#46 | |
Registered User
Quote:
__________________
Dave - what a thoroughly post-modern subversion of the cycling genre - |
#47 | |
Roland Hope School of Unicycling
Quote:
http://www.prosportuk.com/images/ind...%20kites/4.jpg The reasons it would not fly were twofold: the weather was gusty with heavy rain clouds following a stormy day with more bad weather to come; and I hadn't flown it before so I needed to adjust the bridle. I've had a Conyne before - in fact it crashed into a tree a week or so ago. That was also either perfect or totally rebellious.
__________________
"I try to avoid UPDs, not do scientific research on them." Bruce Dawson |
#48 | |
Quote:
Edit: the post immediately below was posted simultaneously and refers to the same incident.
__________________
"I try to avoid UPDs, not do scientific research on them." Bruce Dawson Last edited by Mikefule; 2008-09-06 at 09:58 PM. |
#49 |
Scott
But if that ends up like that big inflatable structure that flew away while it was full of people a little while ago... that wouldn't be so good.
dam you beat me to it.
__________________
This is no longer a blank signature, that is all Last edited by 1-wheeled-grape; 2008-09-06 at 09:59 PM. |
#50 |
Ride hard; Stay young
I used to make kites. Now I repair them, mostly large LEI and SLE type kites, but I do a few foil kites too. I like to fly them more than repair them!!!
I fly the Cabrinha Switchblade 3: 8, 10, 12 & 14 currently, after owning many quivers of various brands, and flying my own creations also. Currently looking at replacing the current quiver with the Cabrinha Xbow's. Would have been out today, but I broke my finger attempting and old geezer trying to show up the you bucks aerial handlepass last Saturday --- so I opted for a great long Muni sesh instead. Been into kiting since 1999 when I gave up the polesurfing for kiting, on the spot in Maui, when some dude came flying by me doing a multi-spin at Kanaha. I'd seen Corey kiting in the Gorge in the '90's, after spending many, many summers there, but it never caught me as something to look at as on option to windsurfing. Uni rocks, but kiting does too. IMO, uni will NEVER be super popular, because the learning curve for the average person is way to flat, whereas kiting the learning curve is very steep, even in comparison to something windsurfing which takes many hours to learn the basics like waterstart and gybe. Kiting has far more range for creativity (like uni) vs windsurfing. So, you end up at the beach with no wind, pull out the uni and make it a great day. Heading for Boracay, Philippines for November kiting to hook up with the troop I met in Venezuela last year. Last edited by IUni; 2008-09-10 at 01:17 AM. |
#51 |
Well, last time I took the kites out there was virtually no wind, but the big red delta kite went up and took all the line I could give it. Nothing else in the bag would fly. Not even when I took it out of the bag.
Today, it was gusty. Very little wind at ground level, but too much from 10 or 20 metres up. Nothing would fly completely reliably except, you've guessed it: the red delta. Stick with this: The kites I tried were: Winged square box: 11 spars, 2 cells, 10 flat surfaces. Square box: 10 spars, 2 cells, 8 flat surfaces Hexagonal winged box: 9 spars, 12 cells, 42 flat surfaces (?) This one flew pretty weel, but eventually crashed. Conyne, 4 spars, 2 cells, 8 flat surfaces Cody: 8 spars, several battens, 4 cells, 22 flat surfaces Keeled Delta: 5 spars, 0 cells, 2 flat surfaces. The delta is far and away the simplest, easiest to construct, and flies best in all weather. Yet it is the newest design of all. (Perhaps not newer than the hexbox as that is a "show" kite.) What I find interesting is that the various other kites were the product of extensive research to produce a practical and reliable lifting kite, yet all the time, the answer was so much simpler: just make a triangle with enough sticks to hold it in shape! Is there a comparison her to the various early designs of pedal cycle, none of which had the elegant simplicity of the unicycle?
__________________
#52 | |
Registered User
Quote:
Why choose 1 wheel over two? and power/traction kites over box kites? Its more fun, more exciting, gives you a feeling like no other........ the list goes on and on.
