Unicyclist Community
Reply
Old 2011-10-11, 12:04 PM   #211
OUK
An)-On Juncher
OUK's Avatar
Broken frame
Which one would you guys recommend me to get now?
__________________
~An)-On
Ethjulet Cykel - UDC Denmark
Danish Trial Team
I ride one wheel cus it's way more sustainable than riding two!
OUK is offline   Reply With Quote
Old 2011-10-11, 05:05 PM   #212
trepper687
Doin' my thang
trepper687's Avatar
Quote:
Originally Posted by johnfoss View Post
The first generation of those seemed to have a weakness in that very area; possibly a manufacturing defect. Many people got free replacements when that happened, including me, so check with your seller, and they may make you whole pretty soon!
THanks for the advice. I emailed UDC and they said they'd give me a replacement, I just need to call.
__________________
-Me
trepper687 is offline   Reply With Quote
Old 2011-10-11, 05:26 PM   #213
jaco_flans
Trials & Muni!
jaco_flans's Avatar
Send a message via MSN to jaco_flans
Quote:
Originally Posted by OUK View Post
Broken frame
Time for a Triton?
__________________
Jakob F.
Trials 'n Muni 'n Trials 'n Muni
jaco_flans is offline   Reply With Quote
Old 2011-10-11, 06:37 PM   #214
Batteriknutte
Registered User
The Triton uses a weaker form of Titanium compared to the UDC/nimbus-titanium. I would chose the Nimbus, tho it's crown is a bit bigger than the KH. But not near as disturbing for your knees as the old style triton design.
Batteriknutte is offline   Reply With Quote
Old 2011-10-11, 06:58 PM   #215
OUK
An)-On Juncher
OUK's Avatar
Think I will go for the QX alu frame, since it's strong and it has a good crown (and I don't really care much about weight). I don't like the Nimbus crown, since it has a about 0,5 cm extension which destroys you knees
Maybe I should put 20 euros more into it and get an Impact..
Quote:
Originally Posted by jaco_flans View Post
Time for a Triton?
need a little bit of $ before i will be able to get that
__________________
~An)-On
Danish Trial Team
Old 2011-10-11, 07:09 PM   #216
jaco_flans
Trials & Muni!
jaco_flans's Avatar
Quote:
Even though it has weaker Titanium than the Nimbus Ti, it uses 27,2mm seatpost instead of 25,4mm and no one ever broke a Triton anyway. I haven't really seen anyone riding the Nimbus. My Triton is still in perfect shape (except for the scratches) and I ride it really hard
OUK: I'd throw 20 euros more and get an Impact frame
__________________
Jakob F.
Old 2011-10-11, 07:44 PM   #217
OUK
An)-On Juncher
OUK's Avatar
The only downside is the roundcrown.. I could get the flat crown, but the I'd preffer saving the 20 euros and buy a QX alu long neck..
But firstly I need to try to get it welded, I just need to find a place where they weld aluminium :P
__________________
~An)-On
Danish Trial Team
Old 2011-10-12, 09:06 AM   #218
triton
Registered User
triton's Avatar
Question
I really wonder what interesting details you know about nimbus and triton
tell us more about your knowledge...
triton is offline   Reply With Quote
Old 2011-10-12, 09:28 AM   #219
gazza
Triton Bikes
gazza's Avatar
Send a message via ICQ to gazza Send a message via Skype™ to gazza
Hi Batteriknutte,
My name is Dmitry and I run Triton frames' production.
Can you please specify how exactly you have defied "weaker" form of titanium used for Tritons compared to Nimbus titanium?
It's just interesting.
Nimbus do not publish the grade of titanium they use for their frames.
It can be either Ti 3AL-2.5V or 6AL-4V. These are two grades generally used for bicycle frames and you can get proper sized tubing only made of those grades.
3-2.5 is the most popular grade.
6-4 is more stiff titanium which may not bee to good when used on a unicycle. More likely to crack at the crown/seat tube junction.
Plus most 6-4 tubes are welded from sheets.
3-2.5 Ti is extruded as tubing.
Triton uses Russian standard OT4 titanium which is basically Ti 3AL-2.5V.
We have built hundreds of bicycle and unicycle frames since 2005.
From "calm" cross country frames to extreme trials and street trials. Frames used by experienced riders at the Russian and European comps and bashed like hell. They do hold really long.
Bike frames do crack sometimes.
Most cases (we have had less than 10) were trials frames after at least 1.5-2 years of riding. Which is very good compared to aluminum.
Couple of months ago we fixed (welded a stay) a trials frame that was made in 2007. Four years ago. We fixed it. Then the guy participated in the local Championship. The frame will hold another couple of years.
Triton frames are handmade in Russia. Some frames come in series and some are custom.
What do you know about Nimbus?
What's the grade?
I know where it's made - Asia.
It's not bad, it's the way every brand does it now. Because it's cheaper than to make it in your own country.
But that's the difference.
__________________
Triton Bikes
Custom Titanium bikes and unicycles handmade in Russia
gazza is offline   Reply With Quote
Old 2011-10-12, 09:35 AM   #220
Trevor Staader
Trials is pretty good
Trevor Staader's Avatar
Broken frame
Attachment 50813
Attachment 50814
Hi, I was just wondering how you broke it and how old the frame is?
