Unicyclist Community
Reply
Old 2008-11-20, 01:37 AM   #1
steveyo
...feeding the machine...
steveyo's Avatar
Guni wheel-build question
So I got my KH/Schlumpf hub today, and I've laced up all the spokes to the rim following the Uni Magazine's instructions. (This is my first wheel build, BTW).
I've tightened up all the spokes to the same length and my next step should be "relieving" the wheel, that is, putting the wheel on the floor and standing on the rim. The problem is I have this new bazillion-dollar hub and if I do this it will be holding my weight right on one of the shifting buttons, which I've heard are somewhat delicate.
How do I "relieve" the wheel while building with this hub?
__________________
steveyo
...like having your own personal rollercoaster...
- a few uni race write-ups
- muni and kokopelli uni t-shirts, mugs and stickers
steveyo is offline   Reply With Quote
Old 2008-11-20, 01:42 AM   #2
harper
768 - It's in your DNA
harper's Avatar
Steve-
Can you get a small cylinder, like a steel can, that is just the right size to act as a protective cup? Ideally it would contact the flange without threatening the spokes and allow the axle to drop down into the can and hang in mid air. A short length of pipe of the right diameter would work as well. PVC is OK and less likely to scratch anything. Then stand on it. A rag around the rim of the can would distribute forces more uniformly on the spoke surfaces if you can't avoid them.
__________________
-Greg Harper
Destroying the climate by shutting down nuclear power plants, one by one, since 1979.
JC is the only main man. There can be no other.
"A fool on a unicycle is redundant" - J.D. Miller
harper is offline   Reply With Quote
Old 2008-11-20, 02:08 AM   #3
tholub
Totally Doable
tholub's Avatar
You don't need to stand on the wheel; I wouldn't say that's a very good way to stress-relieve. (Nor would Jobst Brandt: http://www.sheldonbrown.com/brandt/s...relieving.html).
You can just put on some gloves and firmly squeeze the sets of parallel spokes on each side of the wheel by hand, going all the way around the wheel.
Enjoy the Schlumpf! I just got my replacement for the one Continental lost. Feh.
tholub is offline   Reply With Quote
Old 2008-11-20, 03:05 AM   #4
Chrashing
O>OO
Chrashing's Avatar
Hello Steve,
Glad to read you got your hub arrived.
I'm no expert on wheel building, but have built a few. The method I've been using do to relieve the stress of the wheel is, when the spokes begin to tighten up, mount the wheel (with bearing caps on) in the fork. Grab the rim near the fork, push and pull side to side within the fork, turn the wheel ~45 degrees and repeat for an entire rotation. The tight wheel often makes a cool creak with each push/pull as the stress is relieved. It takes a little strength, to push/pull the rim towards the fork.
This works out well because if you true the wheel in the fork, and it then becomes a adjust and relieve, process.
Man, you got a geared hub and am building a wheel, that is two great things.
__________________
Regards,
Ken
Unicycles are flying machines!
24", 28", 32", and 36" KH frame based mutts.
26" inexpensive travel.
Chrashing is offline   Reply With Quote
Old 2008-11-20, 05:24 PM   #5
unigoat
NAUCC 2013 Course Architect
Steve,
I've built several wheels (unfortunately none of them with a Schlumpf!), but have followed the late (and absolutely great) Sheldon Brown's advice.
http://sheldonbrown.com/wheelbuild.html
The old crankarm trick has served me very well. My 29er rigid singlespeed (bike) has taken an incredible beating and the wheels have needed almost no work.
I've also found the cheap Park Tool TM-1 (around $70 or so) to be indespensible for all wheel work. The numbers don't lie.
unigoat is offline   Reply With Quote
Old 2008-11-20, 05:32 PM   #6
corbin
Treehouse Muni Rider
corbin's Avatar
Send a message via AIM to corbin
steve! what'cha building? I *just* got my KH24 guni built up last night. I can't wait to take it for a true muni spin around the block. But I still don't have a KH36 yet, nor another hub, to do some super fast riding.
corbin
__________________
http://www.corbinstreehouse.com
maestro8 fan club
Justin LE fan club
corbin is offline   Reply With Quote
Old 2008-11-20, 05:43 PM   #7
joemarshall
dumb blonde
I've used the sheldon brown crankarm technique. My wheels have all stayed true, with the exception of my muni, which needed a minor truing in the alps after 4 days of hard downhilling, but pretty much everyone had the spoke keys out at some point on that trip, it was quite hard on wheels somehow.
