Unicyclist Community
Go Back   Unicyclist Community > Unicycling Discussion > Unicycle Product Reviews
Reply
Old 2009-08-05, 01:20 AM   #1
shermanator94
Registered User
shermanator94's Avatar
Qu-ax Trials
are qu-ax 20 unicycles good?
will they last under heavy trials?
are their parts interchangeble with KH / Nimbus?
shermanator94 is offline   Reply With Quote
Old 2009-08-05, 02:09 AM   #2
xtor
UNIPSYCHO
Send a message via Skype™ to xtor
I think so, though the tire doesn’t last as long as i would like.
2- Don't know this 200 lbs weight only hops around and only drops
1 foot at the most.
3- Again I don't know I have not had any problems hence, no need to change
parts.
xtor is offline   Reply With Quote
Old 2009-08-05, 03:00 AM   #3
muniing sam
Registered User
muniing sam's Avatar
Which qu-ax 20'' are you meaning, the one with the Yellow hub or the red hubbed model?
muniing sam is offline   Reply With Quote
Old 2009-08-05, 03:12 AM   #4
xtor
UNIPSYCHO
Quote:
Mine is red but I have heard that the yellow is better. Again, I have had no
problems with it.
Old 2009-08-05, 03:31 AM   #5
muniing sam
Registered User
shermanator94 if you are meaning the Qu-Ax 20" Crossfire Beginners Trials Unicycle then you can put Nimbus and KH Cranks on that hub. But the stock Qu-Ax 20" Crossfire is not strong enough for heavy trials. The Qu-Ax Splined Trials Unicycle - ISIS is stronger than the trials with the red hub but very heavy. I would suggest getting a Nimbus with Moments as its lighter then the yellow hubbed trials also the nimbus is a good price and strong.
Old 2009-08-05, 04:01 AM   #6
shermanator94
Registered User
sorry for not specifying. I was talking about the yellow hubbed one. how much more does the qu-ax ( yellow hub) weigh than the nimbus?
__________________
Your head lives in your gut. Listen to your gut
Old 2009-08-05, 04:24 AM   #7
muniing sam
Registered User
The Qu-Ax 20" Heavy Duty Trials Unicycle (yellow hub) weighs 6.45kg vs 5.7kg for the Nimbus, so alot more.
Old 2009-08-05, 06:33 PM   #8
shermanator94
Registered User
is the nimbus frame stronger?
__________________
Old 2009-08-05, 08:18 PM   #9
Smilymarco
just call me similymarco
Smilymarco's Avatar
Send a message via ICQ to Smilymarco Send a message via MSN to Smilymarco
They are the same.
The quax wheelset (the rim) is a bit stronger. Youre comparing a strong to a strong uni here.
Just be sure if you get the Nimbus, get it with Moment cranks.
__________________
Riding for Triton
Sponsored by HARTKOR FAKKER
Supported by Municycle.com
Protected by Better for your body
Smilymarco is offline   Reply With Quote
Old 2009-08-06, 04:49 PM   #10
shermanator94
Registered User
qu-ax cranks good? as good as moments?
__________________
Old 2009-08-06, 05:17 PM   #11
jaco_flans
Trials & Muni!
jaco_flans's Avatar
Send a message via MSN to jaco_flans
No cranks are as good a moments, Moments are impossibly solid I dont know if they are good but I am pretty sure they are, someone that has them can answer better than me...
__________________
Jakob F.
Trials 'n Muni 'n Trials 'n Muni
jaco_flans is offline   Reply With Quote
Old 2009-08-06, 05:23 PM   #12
shermanator94
Registered User
well, if you had a choice between these two unis, which would you pick?
new nimbus ISIS trials uni w/ moments - $330 + tax + shipping
or
used qu-ax trials ( yellow hub) - $300 + free shipping + no tax
__________________
Old 2009-08-06, 05:26 PM   #13
jaco_flans
Trials & Muni!
jaco_flans's Avatar
I would go with the Nimbus because I find them cooler and they are compatible with more parts than the Qu-ax(I think). Plus 4 of my friend owns Nimbus Trials uni and they are really good. But this is just my opinion.
__________________
Jakob F.
Old 2009-08-06, 09:27 PM   #14
shermanator94
Registered User
any other people have other opinions?
__________________
Old 2009-08-07, 08:14 AM   #15
WOFT
Likes trees
WOFT's Avatar
Send a message via MSN to WOFT
The yellow-hubbed Qu-ax is a very strong unicycle. Some say it is stronger than a KH (I may get into trouble for saying this though!). However, it is a lot heavier than KH or nimbus. The tyre is the same one you'll get with a KH or Nimbus.
I've put my qu-ax through 2m drops. the only breakage being seatposts, pedals and a (KH street) saddle. Since I got the gusseted seatpost, i've had no more broken posts.
__________________
'n Boer maak 'n plan.
WOFT is offline   Reply With Quote
Reply
Tags
quax, trials
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Erfahrung, Qu-Ax 36" + Canti Bremse AndreaA Deutsches Einradforum 4 2011-05-18 04:10 PM
[For Sale: Australia] qu-ax 24inch muni knighty Trading Post 11 2009-08-31 08:56 AM
Qu-Ax 20" Trials Uni for sale JAYBIRD Trading Post 12 2009-08-18 12:51 AM
Building and Ultra light trials wheel using an actual 20in trials rim wickedbob General Unicycling Discussions 4 2009-03-22 11:15 PM
[For Sale: UK] Nimbus ISIS trials w/ moment cranks. Also, KH 19" wheel, trials rim and frame simonb Trading Post 6 2009-01-18 08:41 PM
Copyright © 2001-2005 Gilby
You Rated this Thread:
Page generated in 0.09205 seconds with 10 queries
