Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
Colby Thomas
my pedal snapped, possible striped crank-help
Hey everyone,
today my pedal snapped so I went to replace my pedals, but upon taking off the snapped pedal, I stripped part of the cranks, in other words, some of the crank peeled off and was left on my pedal. The result is my cranks is now 1/3 stripped, is this anything to worry about?
__________________
COLBY THOM BROS
#2 | |
going to learn standwalk^^
Quote:
#3 |
Live life for yourself, no other.
Yes.
__________________
[B]Take a look at the bigger picture, we're all mere holograms.
#4 |
Colby Thomas
no, seriously, is it anything to worry about?
__________________
COLBY THOM BROS
#5 |
yes well if they still hold then not much but get the KH cranks
ohh and just to be ahead of the curve get the 137mm |
#6 |
UniDC
if all you did was take some of the coating off the crank then your fine. (do people really need to mention that someone should upgrade to khm's)
__________________
Last edited by SixSixOne : Youtube-ay at Vim:eo PM. Belle Isle Richmond, VA (Comp Thread) -David |
#7 |
Colby Thomas
I talking about the threads that wrap around on the crank, about 2 of the O's on the crank got striped off
__________________
COLBY THOM BROS
#8 | |
UniDC
Quote:
__________________
#9 |
Colby Thomas
That part of the reason I am not getting KH's, because I risk stripping and breaking them. essentially a wasted 85 bucks. Theses standard ones do fine. I'm only 100 pounds
__________________
COLBY THOM BROS
#10 | |
is in college. and on magazines.
Quote:
You're talking about the threads where the crank attaches to the axle, that you use with a crank puller right?
__________________
[SIGPIC][/SIGPIC] |
#11 |
jumps stuff
no, i think he's talking where the pedal screws in, if so, it shouldn't be too much of a problem as long as the wheel is on straight and everything...
what kind of uni do you ride? KH cranks might not even fit on it.
__________________
><> Unicycle For Christ <>< MY VIDEOS World Record 94cm Highest Hop (rolling) 308cm Longest Hop (10 feet) 210cm Static Flat Gap |
#12 |
he rides a nimbus trials
#13 |
level 1 fat guy
It is not a steel insert crank
I can tell by the description of how "threads were left on the pedal ".
So we have an alum crank, with only 1/3 the pedal threads gone ! The crank is 2/3 's good ! LOL Really, I think that the remaining threads are full of cracks and ready to go as well, what was so special about that first 1/3 that broke ? Perhaps another pedal can be reinserted with JB Weld (epoxy goo), and might go years in mild street use. I have seen it happen. But as a "pedal snapper", only new cranks will work for you .
#14 | |
Why me?
Location: Rocky Mountain HIIIIIIIIIIIGH!! Co-lo-ra-do......
Quote:
#15 |
meh.
I stripped one O off my DX crank a while back, I put the pedal back in but every day I have to retighten it, worry about it on every drop I take, and it's never as tight as it could be.
And that's' only half as bad as yours, TECHNICALLY it still works, but It'd really be better to have a better crank. You got lucky 'cause ISIS cranks are abundant, 10 spline cranks aren't.
__________________
To be alive at all is to have scars. |
| Tags |
| crankhelp, pedal, snapped, striped |
Similar Threads
| i still need pedal help!!!! | warlord14 | General Unicycling Discussions | 1 | 2008-04-18 03:17 AM |
| i need pedal help!!!! | warlord14 | General Unicycling Discussions | 6 | 2008-04-15 11:54 PM |
| Where do you guys buy pallets???? And is my pedal/crank stripped????? | _Ground_Zero_ | General Unicycling Discussions | 23 | 2007-10-07 07:42 AM |
| Help my friend please! | Roamus | General Unicycling Discussions | 17 | 2007-09-28 01:38 PM |
| Striped thread on Miyata frame | ThisGuyIKnow | General Unicycling Discussions | 2 | 2005-09-28 09:20 AM |