Trevor Staader is offline   Reply With Quote
Old 2011-10-12, 02:09 PM   #221
OUK
An)-On Juncher
OUK's Avatar
Quote:
It's pretty old about 2 years, maybe even more, i think. I were trying to jump over a 75x25 cm concrete thing rolling, and the frame snapped half way over, so it was still rideable after. Then after a days of riding I did a SIF drop from my car and it snapped the whole way..
__________________
~An)-On
Danish Trial Team
Old 2011-10-12, 07:46 PM   #222
Mountainuni1
Registered User
Mountainuni1's Avatar
Send a message via Yahoo to Mountainuni1
Thank you Dmitry! Well put, and certainly instills more confidence in your products when you provide that level of detail. And, being able to debunk a myth about Triton frames on a thread not even dedicated to discussing such a topic.
Signed,
Huge proponent & Distributor of Triton frames.
Mountainuni1 is offline   Reply With Quote
Old 2011-10-12, 08:16 PM   #223
MuniAddict
Not "2" Tired
MuniAddict's Avatar
One of my fusion FF saddles had a loose nut, causing it to spin when screwing on the lift handle bolt. After removing the saddle cover I tried to pull the foam off in one piece, but it was so totally "fused" to the base that became impossible without the foam tearing and breaking to pieces. I was determined to re-attach the loose base nut so I bit the bullet and pulled the foam off, destroying it in the process.
I could have tried to just lift the front of the foam up, but there was also another nut about to come loose in the center, where the seat post is attached. I figured no biggie since I had an old foam, intact, from an older FF saddle. Turned out that I had forgotten that the older foam was super soft and spongy, and not the "dual density" used in the newer FF saddles. So I called UDC to see if I could buy a few of the newer back up foams, as I had in the past.
I figured they were available, since UDC still makes the FF air saddle mods, which means they would have to remove the existing foam from the saddles to do the mod. They also said that sometimes the foams come off easily, other times not. But they told me that they didn't have any extras at all, which I found surprising. I didn't want to have to buy a WHOLE NEW FF saddle, when all I needed was a new foam piece, but apparently, I had no choice, so I ordered a brand NEW FF saddle.
I had been told several times that the NEW FF saddles would not have the "spinning bolt" problem, as all the new saddles had that issue addressed and fixed, by "welding" them into place. Well, after receiving the new FF saddle I began the process of switching the seatpost and KH t handle from the saddle I had fixed, to the NEW FF saddle.
Well, guess what? As I was finishing installing my KH t-handle bracket and lift handle, and having successfully--and very gingerly--screwed in the first three bolts, and thinking I was home free, as I started screwing in the FOURTH and final bolt into the base nut, and it was turning...and turning...and TURNING! The NUT on the NEW FF saddle became loose and was SPINNING with the bolt!!!!!!!!!!!!!!
I was in pretty much in shock that this could/would happen AFTER I was told that the issue had been fixed by "welding" the base nuts in place! Needless to say, I am very disappointed. and there was no way I was going to attempt another "fix" of my own and risk destroying the foam in the attempt. I'm sending it back and hopefully I will get a a saddle that won't have this problem!
I don't know, but maybe they unwittingly sent me a saddle that had not had the base nuts "welded", or done properly. So frustrating!
__________________
My latest TV segment
UniGeezer.com
My videos
MuniAddict is offline   Reply With Quote
Old 2011-10-12, 10:52 PM   #224
skilewis74
Stupidity gets you 2 of these:
skilewis74's Avatar
Send a message via Yahoo to skilewis74
...But firstly I need to try to get it welded, I just need to find a place where they weld aluminium :P
skrobo had his welded at an auto shop. They also welded a small patch on the front and back of the frame covering the neck and part of the crown, I think he said it cost him $40. He posted picks of it but the search feature isn't working, so I can't find it right now.
__________________
Ride everywhere and never just ride anywhere. If you can ride where you are going within a hour, do it, and if you can do a trick 50-75% of the time do it along the way.- Bob Burnquist
What's next?
Learn2Ride&doTricks
TrialsClasses&Building
skilewis74 is offline   Reply With Quote
Old 2011-10-13, 01:03 PM   #225
OUK
An)-On Juncher
OUK's Avatar
Quote:
I will try at an autoshop And I think I'm gonna get it reinforced like Kevin Kartchners frame
__________________
~An)-On
Danish Trial Team
Reply
Tags
broken, parts, post, uni
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Post pictures of your Siege engine! Jeremy R Just Conversation & Introduce Yourself 15 2009-03-31 04:34 PM
Broken Unicycle Parts Count UNIquelyCanadian General Unicycling Discussions 25 2006-05-12 02:26 AM
broken parts movie brockfisher05 General Unicycling Discussions 5 2005-01-21 11:36 PM
Gallery of Broken Uni Parts daino149 Just Conversation & Introduce Yourself 8 2003-10-10 07:33 AM
Re: Broken parts: Was: Who are you guys? Raphael Lasar General Unicycling Discussions 0 2002-05-17 06:33 PM
Copyright © 2001-2005 Gilby
You Rated this Thread:
Page generated in 0.10178 seconds with 11 queries
