Unicyclist Community
Reply
Old 2008-08-26, 04:11 PM   #1
unicyclerperson
Registered User
unicyclerperson's Avatar
Question removing cranks that have their threads wrecked?
Yesterday I got new 5 inch cranks, an upgrade to my sixes but one of my sixes' threads are all screwed up so I can't get the crank puller on. Does anyone know how to get the crank off?
(p.s. I bent my frame using a crowbar, not severely though)
unicyclerperson is offline   Reply With Quote
Old 2008-08-26, 04:23 PM   #2
kington99
Registered User
Send a message via MSN to kington99
you need to use a gearpuller, which has two or three legs which grab behind the crank and presses with a bolt on the end of the hub. I think UDC sells them for profile cranks, or your LBS will no doubt have one for shifting cranks.
__________________
Dave
- what a thoroughly post-modern subversion of the cycling genre -
kington99 is offline   Reply With Quote
Old 2008-08-26, 04:29 PM   #3
unicyclerperson
Registered User
thanks, I'm new to the forums so UDC means...? Thanks
Old 2008-08-26, 04:32 PM   #4
agentQ
Sam Haber
agentQ's Avatar
Send a message via AIM to agentQ Send a message via MSN to agentQ
Quote:
Unicycle.com
Welcome.
__________________
Uneed Films
Whats up with Street and Flat?
the Unicycle Lab
agentQ is offline   Reply With Quote
Old 2008-08-26, 04:34 PM   #5
Nicf
going to learn standwalk^^
Nicf's Avatar
udc = unicycle dot com
Check this out too
Edit: dam you agent Q
Nicf is offline   Reply With Quote
Reply
Tags
cranks, removing, threads, wrecked
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Anyone else have water spray problems on their geared 29er? peter.bier General Unicycling Discussions 12 2008-08-01 11:08 AM
Removing cranks Pembar General Unicycling Discussions 4 2008-05-07 07:12 AM
removing cranks, no puller duncan General Unicycling Discussions 12 2004-06-03 07:03 AM
removing cranks but not pedals ubersquish General Unicycling Discussions 2 2003-10-31 02:02 PM
Maintenance - removing cranks nbrazzi General Unicycling Discussions 10 2002-07-05 09:00 PM
Copyright © 2001-2005 Gilby
Page generated in 0.07297 seconds with 10 queries
