Unicyclist Community
Go Back   Unicyclist Community > Unicycling Discussion > Unicycling Articles and Tutorials
Reply
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 2009-04-25, 11:20 PM   #1
SaskatoonZaz
Registered User
Advanced Hopping- Plz Help
How do I get more height out of my jump? I can only jump like 2 inches high...
Plz help!!
SaskatoonZaz is offline   Reply With Quote
Old 2009-04-25, 11:29 PM   #2
hungry4uni
Colby Thomas
hungry4uni's Avatar
I never tried this, but just imagine jumping without the unicycle. Then do it on the unicycle. This should help out a bit. Then there gets more technical stuff like SI (seat in) and SIF (seat in front). Until them, work on what I said, one day it will come.
__________________
COLBY
THOM BROS
hungry4uni is offline   Reply With Quote
Old 2009-04-26, 12:20 AM   #3
SaskatoonZaz
Registered User
Thanks. If it helps any for you to give advice, I hop seat in.
Old 2009-04-26, 12:37 AM   #4
Michaelgoround
John 15:13
Michaelgoround's Avatar
Just keep hopping and you will start getting farther and higher. Set goals for your distance and your height and you wil progress.
Michaelgoround is offline   Reply With Quote
Old 2009-04-26, 01:16 AM   #5
UNIbike
Registered User
UNIbike's Avatar
I can jump about half a metre si but less sif anyone got any tips sif jumping
UNIbike is offline   Reply With Quote
Old 2009-04-26, 02:49 AM   #6
Myles
Registered User
what i've been working on that seems to help is just timing. Learn to compress your tire and jump straight up when it is fully compressed. I have added a little height to my vertical from proper timing. Also, make sure that after you jump up, you bring the unicycle up under you (pull it up with your hand)
Myles is offline   Reply With Quote
Old 2009-04-26, 02:59 AM   #7
Ducttape
I unicycle for Donuts
Ducttape's Avatar
Send a message via AIM to Ducttape Send a message via MSN to Ducttape Send a message via Yahoo to Ducttape Send a message via Skype™ to Ducttape
Quote:
Ducttape is offline   Reply With Quote
Old 2009-04-26, 03:02 AM   #8
UNIbike
Registered User
UNIbike's Avatar
I don't really get u when u say to compress the tire is it making it flat as possible so it give u more spring in the jump?
Old 2009-04-26, 03:15 AM   #9
Ducttape
Ducttape's Avatar
that means push down REALLY hard with all your body weight so that the tire squishes and then springs back up to give you more bounce.
Old 2009-04-26, 03:17 AM   #10
SaskatoonZaz
Registered User
I tink so
Old 2009-04-27, 01:05 AM   #11
saskatchewanian
ERIC P
saskatchewanian's Avatar
Send a message via MSN to saskatchewanian Send a message via Skype™ to saskatchewanian
Yo S'toon. I am moving up north but will be back in town in a couple weeks. Thinking of trying to get a few riders together in Toon Town. I am thinking an afternoon ride Sunday the 10th. Let me know if you are in.
Can't really help you with the hop though. Definitely not my strong suit.
saskatchewanian is offline   Reply With Quote
Old 2009-04-27, 07:49 AM   #12
Obtusellama
Hand me my unicycle, sir.
Obtusellama's Avatar
Send a message via MSN to Obtusellama
As simple as it sounds i find it helps when you visualise yourself doing something just before you do. Alot of it just comes down to practice and confidence.
Also, Try lowering your seat. This way you can pull the uni up higher when your in the air. I gained a few more inches off the ground from doing this.
Good luck!
Obtusellama is offline   Reply With Quote
Old 2009-04-27, 08:16 PM   #13
Myles
Registered User
compressing the tire makes you spring upwards
you have to do a couple little hops and then when you're at the peak of a hop slam your unicycle/body down and then launch back up. Then when you get to that peak, work on compressing your tire from your new max height and you'll continue to get higher. Then eventually you'll have to switch to sif to get higher (or rolling hops)
Old 2009-04-27, 10:11 PM   #14
Harley
Registered User
Keep me in the loop re: the Sunday ride Eric. Time, place, type of uni etc.
__________________
Always remember: With patience and perseverance you can piss a hole through a rock.
Harley is offline   Reply With Quote
Old 2009-04-28, 12:50 AM   #15
blueharmony
Kenny Cason
blueharmony's Avatar
I noticed while watching the Ryan Atkins video that he barely bends his knees while hopping, yet gets quite a bounce. If one were to jump without the uni all the power would be from the knees. I'm sure correct form has a lot to do with it but is it mostly the quick-twitch muscles that give the rider that much height?
__________________
- Kenny
blueharmony is offline   Reply With Quote
Reply
Tags
advanced, hop, hopping, jump, plz
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Help my cats get in the newspaper Ergolicious Just Conversation & Introduce Yourself 6 2009-04-25 12:13 AM
Bah! who needs a GameBoy Advanced? LegoBoy Just Conversation & Introduce Yourself 10 2005-06-04 07:15 PM
Extremely advanced Coker bronson General Unicycling Discussions 64 2002-10-30 03:18 PM
Advanced Unicycling Technology Maxfield D General Unicycling Discussions 0 1998-04-29 07:01 PM
Copyright © 2001-2005 Gilby
You Rated this Thread:
Page generated in 0.09561 seconds with 11 queries
