Unicyclist Community
Reply
Old 2010-01-29, 04:32 AM   #1
Pigs on Unicycles
Big guy that rides a small unicycle
Pigs on Unicycles's Avatar
40mm Frame on 42mm Bearings
I know there are a few threads on this but I wanted a fresh opinion on this. I am looking at this http://www.unicycle.com/unicycle-har...nch-frame.html to put onto a trials wheel-set with 42mm bearings. I know that the frame isn't meant to be put on a trials uni but would it work or would I have crushed bearings from too few points of impact?
Gene
__________________
Pigs on Unicycles
(Gene)
"Sprite off, you spriting spriter!" - Into the Blue
Pigs on Unicycles is offline   Reply With Quote
Old 2010-01-29, 05:58 AM   #2
saskatchewanian
ERIC P
saskatchewanian's Avatar
Send a message via MSN to saskatchewanian Send a message via Skype™ to saskatchewanian
I have been riding an ISIS hub (42mm bearings) in a frame desighned for 40mm bearings for over two years with no issues so far. In-fact i found the larger bearings to be a better fit in the pressed bearing holders.
My concern with that frame is seat-post diameter. I don't see it listed but if it is 22.2mm stay away. Believe me even a bit of weak beginner trials will quickly wreck a 22.2mm post. You can get some pretty good posts in 25.4 though.
__________________
saskatchewanian is offline   Reply With Quote
Old 2010-01-29, 02:03 PM   #3
MuniSano
Hartman Rocks, Uncompahgre beyond..
MuniSano's Avatar
I think you'd be better off spending a little bit more for a compatable frame i.e. with 42mm bearing housings. Is $20-$30 more going to kill you? Unlike saskatchewanian's success with mixing a 42mm hub with a 40mm frame I've had very poor success the times I've tried. I have an old 26" Yuni frame with 40mm housings and non machined bearing covers, the simple bolt and nut and pressed covers. I could never get the hub to fit in the frame quite correctly, it was always a bit crooked and even with shimming it just wasn't quite right. Even worse there was almost no clearance between the outer frame and my cranks so that a lot of paint/metal was initially scraped off of the frame. Not the best ride IMHO. Get a compatable frame, you'll be much happier, oh and make sure it has the machined bearing housings like:
http://www.unicycle.com/unicycle-har...ome-frame.html
You'll be much happier in the long run.
My two cents...
__________________
munisano
MuniSano is offline   Reply With Quote
Old 2010-01-29, 03:19 PM   #4
saskatchewanian
ERIC P
Quote:
Originally Posted by MuniSano View Post
Unlike saskatchewanian's success with mixing a 42mm hub with a 40mm frame I've had very poor success the times I've tried. I have an old 26" Yuni frame with 40mm housings and non machined bearing covers, the simple bolt and nut and pressed covers...
Interesting. I have the same frame and find it fits great. I did have to shim the one side since it is not perfectly even (had to do this with the old wheel as well). Tolerances could have been pretty loose for those frames though and I might have just gotten lucky.
Before we start suggesting products we should probably know why Gene wants that frame. Sure the trials frame is a safer bet but maybe he just wants a round crown.
__________________
Old 2010-01-29, 03:25 PM   #5
MuniSano
MuniSano's Avatar
Yeah you might have gotten lucky, or else I was a bit unlucky? Either way, I didn't mean to suggest a particular product, just that they make 40mm and 42mm compatable frames for a reason and one would be best served getting a compatable frame. That isn't to say you can't try and make it work, but I think that in the long run one would be better off with compatable components; just my humble opinion. (I'm all for tinkering, I've got a few Franken-Uni's that I've developed in the past)
__________________
munisano
Old 2010-01-29, 08:52 PM   #6
corbin
Treehouse Muni Rider
corbin's Avatar
Send a message via AIM to corbin
Quote:
Gene
Yes, eventually it will effect the bearings. They will wear out prematurely, and it will possibly affect how well the wheel rotates.
--corbin
__________________
http://www.corbinstreehouse.com
maestro8 fan club
Justin LE fan club
corbin is offline   Reply With Quote
Old 2010-01-29, 10:32 PM   #7
jaco_flans
Trials & Muni!
jaco_flans's Avatar
Send a message via MSN to jaco_flans
I dont really know about the bearings. but if you want to put a trials wheel in that frame you'll need a Try-all tire, because it's rounder than any other trials tire. My Luna didn't fit in my round crown frame I had from my learner uni but my Try-all did.
__________________
Jakob F.
Trials 'n Muni 'n Trials 'n Muni
jaco_flans is offline   Reply With Quote
Old 2010-01-30, 02:06 AM   #8
unicycler100
Names Jesse :P
unicycler100's Avatar
Send a message via MSN to unicycler100
I've used one of those frames for a while doing hard trials on it. and I was useing a nimbus wheel set ISIS. still going strong. but now I have KH long neck. bearing are still good tho
__________________
You know your not succeding when you know your not achiving anything
unicycler100 is offline   Reply With Quote
Old 2010-01-30, 05:47 AM   #9
maximus unius
Registered User
maximus unius's Avatar
I'm using a Nimbus II frame from a couple years ago when the holders were 40mm and not machined. The wheel has 42mm bearings, but I haven't ridden the setup long enough to comment on how much it will wear out the bearings. There is not slop in the setup and it seems pretty solid though.
I'm only using this setup because I already had the frame, and it wasn't worth $65 for a new Nimbus II. In your case, I would go ahead and spend a little more for the right frame.
maximus unius is offline   Reply With Quote
Old 2010-01-31, 04:10 AM   #10
Pigs on Unicycles
Well, I was going to get then Nimbus round-crown but Unicycle.com US stopped carrying them and the are a b to find.
Gene
__________________
Pigs on Unicycles
(Gene)
Reply
Tags
40mm, 42mm, bearings, frame
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
running 42mm bearings in a 40mm frame-for MUNI wumpus General Unicycling Discussions 16 2008-07-24 03:10 PM
42mm Bearings into a 40mm Frame? Jerrick General Unicycling Discussions 3 2006-11-15 03:34 AM
24" frame that fits 42mm bearings zfreak220 Unicycle Product Reviews 5 2006-08-01 06:43 PM
42mm bearings to 40mm unijesse General Unicycling Discussions 9 2006-02-13 04:01 AM
Fitting 42mm bearings in KH freestyle frame TonyMelton General Unicycling Discussions 3 2004-09-24 01:21 AM
Copyright © 2001-2005 Gilby
Page generated in 0.07962 seconds with 10 queries