__________________
Marcus Collings *)---' my pure trials vid , 1mHighJump*my Year in vid learning 180 or 360 unispins? watch my unispin tutorial Want to glide? watch my ww tutorial |
#53 | |
Year of the Tiger
Quote:
This past friday the weather report was so bad that the schools were cancelled all over the state. Many state workers were told to stay home. Were talking a cold front with high winds and rain. A Friend called and said let's go kiting. I said, mmmmkay. The temperture drop nearly 4 degrees to 68*f and it was raining off and on. I still didn't need a wet suit. . Because the winds were blowing from the west instead of the usual NW, we got to kite on a southern beach. It was my 1st time at this location which made it more exciting for me.I had a guy launch my kite into the air and it drag me 100 feet between a picnic table and a big tree. (made me think of that guy in florida that got yank in the parking lot). It was like grass skiing and once I got the kite straight up I was okay. A guy I hardly know yelled at me to bring the kite back down. I said' 'no way!, just get me my board". (Which was lying on the beach too far up wind). I hopped on the 5 foot board with 4 back fins and took off to sea.It was whipping! I was on my Naish Helix 9 meter kite and was fully powered. I'm guessing 30+ winds. I surfed and paddled here several times but never kite so I start exploring. I wanted to go to the sand bar. When I got there it was low tide and I flew off the board when my fins hit. I'm still okay but I have to walk the kite 50 yards to get off the sand bar. Now I'm in the shoreline channel and skirt my way back out to sea. I don't like to be close to land when it's super windy. But I'm still make it without a hitch. Half of the kiters(maybe 5 or 6) are still sitting on the beach afraid to go out. And I don't blame them. I'm out here; I'm going to have fun. Caught a few waves and dodge a few coral heads. Once I felt dialed in I start to get some air. Big air! I boosted some jumps with over 5 second hang times. I was going scary high and scary far(30+ meters in distance or 100+ feet). It took very little effort to lift off the water.After an hour out on the water, I started to get tired. But there was no going back to the beach because the winds were too strong. Then I decided to go out to the deep blue sea off the point(where dog the Bounty hunter lives ). There was ''bus size'' wave swells generated by the winds. Finally there was a lull in the winds so I headed back to the beach where my friend helped me safely land my kite.Very intense, quite epic.
__________________
MUni! The closest I'll ever get to bull riding! Last edited by critter; 2009-01-18 at 02:30 AM. Reason: grammar |
#54 |
Year of the Tiger
Powered by a kite.
Here's 3 guys in a four-man canoe at hawaii kai bay.
See the guy in back steering with the paddle. Me, in the middle holding a 9-meter kite. Front guy taking the picture. It was fun!
__________________
MUni! The closest I'll ever get to bull riding! Last edited by critter; 2009-05-05 at 03:47 AM. |
#55 |
Surf the Turf
Shell Island? Hey Cath! not the Shell Island where I live in Gwynedd?? That is, the Shell Island that is on the coast near Barmouth, very close to Harlech? Is that the one or is there another Shell Island?
#56 | |
Surf the Turf
Quote:
#57 |
Registered User
Wow!! I am really missing out here! I've never flown a kite before..
This summer, it is my mission to purchase and fly a kite down by da beach mmboi!! This WAS a nice thread
__________________
I hear and I forget. I see and I remember. I do and I understand. God don't make no mistakes Practice Practice Practice myspace.com/roosterclaw |
#58 |
Ask me about the Ottawa unicyclists
One of my friends just went to Hateras, North Carolina to go kite surfing, now those are kites!!
__________________
how to build a strong comfy saddle from junk. |
#59 | |
Year of the Tiger
Quote:
![]() I tried hooking the kite bar to the canoe but it was too hard to steer. And no shock absorber, the strings could break because of the weight of the boat and crew. edit: The picture was a print that got ruin.(bottom left corner). I scanned what's left of it.
__________________
MUni! The closest I'll ever get to bull riding! Last edited by critter; 2009-05-06 at 02:18 AM. |
#60 | |
Quote:
Shell Island? Mocras? (SP?) The island you can only get to via the causeway at low tide? We used to go camping there in the early 1970s. My dad and I used to collect winkles then cook and eat them back at the tent. There was a storm there one alleged summer, and we used the tow rope from the car to secure the tent. That Shell Island? Never heard of it.
__________________
| Tags |
| kites, wurst |
Similar Threads
| Uphill anyone? | abm429 | Unicycling Articles and Tutorials | 7 | 2008-03-08 03:35 AM |
| Anyone broke this? | The UniSLAB | General Unicycling Discussions | 12 | 2008-02-02 04:24 PM |
| Anyone In FBLA??? | UniDudeDX | Just Conversation & Introduce Yourself | 1 | 2008-01-09 06:50 PM |
| Sullivan anyone? | vivalargo | General Unicycling Discussions | 4 | 2007-09-02 02:39 AM |
| volvo anyone? | gabetheunicycleman | Just Conversation & Introduce Yourself | 17 | 2007-08-02 12:29 PM |
