Unicyclist Community
Reply
Old 2007-04-05, 02:37 AM   #16
Hazmat
Too insane to be considered human.
Hazmat's Avatar
I'm just curious but have you tried HUFFY Mountain bikes brakes?? . One of my friends unicycle brakes are taken from those.
__________________
I'm 1 weird and unusual Greek Cypriot Australian with a pienormous heart.
Can't wait till this game is finally released.
Hazmat is offline   Reply With Quote
Old 2007-04-05, 04:51 AM   #17
pkittle
NorCal Riding Project
pkittle's Avatar
Quote:
Originally Posted by joemarshall
Do HS11s work on unicycles?
Yes. A friend has HS11s on his muni.
Another place to look for maguras is craigslist and the for sale section of the observedtrials.net fora.
__________________
Peter Kittle * Chico, CA
"The Revolution is just a t-shirt away."
--Billy Bragg
pkittle is offline   Reply With Quote
Old 2007-04-05, 06:02 AM   #18
GhettoSmurf
Registered User
Send a message via AIM to GhettoSmurf
there is a company that makes a V-brake without a noodle
(jaguar I think)that should fit.
I think a pair of Shimano XT or XTR or Avid arch rival breaks with the parralelagram would work well, because the pad would hit simalar to maguras
GhettoSmurf is offline   Reply With Quote
Old 2007-04-05, 09:16 AM   #19
Unicorn
Registered User
Unicorn's Avatar
V-Brake Pictures and Info.
Hi Everyone!
I took the time to take osme pictures of my V-Brake settup with the Mission 4Bolt Magura adaptors. the picture are however to large to upload. I will email thm to anyone who sends me thier email in a private mesage.
Some extra info. I now have the V-Brakes mounted on my KH29 with a 2.1" kenda Klaw tire. I previously had Shimano V-brakes mounted on my Onza 24" with a 3" Duro tire. I dismounted the brake from my Onza because I just never used it. On the KH29 I use it only when going down huge hills.
Unicorn
__________________
Keep your eyes on the stars and your feet on the pedals, and you will accomplish great feats!
The Unicycling Commune
Unicorn is offline   Reply With Quote
Old 2007-04-06, 04:57 AM   #20
pkittle
pkittle's Avatar
On eBay right now, there's a guy selling NOS (new old-stock) magura master cylinders (the brake handle part) for $15, and slave cylinders (the parts that hold the brake pads) for $5 each. That's $25 for a whole wheel; you need to add only hose and oil and pads, and maybe a couple little parts like olives. Cheap and easy.
__________________
--Billy Bragg
Old 2007-04-06, 12:16 PM   #21
Carey
One up.
I am holding out for a cable brake solution. Don't want to mess with hydraulics. My son has them on his MTB and I like the cable set-up on my own MTB much better. Cheap, reliable, easy to fix and highly available parts.
Carey
Carey is offline   Reply With Quote
Old 2007-04-06, 03:14 PM   #22
Hazmat
Hazmat's Avatar
Quote:
Carey
Well why not find a spare MTB brakes set and attach it to your uni. There's of course the custom made option too. It shouldn't cost too much i don't think.
__________________
Old 2007-04-06, 04:34 PM   #23
Carey
One up.
V-brake
That's my plan. Unicorn put me onto those Magura adapters out of the UK that will allow a v-brake installation...have a set enroute now. Once I get them, I plan to put on a v-brake with the tallest arms I can find for tire clearance. Hoping it works out.
Carey
Old 2007-04-06, 06:23 PM   #24
henque19
No pain, no gain!
Send a message via MSN to henque19
This is what i've done, works great!
Dunno what the type is called, but i had a break-set lying around at home. So I just drilled a hole in the frame and it was done.. piece o' cace, pretty much for free..
henque19 is offline   Reply With Quote
Old 2007-04-06, 11:05 PM   #25
Carey
One up.
Brake
Nice job! Looks like you solved the problem at minimum cost and effort.
Carey
Old 2007-04-06, 11:13 PM   #26
joemarshall
dumb blonde
What size tyre is that? It's either a relatively narrow tyre, or you've found a fantastically big caliper brake (which would be great).
Joe
joemarshall is offline   Reply With Quote
Old 2007-04-07, 10:23 PM   #27
henque19
No pain, no gain!
Joe
Its a 29x2.1" IRC Notos. Not too wide, but it should fit my newly ordered Panaracer Rampage tyre, yum!!!
Old 2007-04-08, 09:05 AM   #28
Unicorn
Registered User
Unicorn's Avatar
Nice Job!
Henque19 did a nice job putting his V-Brakes on. However he had to drill the frame of his Unicycle to do so. I am not a machinist and I don't have a machine shop. I would advice against drilling a hole in you Unicycle frame. If the hole is not totally in a strait line with the wheel then the pads will rub the rim at an angle. Also I don't know the efects of drilling a hole on the strength of a MUni frame where strenth is of the utmost importance.
I am all for adding stuff to your unicycle.
I am not for making changes to the stock frame.
Unicorn
__________________
Old 2007-04-08, 09:12 AM   #29
Brian O.
Team Spencer Photographer
Brian O.'s Avatar
Those aren't V-Brakes in the picture and you certainly don't need a machine shop to drill a hole in the frame. As long as the hole is relatively level it should work just fine, and many drills have a level built right in. One single hole on that type of frame, especially where that hole is put certainly won't effect the strength of the frame. I'm not trying to say there are no risks involved but it's a bit easier than you make it sound.
Unicorn
__________________
Get cool unicycle posters, pins and more! All products are my personal photography. * New Poster 11/16/2010 *
Brian O. is offline   Reply With Quote
Old 2007-04-08, 09:16 AM   #30
henque19
No pain, no gain!
Unicorn
First of all, its not a v-brake. Those are attached in a similar way as maguras onto the side of the frame. If you have magura fittings on your frame, I think you can buy some kind of adaptor from unicycle.co.uk to fit v-brakes.
Second. It was no problem drilling a straight hole. I used a simple but strong hand-held drill and the hole is failrly straight. Doesn't matter too much if the hole is straight or not. It might even be bettter if its leaning a bit, more breaking area. I also don't think that the hole affects durability. I wouldn't do it on an aluminium frame, but as long as the hole is as far down as possible where the strain is minimum it souldn't compromise durability
Reply
Tags
brake, cost, lower, option
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Lower back pain - is it just me? patmoore General Unicycling Discussions 21 2006-08-06 04:46 PM
Lower Back Protector Pad teachndad General Unicycling Discussions 2 2004-07-13 09:40 PM
lower abdominal muscle damage onewheeldave General Unicycling Discussions 3 2003-07-22 12:48 AM
why a lower saddle is more tiring, especially on climbs Klaas Bil General Unicycling Discussions 4 2003-03-25 11:58 PM
ouch, my lower back teachndad Unicycle Product Reviews 2 2002-12-30 03:28 PM
Copyright © 2001-2005 Gilby
Page generated in 0.10777 seconds with 11 queries
