#1 |
Registered User
First Generation Coker weight difference?
So I just picked up a very clean 1st gen Coker big one, it is all steel for $175
. I am fine with the steel frame, but am wondering what the weight difference is between the older wheel set and the new one? I have done an extensive search and found nothing on the weight of the Coker steel wheel set. The Coker sight says the new wheel set is 1170 grams without the tire and tube. So how much heavier is the steel one? They have the whole wheel set listed at $118.00 so it wouldn't be a big investment to upgrade the wheel set...but I'd rather to waste the $ if they are about the same weight. I have contacted the Coker people and asked if I can buy just the rim and swap it out since that will make the biggest difference while riding. I found a rim alone on Unicycle.com but it was $115 and I might as well get the whole wheel set for that price right? Thanks for any advice or thoughts.
__________________
Ride On... Vince |
#2 | |
Treehouse Muni Rider
Quote:
The old rim and the new rim have a different number of spokes; they are not interchangeable. You want an airfoil rim if you are going with the old coker, and upgrade to 14g ss spokes. That's a good upgrade for what you have. corbin |
#3 |
weather is a fiend
i have a steel oldschool coker wheel. they're hella heavy i didn't realize that coker sold the replacement wheelset! that's suddenly become pretty high on my list
__________________
android power. |
#4 |
Mainly XC Muni
I swapped my old steel qu-ax wheel (an exact rip-off of the original Coker) for a Nimbus Stealth rim with 14 gauge spokes and ally cranks. It saved over 1330g (close to 3lbs) - very noticeable when riding.
I posted about in in this thread. Rob |
#5 |
Registered User
Thanks guys....Rob did you ever weigh your old wheel set? 1330g of weight savings is kind of amazing! For $118+ shipping that seems like a no brainer.
__________________
Ride On... Vince |
#6 | |
Mainly XC Muni
Quote:
Bear in mind mine's a Nimbus Stealth Pro rim - I don't know how that compares to the new Coker ones weight-wise, but I'd expect it to be similar. My old wheel (Qu-Ax steel with 12-gauge spokes) was pretty much identical to an old Coker wheel. Rob Edit: Are the new Coker wheels really that cheap? Seems like quite a bargain. Last edited by rob.northcott; 2009-03-31 at 04:04 PM. |
#7 |
Registered User
Thank you for clarifying Rob, I did read your earlier post it was enlightening. Almost 7 pounds of rolling weight saved, that is a no brainer!
I am calling Coker today and seeing if the $118 is right and what shipping is.
__________________
Ride On... Vince |
#8 |
Mainly XC Muni
#9 |
Registered User
My understanding is moving weight is multiplied by a certain factor and spinning weight at the rim is double static weight...at least that is how I understand it at the simplest level.
__________________
Ride On... Vince |
#10 |
Registered User
I started to place an order and shipping for the wheel set was $8.00, making it 124 and change shipped. I will be ordering this real soon!
__________________
Ride On... Vince |
#11 |
North Shore ridin'
Please note that the original Cokers used standard-width hubs. the newer ones use wide hubs, which could be an issue in fitting the frame. Not sure how much width difference there is, and it if will cause problems to widen the old Coker frame to fit.
If that's true for bike wheels, it's probably even more true for 36" wheels (bigger multiplier). But that's a "virtual" weight savings rather than an actual one. Saving rotating weight is always a good thing!
__________________
John Foss "jfoss" at "unicycling.com" www.unicycling.com "Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben |
#12 | |
Mainly XC Muni
Quote:
![]() Rob |
#13 |
Registered User
A standard hub has an outside bearing spacing of 110mm. The Coker hub is 140mm outside/outside bearing spacing. Because the old frame is steel, it should be possible to spread the frame to accomodate the new wheel. I have straightened, and opened many bike frames/forks and it is fairly straight forward if you have the right tools. The trick with opening the frame is doing it without denting the tubes.
Unfortunately, the tools used for squaring/alligning the dropouts on a bike won't work in a uni frame, and so you will have to make a tool for this purpose. ![]() I don't think it would be too dificult to make a set of tools that gets clamped in the bearing hangers, and allows for applying leverage to the fork blade. I have an idea in mind, if you are interested I can draw it up for you. |
#14 |
Mainly XC Muni
My "tool for the purpose" was a foot and a hand
These frames are pretty crude - not much danger of damaging the tubing like on a nice bike frame. Rob |
#15 |
Registered User
How did you make sure that the frame was straight after you bent it? Did you just eye it?
| Tags |
| coker, difference, generation, weight |
Similar Threads
| Does anyone know the weight difference between an '04 24" KH and the new Freeride? | pdc | General Unicycling Discussions | 0 | 2005-05-23 03:40 PM |
| Weight difference- KH Pro vs Wilder 6160c | Rowan | General Unicycling Discussions | 7 | 2003-06-23 03:09 AM |
| Weight difference - KH20 vs. Summit 20 | daino149 | General Unicycling Discussions | 4 | 2003-05-11 10:35 PM |
| weight difference | BigWheelTex | General Unicycling Discussions | 0 | 2002-11-12 02:06 AM |
| Coker weight | BigWheelTex | General Unicycling Discussions | 4 | 2002-11-10 07:22 PM |
