Unicyclist Community
Reply
Old 2006-10-31, 11:02 PM   #1
David H
Twice The Man To Ride Half The Bike
David H's Avatar
Qu-Ax Beginners Trials Unicycle???
I've been unicycling for a while now and have decided it's time to start trials unicycling.
I don't have much to spend and am thinking of getting the new quax beginners trials unicycle.
Can anyone suggest something different or write your opinions of the qu-ax.
P.S. I won't be doing extreme trials (only small things).
Thanks
__________________
My Gallery: To View My Gallery, Click Here.
Need somewhere to ride with other unicyclists:
Stockton Unicycle and Juggling Club
David H is offline   Reply With Quote
Old 2006-10-31, 11:04 PM   #2
David H
David H's Avatar
...Another option would be the nimbus trials unicycle
__________________
Old 2006-11-01, 02:05 AM   #3
maximus unius
Registered User
maximus unius's Avatar
If you go with either of those, you go with the qu-ax. Only because its splined and the nimbus wont last. Only bad thing is the qu-ax there is more of a nice freestyle/street machine. If you go with qu-ax for trials, get the real trials uni with a 2.5 tire and all that. Sure, you can do trials on that one, but it will be better on the heavier duty one cause its made specificaly for trials.
maximus unius is offline   Reply With Quote
Old 2006-11-01, 02:18 AM   #4
skrobo
jumps stuff
skrobo's Avatar
Send a message via AIM to skrobo
uhmm
you could get a 2005 torker DX, i think ... www.bicyclesource.us
$200
its a little heavier, and the frame may break eventually, but it has a lifetime warranty and will be replaced
EDIT: ahh, sorry dude, they are out of them.
__________________
><> Unicycle For Christ <><
MY VIDEOS
World Record
94cm Highest Hop (rolling)
308cm Longest Hop (10 feet)
210cm Static Flat Gap
skrobo is offline   Reply With Quote
Old 2006-11-01, 03:53 AM   #5
UniTyler
Registered User
Quote:
The Quax he linked to is not splined.
UniTyler is offline   Reply With Quote
Old 2006-11-01, 04:38 AM   #6
forrestunifreak
is in college. and on magazines.
forrestunifreak's Avatar
Send a message via AIM to forrestunifreak Send a message via MSN to forrestunifreak Send a message via Skype™ to forrestunifreak
The Qu-Ax line is kind of confusing now.
Yellow hub trials: New or old, same strong 10 spline
Old red hub (cross) trials: Real trials rim and tire (19" mod trials rim and tire), square taper hub and cranks
New in 2006, red hub (cross): 20" BMX rim, ISIS splined hub (much lighter, and cranks are stronger then swuare taper, but the axle itself is hollow and not as strong as the yellow ten spline) This is the one David H linked to, it is ISISsplined.
__________________
[SIGPIC][/SIGPIC]
forrestunifreak is offline   Reply With Quote
Old 2006-11-01, 11:56 AM   #7
maximus unius
Registered User
Forrest sumed it up.
Old 2006-11-01, 12:49 PM   #8
David H
David H's Avatar
The qu'ax i was talking about isn't splined, i think i'm going to go with the nimbus because the qu'ax model doesn't have a proper trials tire or rim.
Does anyone have any thoughts about the nimbus trials uni for street riding?
__________________
Old 2006-11-01, 01:24 PM   #9
joemarshall
dumb blonde
Quote:
Yes it is. ISIS is a splined interface, so it must have splined cranks. It's the lightweight hub and cranks, so might be not way stronger than square taper though.
If you're only going to be doing small things, either will probably be fine. Having said that though, everyone I know who got a trials for only doing small stuff got bored of it and started riding muni instead.
I dunno, but it might be nice to get the qu-ax, but with the Onza Onza Sticky Fingers 20" trials tyre instead, although having said that I've got absolutely no idea as to how the 20" creepy crawler is as a trials tyre.
Your best bet though is to phone Roger at unicycle.com rather than ask on here, as he'll know what all the options are, also he probably knows what your style of riding is if you go to Stockton club.
Joe
joemarshall is offline   Reply With Quote
Old 2006-11-01, 01:41 PM   #10
Chexjc
GO RIGHT!!!!
Chexjc's Avatar
Send a message via AIM to Chexjc
just go w/ that one
__________________
Chexjc is offline   Reply With Quote
Old 2006-11-01, 02:13 PM   #11
David H
David H's Avatar
Quote:
Unicycle.com says:
Quote:
only has lightweight Isis hub and cranks, for extreme jumping look at our unicycles with splined hubs.
So is it splined or not?
I still think the nimbus will be better because unicycle.com says that it is entry level.
David.
__________________
Old 2006-11-01, 04:05 PM   #12
joemarshall
dumb blonde
Unicycle.com says:
Yep it's splined. It's a lightweight splined hub which will be not as strong as the heavier splined hubs, but may be stronger than the square taper hub on the Nimbus. Unicycle.com might know if you ask them.
Entry level means the same thing as beginner. Either of these unicycles will probably break if you do big drops.
Phone up unicycle.com, he'll tell you which of these two is best for your riding style, and you'll avoid ending up with a unicycle which is comparatively junk like the old Qu-ax you've linked in the other thread.
Joe
Old 2006-11-01, 04:12 PM   #13
David H
David H's Avatar
So what would you say about getting the 07 beginners qu-ax and a maxis creepy crawler tire? for £138?
Thanks
__________________
Old 2006-11-01, 08:42 PM   #14
maximus unius
Registered User
If you are going to be doing mainly street, leave that tire on there and try it out. Who knows, you might end up liking it.
Old 2006-11-02, 12:00 AM   #15
forrestunifreak
Thanks
A true trials tire (like the Maxxis creepy crawler) will not fit on a true 20" rim.
__________________
[SIGPIC][/SIGPIC]
Reply
Tags
beginners, quax, trials, unicycle
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Qu-Ax 20-inch Trials Unicycle vs. Nimbus Hoppley uni.rider.13 General Unicycling Discussions 11 2007-10-11 03:42 AM
Qu-Ax 20 trials blackbike Unicycle Product Reviews 31 2006-10-25 11:48 PM
Qu-ax? Goats_On_Unicycles General Unicycling Discussions 17 2006-10-21 05:42 PM
[FOR SALE] Qu-ax 36" Unicycle, barely used - UK Only sallyesq Trading Post 9 2006-08-19 09:15 PM
qu-ax seat uni man 22 General Unicycling Discussions 8 2006-07-28 07:18 PM
Copyright © 2001-2005 Gilby
Page generated in 0.09369 seconds with 10 queries
