Unicyclist Community
Reply
Old 2009-02-10, 02:52 PM   #1
cbs
Registered User
cbs's Avatar
time to start learning!
I can finally ride starting this weekend. Any hints on best places to start? I was thinking of starting by a building. I am just now allowed after having a broken arm so want to try not to fall bad yet lol. I've waited so long, I'm stoked! I'm just mentally scared cause of my broken arm but was OK rollerskating after 15 mins. this weekend.
cbs is offline   Reply With Quote
Old 2009-02-10, 03:12 PM   #2
maestro8
is what it is
maestro8's Avatar
Quote:
Here is the best place to start. Any questions or hints you might need can be found quite easily.
__________________
"The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt." - Bertrand Russell
maestro8 is offline   Reply With Quote
Old 2009-02-10, 03:16 PM   #3
MuniSano
Hartman Rocks, Uncompahgre beyond..
MuniSano's Avatar
How old are you? Well if you can drive I'd go find an empty parking lot and park your car there (if you don't drive find an empty parking lot with a light post or something you can prop yourself up on). Using your car (or light post) as a prop to just learn to get on the unicycle and sit there with the aid of a prop. When you start to feel confident enough just sitting there then try pedaling away from your prop and challenge yourself to go further and further before you come off. Remember as you're resting against your prop to keep your cranks at 9 and 3 o'clock and it's probably easiest starting out to get on the unicycle with a prop to have the cranks straight up and down and step on the down pedal first and only after you are seated to move a bit forward or backward to get the cranks level. I know there are a million ways to learn but I only had myself and no videos or books so I called this the "trial by fire" technique. Just prop yourself up in a large playing area i.e. empty parking lot and then slowly try to ride away from your prop. Remember that you want to have a slight lean forward and once you start pedaling don't stop! In this way you can just about guarantee you won't go off backwards (this is bad!). Just be careful! Always wear a helmet and since you have a broken arm be careful with that too. If you can wear wrist protection I'd do that as well. It is very frustrating starting out but you'll find with time you'll make it one, two, three revolutions from your prop. Challenge yourself to make it a bit further each session before you stop. I only practiced for 30-45 minutes at time starting out because any more and I got too tired, frustrated and I could tell I wasn't improving. Eventually you'll ride away from your prop and just keep on going! That is what I did and now you have the whole empty parking lot to ride around and practice. It will take a bit longer to learn how to turn around and free-mount but just focus on being able to ride first. I never considered learning next to a wall or fence (mainly because there was nothing like that around where I live) but I think you're better off learning out in free-space rather than relying on a prop to lean on as you pedal??? Anyhow that is how I learned hopefully you'll learn as quick as I did; maybe 4-5 hours worth of this in 30-45 minute increments. Good luck and have fun! The moment it gets too frustrating during a session it's time to stop.
__________________
munisano
MuniSano is offline   Reply With Quote
Old 2009-02-10, 10:07 PM   #4
Klaas Bil
Sir Prince of Newsgroupia
http://www.xs4all.nl/~klaasbil/uni_beginners.htm
Klaas Bil is offline   Reply With Quote
Reply
Tags
learning, start, time
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Advice please on the best way to start learning to freemount. Splodge General Unicycling Discussions 18 2011-05-15 04:18 PM
Can learning on old, crappy unicycle to start be counterproductive? oceansea General Unicycling Discussions 45 2010-08-19 01:45 PM
Age to start learning todd1814 General Unicycling Discussions 18 2004-04-18 04:17 PM
Ann: British Unicycle Convention 9 - start time Arnold the Aardvark General Unicycling Discussions 0 2002-04-08 07:53 PM
Copyright © 2001-2005 Gilby
Page generated in 0.06474 seconds with 10 queries