Joe
joemarshall is offline   Reply With Quote
Old 2008-11-21, 03:41 AM   #8
osmundo
Osmundo
osmundo's Avatar
Steve- Congrats on the schlumpf! You are heroic to build your first wheel with this hub. I hope you like it as much as I do. Initially I was discouraged by the amount of slop and my inability to..
1. Trust my equipment at high speed
2. Change gears without falling.
Soon these concerns melted away. The 36 inch guni is a beautiful thing and i am now changing gears pretty well. It is so much fun and I cannot imagine riding a single speed Coker anymore! Looking forward to hearing your impressions!
osmundo is offline   Reply With Quote
Old 2008-11-21, 10:49 AM   #9
joemarshall
dumb blonde
Also, if you have an ear for pitch, you can get spoke tension even by listening to them and comparing them to a known note - there's instructions on it on
http://www.bikexprt.com/bicycle/tension.htm#pitchtable
I always used to build my wheels next to the piano - although nowadays I have a ukulele which is an alright source of pitch - I just make sure one of the strings is tuned to the pitch I want.
If it's a coker wheel, I can't remember what the note is though - there are equations on that site for working out tension vs. pitch, you'd need to find out from unicycle.com what tension they recommend.
Alternatively, you can use this just as a relative measure, to tell which spokes are less tight than others by listening to the pitch.
Joe
Old 2008-11-21, 11:14 AM   #10
TonyMelton
Proud owner of Kris Holms old shoes
TonyMelton's Avatar
I stood on all four Schlumpf wheels I built! As long as the button facing the floor is pushed in I see no reason why not.
TonyMelton is offline   Reply With Quote
Old 2008-11-21, 01:36 PM   #11
GizmoDuck
Uni Hour Record Holder 29.993km
GizmoDuck's Avatar
Location: Wellington, New Zealand/ Middle of NSW, Australia
Fat Tony stood on my wheel?
No wonder it's gone all funny
GizmoDuck is offline   Reply With Quote
Old 2008-11-21, 02:21 PM   #12
capuni
Perry
capuni's Avatar
Send a message via MSN to capuni Send a message via Yahoo to capuni
Quote:
I built up a KH29 guni yesterday and took it for my first guni ride. I zipped down (and I do mean zipped.... damn this thing is fast) to the local trail to test it out. Once I got off the pavement in geared up mode, my first thought was "what would this be like on a 24guni?"
Looking forward to hearing about your experience on the 24 Corbin.
__________________
2008 Evolution of Balance Award - Panama Expedition
My Ride The Lobster Photo Album
capuni is offline   Reply With Quote
Old 2012-02-24, 02:37 PM   #13
steveyo
steveyo's Avatar
new guni wheel-build question
A new guni wheel-build question:
I dissembled my guni wheel, sent the hub back, just rcved new hub, and I'm now looking at rebuilding the 29er wheel.
Should I reuse the old spokes, or buy new ones?
__________________
steveyo
Old 2012-02-24, 03:13 PM   #14
tholub
Totally Doable
tholub's Avatar
There's nothing inherently wrong with re-using the spokes, but they will be somewhat more likely to fail than new spokes would be. Depends on your tolerance for fixing broken spokes.
Old 2012-02-24, 03:22 PM   #15
MuniAddict
Not "2" Tired
MuniAddict's Avatar
Just like all metals that are put under stress, spokes will also be subjected to metal fatigue over time. If the are still fairly new, and were properly tensioned and kept clean and dry, they should be reusable, but the best course would be to replace them with new black stainless, double butted, brand name spokes.
__________________
My latest TV segment
UniGeezer.com
My videos
MuniAddict is offline   Reply With Quote
Reply
Tags
guni, question, wheelbuild
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Custom wheel build bungalistic Unicycle Product Reviews 2 2007-10-03 09:48 PM
Tire removal for wheel build pinefresh General Unicycling Discussions 9 2007-02-25 09:14 AM
Wheel build specs??? unichomp General Unicycling Discussions 2 2006-07-11 05:21 PM
wheel build price $174? Jose Freedman General Unicycling Discussions 13 2002-08-15 09:26 PM
how to build a wheel ? tandys General Unicycling Discussions 2 2001-05-07 10:58 AM
Copyright © 2001-2005 Gilby
Page generated in 0.09054 seconds with 10 queries
