Unicyclist Community
Reply
Old 2009-01-24, 11:32 PM   #1
T.M.C.
T-Bit
T.M.C.'s Avatar
Pedals move during unispins
I filmed myself doing some unispins in my garage with my phone and I noticed that my back pedal moves up when I spin. I think that this is why I never hit my back(right leg) and only my front(left leg). What can I do to stop moving the pedals?
T.M.C. is offline   Reply With Quote
Old 2009-01-24, 11:35 PM   #2
AlisterBurt
Push button, recieve bacon.
AlisterBurt's Avatar
Send a message via MSN to AlisterBurt
i think your spinning too early and your feet are still on the pedals when you spin the uni, which makes the pedals go wonky, try jump up then spin
AlisterBurt is offline   Reply With Quote
Old 2009-01-24, 11:41 PM   #3
T.M.C.
T-Bit
T.M.C.'s Avatar
So more of a "Jump and kick out-spin-then land", instead of "Jump and spin-then land"?
Old 2009-01-25, 12:06 AM   #4
Michaelgoround
John 15:13
Michaelgoround's Avatar
Thanks for posting this, I think i just figured out what I've been doing wrong!
Michaelgoround is offline   Reply With Quote
Old 2009-01-25, 03:11 AM   #5
Emile.m
Registered User
Emile.m's Avatar
Send a message via MSN to Emile.m
You mean the crank or the pedal? Because, good look to stop the pedal from moving.
Emile.m is offline   Reply With Quote
Old 2009-01-25, 03:15 AM   #6
T.M.C.
T-Bit
T.M.C.'s Avatar
The crank moves. I watched the video a few more times and is it possible that it's because my feet aren't leaving the pedals at the same time causing one crank to go higher/lower than the other?
Old 2009-01-25, 04:40 PM   #7
skrobo
jumps stuff
skrobo's Avatar
Send a message via AIM to skrobo
you don't hit your back leg because you are about 100 times more likely to end up w/ the uni too far in front and only catch your back foot than you are to end up to far in front and have a good chance of catching your front foot and missing the back pedal while your leg is in front of the pedal
hope that makes sense.
you could practice no footers to get used to not allowing the pedals to rise/drop.
__________________
><> Unicycle For Christ <><
MY VIDEOS
World Record
94cm Highest Hop (rolling)
308cm Longest Hop (10 feet)
210cm Static Flat Gap
skrobo is offline   Reply With Quote
Old 2009-01-25, 08:32 PM   #8
Lottrup
UniSalg.dk - UDC Denmark
Lottrup's Avatar
An other tip could be to make sure that you dont lift your unicycle. Make sure that the wheel has contact to the ground all the time.
Lottrup is offline   Reply With Quote
Old 2009-01-26, 06:30 AM   #9
Unicaw89
FRAME BREAKER!!!
Unicaw89's Avatar
Location: Phelan Southern CA. Best trick: Pedal grabbing your face!
Send a message via AIM to Unicaw89
Ok, good cross training I used to do back in the day was no footers. Try to jump off the uni and land back on training your legs to leave the pedals at the same time so that the cranks dont flip. As with the trick just like said before do in order, jump off evenly, spin the uni, land back on, impress tha ladies ;D
__________________
Cody Freaking Williams
DIRTY BIRD VIDEO!!
PAINFUL UNI VID!!!
RenegadeJuggling.com
Unicaw89 is offline   Reply With Quote
Old 2009-01-27, 01:24 AM   #10
T.M.C.
T-Bit
T.M.C.'s Avatar
Something else I noticed today while I was practicing was that my front foot when I mount is a little higher than my back. So when I'm hopping SIF my feet aren't perfectly level. I think that this combining with me pushing off on my right foot makes the cranks rise/drop.
Reply
Tags
move, pedals, unispins
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Unicycling commercial during Daily Show hydrophidian General Unicycling Discussions 2 2008-08-30 09:51 PM
Monocycles during the Olympics closing. utemplarbond General Unicycling Discussions 27 2008-08-26 04:57 PM
Who is on during class Uniman_3 Just Conversation & Introduce Yourself 50 2007-05-24 02:43 PM
Acrobatic Move unicycleboy Just Conversation & Introduce Yourself 8 2004-01-17 12:56 AM
New move? David Straitjacket General Unicycling Discussions 17 2002-01-13 05:47 PM
Copyright © 2001-2005 Gilby
Page generated in 0.11243 seconds with 10 queries
