#1501 |
Registered User
Du assi. Verbring ja fast mehr zeit das Dingen zusammen zu bauen.
#1502 |
Registered User
Hat nur 20 min gebraucht
![]() hatte halt nicht viel zeit und wollt halt was technisches machen |
#1503 |
slc uni
Trick 1: jump on 44 cm then jump down angled upsidedown pallet from there pedalgrap gap 90cm high 88 cm wide. Trick 2: 138cm gap up to 59cm Trick 3: 119cm gap up to 72cm Trick 4: 85cm sidehop, set by Jesper. Trick 5: 70 second stillstand, set by Tom. Trick 6: pedalgrap block 15/15 cm 66cm high set by markus trick 7: will be set by Tom on Thursday, 5/31 O _ _ markus**(set) O U _ Tom* (landed) O _ _ Timolein* Last edited by tmoyer; 2012-05-25 at 12:39 AM. |
#1504 |
Registered User
Ich mach das so wie tmoyer
#1505 |
Registered User
tom are you going to set????
#1506 |
slc uni
Sorry - I didn't have time during the week to ride. I should be able to set today.
#1507 |
slc uni
Trick 7 is a 61 cm sidehop to skinny, 3 seconds or 3 hops on the skinny. Max skinny width is 4 cm. The skinny has to be a free span - unsupported in the middle.
I'm leaving on a trip on the 13th, so I might get one more trick in after this one and then I'll be out. The second clip on this video is my 10 year old daughter's first trials trick. OTG Trials - Trick 7 Trick 1: jump on 44 cm then jump down angled upsidedown pallet from there pedalgrap gap 90cm high 88 cm wide. Trick 2: 138cm gap up to 59cm Trick 3: 119cm gap up to 72cm Trick 4: 85cm sidehop, set by Jesper. Trick 5: 70 second stillstand, set by Tom. Trick 6: pedalgrap block 15/15 cm 66cm high set by markus Trick 7: 61 cm hop to skinny, set by Tom. Due at 23:59 in your time zone on Saturday June 9th. Trick 8: will be set on June 10th. O _ _ markus** O U _ Tom** (set) O U _ Timolein* Last edited by tmoyer; 2012-06-03 at 05:18 AM. |
#1508 |
Registered User
nice one
#1509 |
Registered User
is it ok so? :
Trick 1: jump on 44 cm then jump down angled upsidedown pallet from there pedalgrap gap 90cm high 88 cm wide. Trick 2: 138cm gap up to 59cm Trick 3: 119cm gap up to 72cm Trick 4: 85cm sidehop, set by Jesper. Trick 5: 70 second stillstand, set by Tom. Trick 6: pedalgrap block 15/15 cm 66cm high set by markus Trick 7: 61 cm hop to skinny, set by Tom. Due at 23:59 in your time zone on Saturday June 9th. Trick 8: will be set on June 10th. O _ _ markus**(landed) O U _ Tom** (set) O U _ Timolein* |
#1510 |
slc uni
Nope - the skinny has to be a free span - unsupported in the middle. It's a lot scarier that way.
![]() Nice hop to stillstand, though. I was never able to get one that good. |
#1511 |
Registered User
did it again:
#1512 |
slc uni
Nice work.
#1513 |
Registered User
pedalgrap a rail min 70 cm high, max diameter 10 cm. the material of the rail does not matter:
Trick 1: jump on 44 cm then jump down angled upsidedown pallet from there pedalgrap gap 90cm high 88 cm wide. Trick 2: 138cm gap up to 59cm Trick 3: 119cm gap up to 72cm Trick 4: 85cm sidehop, set by Jesper. Trick 5: 70 second stillstand, set by Tom. Trick 6: pedalgrap block 15/15 cm 66cm high set by markus Trick 7: 61 cm hop to skinny, set by Tom. Due at 23:59 in your time zone on Saturday June 9th. Trick 8: pedalgrap a rail min 70 cm high, max diameter 10 cm Trick 9: WONT BE SET!!! ![]() O _ _ markus***(set) O U _ Tom** O U T Timolein |
#1514 |
slc uni
I forgot to film the width of the rail, but it's my same 4 cm skinny.
Time to start a new game. I'll be back on June 30th and I'll join back in then with a letter or two. Trick 1: jump on 44 cm then jump down angled upsidedown pallet from there pedalgrap gap 90cm high 88 cm wide. Trick 2: 138cm gap up to 59cm Trick 3: 119cm gap up to 72cm Trick 4: 85cm sidehop, set by Jesper. Trick 5: 70 second stillstand, set by Tom. Trick 6: pedalgrap block 15/15 cm 66cm high, set by markus Trick 7: 61 cm hop to skinny, set by Tom. Trick 8: pedalgrap a rail min 70 cm high, max diameter 10 cm, set by markus Trick 9: WONT BE SET!!! O _ _ markus***(set) O U _ Tom** (landed) Last edited by tmoyer; 2012-06-13 at 12:11 AM. |
#1515 |
slc uni
New game.
_ _ _ Tom |
| Tags |
| beginner or intermediate, best out the gamer ever, game, otg, out the game, sambohdee, trials |
Similar Threads
| **OUT the Game Flat** Beginner/Intermediate | Julia B | Challenge Each Other | 1275 | 2012-09-23 12:49 AM |
| * Out the Game * | Matti M | Challenge Each Other | 132 | 2011-07-24 10:53 AM |
| *Out The Game - Freestyle* | SamGoodburn | Challenge Each Other | 153 | 2011-04-04 10:42 PM |
| **OUT of the game Flat** Super Beginner | Pimpinpete | Challenge Each Other | 446 | 2010-08-31 03:15 AM |
| ++FLIPS++ Out The Game | Emile.m | Challenge Each Other | 109 | 2009-12-23 08:02 PM |
