#1 |
magic
BC trick?
I was wondering if anyone has done this on a BC,
1. roll toward object(bench would work) 2. jump off BC 3. jump over the bench while the BC goes under 4. land on BC and keep rolling I got the trick from skateboarding, has anyone done it? |
#2 |
Registered User
I have thought about it but its alot harder on a bc than a skateboard because a skateboard can fit under alot more stuff than a bc can.
#3 |
magic
I can see the problem.
Hmmm, you could build a little obstacle like this: I-----------------I I I I I I I I I I I out of 2 by 4's, buut that would take a while |
#4 |
magic
pretend the second column of I's is on the other side of the drawing
#5 |
Registered User
Yeah, I have looked at tables (they def. won't fit under benches) and most ables have a solid side or a bar that goes across the bottom.
It would also be hard to jump off it it that high without pushing it over. I can no footer pretty well and if I try to go for a huge extention it falls over really easily. The other problem is sometimes it gets turned a little bit when you jump off but if you are coming straight back down you can still land on it and correct it. If it is going 5-6' under a table then it will probably hit something. I would like to see it be done but you might have to build something special for it (enough clearance to allow the bc to go through but not huge so you have to leap off). edit: and that I am talking about a 20", with a 24" it would just cause more problems. Last edited by litldude2; 2006-06-22 at 04:11 AM. |
#6 |
Why am i here? I dont unicycle.
#7 | |
Registered User
Quote:
sorry im gonna have to agree with evan
__________________
freedom of style |
#8 |
Byronic hero
lol
__________________
[QUOTE/into the blue]Am I the only one who finds it incredibly egotistical when someone sigs themselves? [QUOTE/dan de man]yes , yes you are |
#9 | ||||
jamison, master of the straw
lol is banned
so i am gonna have to say... hahaha
__________________
Quote:
i_love_twins546@hotmail.com add me www.jakespants.blogspot.com |
#10 |
ONE WHEEL IS BETTER THAN 2
somedody has done it on uw
go down to the section about jump over pole
__________________
<><unicycle for Christ><> |
| Tags |
| trick |
Similar Threads
| What is the best trick you have ever seen? | Lucas1wheel | General Unicycling Discussions | 28 | 2007-02-19 02:43 PM |
| uni 2 uni (the trick) | daino149 | General Unicycling Discussions | 7 | 2004-04-02 05:58 AM |
| A trick! | Aaron Pelly | General Unicycling Discussions | 3 | 2003-01-07 07:33 PM |
| What's the best trick you've ever seen? | andrew_carter | General Unicycling Discussions | 35 | 2002-11-28 05:43 PM |
| Name this trick | foxx | General Unicycling Discussions | 11 | 2002-09-24 09:47 PM |
