Unicyclist Community
Reply
Old 2008-07-19, 07:31 PM   #1
1-wheeled-grape
Scott
1-wheeled-grape's Avatar
Send a message via MSN to 1-wheeled-grape
Help with Magura brake questions
I've been given this brake free from my technology teacher at school along with two spare brake cylinders, 3 brackets for bikes, a spare lever and some really worn pads.
-Unfortunately the handle pump piece has broken and there is no longer any way of attaching it to the handle. Does anyone know where I can get a new one cheep?
-Also what type of brake is it because it doesn't look like the HS33?
-I know I need to get some new brackets, but do I need the tensile ones with a DX32 rim, or can I use the ones supplied with KH24s?
-Also what type of brake fluid does it take because I need to refill it?
-Are there any recommendations for new brake pads too?
Thanks!
__________________
This is no longer a blank signature, that is all
1-wheeled-grape is offline   Reply With Quote
Old 2008-07-19, 07:47 PM   #2
sp4rky-m4rky
Registered User
sp4rky-m4rky's Avatar
Send a message via MSN to sp4rky-m4rky
I dont know all that much about them but it looks like a HS33 to me. Fill it with water. Its cheaper easier and makes for a lighter feeling brake.
Looks like the leaver is pretty knakered, have a look on chain or tarty, I think new leavers are normaly about £30.
__________________
Marcus Collings
*)---', 1mHighJump*
my pure trials vid
my Year in vid
learning 180 or 360 unispins? watch my unispin tutorial
Want to glide? watch my ww tutorial
sp4rky-m4rky is offline   Reply With Quote
Old 2008-07-19, 08:12 PM   #3
1-wheeled-grape
Scott
No I've just looked there and they're £40-£50! Bit out of budget at the moment. The handles look different though. I think I'll have a go at making something to repair it instead. I'm still not sure about the brackets though can I use these or do I need these?
__________________
Old 2008-07-19, 08:48 PM   #4
sp4rky-m4rky
Registered User
Quote:
They are basicly the same but one set is branded and therefore alot more expensive.
Try bleeding your lines with water, if they work, fix the leaver. If they dont, consider buying a new set. Check ebay or go for the HS11 which I think are £35. Im running a HS11 on my 29er and its perfectly adequate.
__________________
Marcus Collings
*)---', 1mHighJump*
my pure trials vid
my Year in vid
Old 2008-07-19, 08:51 PM   #5
1-wheeled-grape
Scott
That's the one I've got HS11! the handle for that is £20, a bit better!
__________________
Old 2008-07-19, 09:15 PM   #6
kington99
Registered User
Send a message via MSN to kington99
i've bought two operational sets of maguras on ebay for £11 each in the past, this will be your best source for a new handle body. Yours does look like an HS33 to me, an 05 series. The brackets that came with KH24 are fine, the tensiles are for if you're running a monster rim like the Surly Large Marge 64mm. Khs used to use DX32 rims and used the same brackets as they do now.
As for fluid, the reccomended is Magua Blue Blood, this costs £2.50 for a bottle for one bleed, but you'll need a bleed kit which are expensive. I've never done water but a lot of trials riders do, and you can just take the plugs out and submerge the entire gear to get all the bubbles out, with no need for special equipment.
__________________
Dave
- what a thoroughly post-modern subversion of the cycling genre -
kington99 is offline   Reply With Quote
Old 2008-07-19, 09:18 PM   #7
1-wheeled-grape
Scott
Oh right, I'll go with the water option. I will bodge-job this handle and get another handle body after, I have a spare lever for one any way.
__________________
Old 2008-07-19, 09:25 PM   #8
kington99
Registered User
nice set on ebay atm for 99p, and cheap postage!
__________________
Dave
Old 2008-07-19, 09:26 PM   #9
1-wheeled-grape
Scott
Yeah I'm watching them now. Might get them, I have loads of spares then
__________________
Old 2008-07-20, 09:08 AM   #10
Fraggle
Registered User
Fraggle's Avatar
Quote:
Originally Posted by kington99
1-wheeled-grape, depending on how the above set goes, I might be able to locate a HS33 lever body for you. I don't see why they wouldn't be compatable. Let me know, I'll see what I can do.
Supposed to use Magura brake fluid, but as it's a tad over priced, I use distilled water, the lack of oxygen makes for a more solid brake rather than the softer brake that you'd get from using plain water. I'd advise bleeding the system through with oil occasionaly, just to keep the rubber seals in good nick.
F.
Heh, just noticed my post count is twice the number of my age, lol.
Fraggle is offline   Reply With Quote
Old 2008-07-20, 09:13 AM   #11
1-wheeled-grape
Scott
Oh awesome thanks! I'll PM you if I do.
__________________
Old 2008-07-20, 09:17 AM   #12
Fraggle
Registered User
Fraggle's Avatar
Thats cool. I swapped a BMX frame with a mate for a HS33 with braided hose, to go on my uni. I'm sure there's a few more HS33 bits knocking about round his place.
F.
Old 2008-07-20, 09:37 AM   #13
Fraggle
Registered User
Fraggle's Avatar
I'd go with a set of them, unless you have a huge rim on your uni.. I got the full HS33 Evo kit, so I have the grey mounts in the Evo2 pic in the link below. These aren't offset, and work fine, I have the QU-AX Alunimium frame, with a 45mm rim.
http://www.magura.com/7thsenseCMS/in...?id=12005&L=1#
F.
Old 2008-07-20, 10:17 AM   #14
1-wheeled-grape
Scott
Oh thats ok, my friend got a set with his KH24 and he said I could have them for £8, which is ok.
__________________
Old 2008-07-20, 11:10 AM   #15
kington99
Registered User
what uni are you mounting them on?
__________________
Dave
Reply
Tags
brake, magura, questions
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
magura/KH brake mod cline General Unicycling Discussions 3 2004-09-30 04:30 AM
Magura brake mod unicus General Unicycling Discussions 5 2004-09-21 05:11 PM
Magura brake setup questions xtremeskier_ General Unicycling Discussions 5 2004-07-28 09:23 PM
Magura brake help,please forget_your_life General Unicycling Discussions 11 2004-04-08 05:48 AM
Magura Brake David Poznanter General Unicycling Discussions 2 1999-12-07 06:24 PM
Copyright © 2001-2005 Gilby
Page generated in 0.09331 seconds with 11 queries
