Unicyclist Community
Reply
Old 2007-07-21, 10:32 PM   #1
Det-riot
I unicycle?!
Det-riot's Avatar
Puller needed for K1 Street Cranks?
Is a puller needed for k1 isis street cranks, because my right one just pops off if i unscrew the bolt, but the left bolt wont even turn, so i don't know if it will come off as easily as the right one.
__________________
Quote:
Originally Posted by Jerrick
I think we should get off the topic off kinky/horny girls and unicycles, and back to creepy horny men.
Quote:
Originally Posted by Into the blue
GILD, did you have clothes on when you spoke to me on the phone?
MRIS!!!!
3,000th post!
Det-riot is offline   Reply With Quote
Old 2007-07-22, 12:27 AM   #2
feel the light
level 1 fat guy
I have never worked on a Koxx
The cranks on my KH were greased at the factory and slide off the splines easy once the allen bolt is loose. I am pretty sure all splined cranks are the same, as opposed to the taper on square axles that gets wedged on. So take the bolt off and tug away ! Both side should be the same.
feel the light is offline   Reply With Quote
Old 2007-07-22, 12:28 AM   #3
feel the light
level 1 fat guy
The left side crank bolt is not left threaded
That's just for pedals.
Old 2007-07-22, 12:48 AM   #4
oneisenough
Trialstreet Rider
oneisenough's Avatar
if it has puller threads than it probably needs a puller.<-- at least from my expierience.
oneisenough is offline   Reply With Quote
Old 2007-07-22, 01:16 AM   #5
Spencer Hochberg
Send a message via AIM to Spencer Hochberg Send a message via MSN to Spencer Hochberg
Quote:
ISIS cranks taper on the axle. When Cody had street cranks they had that black ring in the crank on the outside of the bolt so it made it self extracting, as you unscrew the bolt it cant come out so it pushes against the axle and it pulls it off.
The trial k1 cranks do need a crank puller.
Spencer Hochberg is offline   Reply With Quote
Old 2007-07-22, 02:25 AM   #6
feel the light
level 1 fat guy
OK, I'm likely wrong
I rotated the cranks on my 05 KH24 , to even out the tire wear. It is non ISIS splined, and I'm pretty sure it had no taper. I assumed my 07 KH20 would be the same. Tire's still good on the 20, so I never looked.
Old 2007-07-22, 02:29 AM   #7
Spencer Hochberg
Yeah the kh/onza cranks don't taper on the axle, you just need to tighten it against something.
I like these for flatland crank tricks because you can put extra spacers on the axle and get more room for your foot, with ISIS cranks you can't have the cranks any farther out.
Old 2007-07-22, 07:46 AM   #8
Blegas78
ichirinsha-ist
Blegas78's Avatar
Send a message via AIM to Blegas78
Quote:
Yeah, that sucks for roll tricks. Just wait for my mod cranks though
__________________
Nothing is better than than eternal happiness, and a ham sandwich is better than nothing, therefore a ham sandwich is better than eternal happiness.
"Rock Out Loud Yo!" -kid from Paper Bag Over the Head advertisement
Blegas78 is offline   Reply With Quote
Old 2007-07-22, 07:54 AM   #9
wendino
municycle.com
wendino's Avatar
Hi,
the self extracting does not work becuase the bolt are too short and loose the contact to the axle thread before the crank is getting loose
A normal crank extractor will not fit because the threads in the cranks are not clockwise ...
You have to use a bearing puller. I think it is easier to remove cranks and bearings together.
Cheers
Roland
wendino is offline   Reply With Quote
Reply
Tags
cranks, needed, puller, street
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
K1 v KH jo3 Unicycle Product Reviews 76 2007-07-31 07:28 PM
UK Street Riders Needed milk General Unicycling Discussions 31 2006-12-21 07:21 PM
Removing cranks without a crank puller? unisteez General Unicycling Discussions 10 2006-05-05 04:08 PM
removing cranks, no puller duncan General Unicycling Discussions 12 2004-06-03 07:03 AM
Stump-puller cranks hbaker1@pipeline.com General Unicycling Discussions 3 2003-04-06 02:43 PM
Copyright © 2001-2005 Gilby
Page generated in 0.07893 seconds with 10 queries
