Unicyclist Community
Go Back   Unicyclist Community > Non-unicycling Discussion > Just Conversation & Introduce Yourself
Reply
Old 2008-10-19, 12:05 AM   #1
beeper
5tr33t
beeper's Avatar
Send a message via AIM to beeper Send a message via MSN to beeper
Powdercoat over chrome?
This question is in regard to my unicycle, but could be handy in other fields, so i'm just asking here.
Is it possible to powdercoat over chrome?
I realize you can't paint it otherwise, and was just curious. I wanted to paint my nimbus frame.
__________________
)-Crankflip-'O,
beeper is offline   Reply With Quote
Old 2008-10-19, 12:12 AM   #2
Jeremy R
onceuponatimetherewasaper son
Jeremy R's Avatar
Send a message via AIM to Jeremy R
No. but is is possible to remove chrome plating with some Iron wool and time. Mastero8 wrote a great article on the fine points of doing so.
__________________
661
MountainUni
or make it a dinglespeed - saskatchewanian
Jeremy R is offline   Reply With Quote
Old 2008-10-19, 08:56 AM   #3
SkierAlex
Alex Grierson
SkierAlex's Avatar
Send a message via MSN to SkierAlex
Quote:
Actually, I've heard you can. And you can paint over it also, but I think it'd be worth atleast making it rough before hand so the paint sticks better.
I think it'd be worth searching it coz I'm pretty sure there's other topics about it.
SkierAlex is offline   Reply With Quote
Old 2008-10-19, 03:19 PM   #4
municycledotca
Registered User
municycledotca's Avatar
powder coating over chrome is done all the time with colors that are called candy coats. You can also use normal colors too. The surface does need to roughed up a bit - professional powdercoaters use an acid to etch the surface so that the paint bonds better.
__________________
UDC Canada
www.municycle.ca
1 866 686 4292
municycledotca is offline   Reply With Quote
Old 2008-10-19, 08:22 PM   #5
kington99
Registered User
Send a message via MSN to kington99
yes painting/PCing over chrome is certainly used professionally in certain areas. The surface does need to be rough, painting over polished chrome will fall off quickly. A little work with some fine sandpaper will sort it. You need to bear in mind that ou are now painting chromium, rather than steel or whatever the base metal is, and your choice of paint needs to reflect this.
__________________
Dave
- what a thoroughly post-modern subversion of the cycling genre -
kington99 is offline   Reply With Quote
Old 2008-11-01, 03:13 AM   #6
tabler1010
albert
what is powder coating i know it a way of painting but how is it done
tabler1010 is offline   Reply With Quote
Old 2008-11-01, 06:11 AM   #7
saskatchewanian
ERIC P
saskatchewanian's Avatar
Send a message via MSN to saskatchewanian Send a message via Skype™ to saskatchewanian
Powder-coating is a way of "painting" something. It uses a dry powder instead of a liquid paint. Usually the use electrolyses to get the powder to stick then heat the object up to melt the powder into a film that covers the object. The result is usually much more durable than a conventionally painted surface.
saskatchewanian is offline   Reply With Quote
Old 2008-11-01, 02:00 PM   #8
ntappin
Ask me about the Ottawa unicyclists
ntappin's Avatar
Send a message via MSN to ntappin
For spray painting I always recommend to leave the chrome on, so that if it gets chipped you will still have a protective layer of chrome.
You are wanting to powdercoat which will be a tougher material but it may be worth leaving the chrome and doing a thinner layer of powdercoat.
ntappin is offline   Reply With Quote
Old 2008-11-01, 04:52 PM   #9
saskatchewanian
ERIC P
My powder-coated Yuni Muni frame just survived another truck getting totaled off with some cosmetic damage.
There are now a few patches where the powder coat was rubbed off and it looks to me like the chrome that was under it is either gone or pitted/textured.
I was sort of curious if they just powder-coated over the chrome or removed it some how. I guess I will wait and see if it rusts at all in the exposed areas to tell me if it is bare steel or just textured chrome.
Old 2008-11-24, 04:07 AM   #10
AutocyclePC
Registered User
Hello, We are the powder coating shop that coated the Red, White & Blue Coker frames for RTL 2008. Chrome can be powder coated over usually without having to be removed. The exception is if the it was a poor plating job and the chrome is already peeling off or it tries to bubble or peel at the curing temperature for the powder coat. Candie colors can be applied right over the chrome without any etching or scuffing for an awesome effect. If opaque colors are being used then the surface can be media blasted to etch the surface for even better adhesion. Hope this helps.
Here are some pics of the frames at our shop before they were assembled for RTL. These were a custom fade of candy blue and red over a pearl white with a Starlight Clear.
Jason
AutocyclePC is offline   Reply With Quote
Old 2008-11-27, 08:10 AM   #11
feel the light
level 1 fat guy
excellent post auto
If I understand you correctly, only high quality chrome can be powder coated over. Makes sense to me, how could a powder paint job on top of peeling or pitted chrome get to tight metal so it can last ?
I have a chromed radial 360 that's showing a bit of rust. I really should wax it, retroactively, for the last year.
So , for chrome, is it wax and wait ? Then if you are lazy like me and the chrome goes all dodgy, it will need a sand blast to clean steel to get a good powder coat ?
feel the light is offline   Reply With Quote
Old 2008-12-01, 04:50 AM   #12
AutocyclePC
Registered User
Quote:
Your correct for a good quality powder coating job it will only be as good as the substrate it is applied over.
I have a chromed radial 360 that's showing a bit of rust. I really should wax it, retroactively, for the last year. LOL we all wish we cold have done that before.
So , for chrome, is it wax and wait ? Then if you are lazy like me and the chrome goes all dodgy, it will need a sand blast to clean steel to get a good powder coat ? If I have a part with questionable chrome I will put it in the oven and run it through a cure cycle to see how the chrome holds up if it does well then we media blast it and coat it if needed. A good chrome plating can be clear coated with clear powder so the rust then becomes a non issue.
Hope that helps.
Jason
Old 2008-12-02, 02:57 AM   #13
Jethro
Bill Hugo
Jethro's Avatar
Send a message via AIM to Jethro
We just did this this weekend. My brother-in-law is a Harley Davidson mechanic in Iowa and does the powdercoating on their aftermarket stuff. A lot of it is chrome. He powdercoated a chrome trials frame for one of my sons and it turned our great. I will post pictures soon.
You should know that powder coating over chrome will produce a completely different color than powdercoating raw metals.
__________________
New Blog:Unicycle Nation
What difference does it make to the dead, the orphans, and the homeless, whether the mad destruction is wrought under the name of totalitarianism or the holy name of liberty or democracy? ~Mahatma Gandhi
Jethro is offline   Reply With Quote
Reply
Tags
chrome, powdercoat, unicycle
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Powdercoat assitance... shadowuni General Unicycling Discussions 6 2004-12-31 06:59 PM
DIY powdercoat digitalattrition General Unicycling Discussions 21 2004-09-12 05:43 AM
PowderCoat :D joe General Unicycling Discussions 9 2003-06-15 05:18 PM
PowderCoat? oftenbirder Üamyoftenbird General Unicycling Discussions 0 2001-04-30 05:51 AM
Copyright © 2001-2005 Gilby
You Rated this Thread:
Page generated in 0.10868 seconds with 10 queries
