#1 |
South Bay Uni-Sykos
"Leading with left shoulder while riding!
I know there have been similar threads about "listing" to one side while riding, with no real solution to that problem, asserting that the probelm could be with the rider and not the uni, or maybe a psi/sadle height related problem, or "dishing",etc. My problem seems related, but when I ride muni, whether on level, or uneven, high left, high right side, I always seem to be "Leading" withmy left shoulder! It's like I'm trying to compensate for a left-pull of the uni. So I experimented with seat height, and tried adjusting the seat a little left, then a little right, but still no real improvement. Then I noticed when I took off my back pack, the shoulder leading almost disappeared, but it was still there. No, my backpack is equally weighted, with no extra weight on one side. One thing I haven't tried, is "building up" the seat on one side,to help" shift my weight to a more balance position. Am I correct in thinking that if my left shoulder is Jutting forward as I ride, that I should build up the RIGHT, to force my left shoulder BACK even withmy right? Does anyone think this might help, or solve the problem? I don't know what else to try, but I HATE the extra work involved just to stay on a straight course!
__________________
Impotence: Nature's Way Of Saying "No Hard Feelings". Uni is just a cycle I'm going through. |
#2 | |
Trials and Muni Rider!
Not sure...but let me kno if the seat thinkg works...i get this sometimes to only with my right shoulder.
__________________
TRIALS 4 LIFE ! Check Out The Newbie Guide And the Spline Maintenance Guide!<UPDATED!!!With Video Quote:
#3 |
keep it wheel
i think you should try riding a different uni. if you still can't help leaning, you're the problem. if it does help, then maybe your seat post is bent? wheel isn't trued, maybe gravity just affects your right shoulder more...just throwin out some possibilities. (i've only had that problem when i was riding on unlevel terrain, never with pressure or saddle height)
__________________
hi. |
#4 |
***** Member
The problem is either mental or you need to get used to your unicycle at its current setting. I often found when I made a change in tire pressure or seat hieght (or a number of other things) I had the same problem, and the more I noticed it the worse it got. My solution was to hop on the uni and ride it hard and fast until my legs were a little tired (but loosened up) and then hop back on the uni. More often than not it solved the problem.
Of course, inspect your unicycle before doing this to make sure your wheel isn't off center. Also check your pedals, sometimes when your grip on the pedals isn't strong it leads to changes in the way you ride.
__________________
SWAT Gallery SWAT webpage Arrow Racing Sixsixone "Obie is definately a trend setter, I got in to unicycling because of him, and came here because of him" - KJ-52 "try not to annoy the great Obie, for he is better than us." - Murde Mental Disclaimer: The above message was not intended to offend anyone. If you are offended I can take no responsibility for my actions because I don't feel like it. Also you are reading an internet newsgroup where not everyone will share your same views and beliefs, be able to take criticism and post/read threads at your own risk. |
#5 | |
South Bay Uni-Sykos
Quote:
__________________
#6 |
Small fish, small pond
It may be that, as your riding develops, your musculature and technique are becoming asymmetric. Consider taking active steps to balance your riding style by idling with each leg, one-foot riding with each leg, working on figure 8s, hopping with each foot forward, and even holding the saddle with either hand.
__________________
Weep in the dojo... laugh on the battlefield. -- Dave Stockton |
#7 |
i just dribbled
i may have a some-what related problem. when i'm going up steepish hills i tend to have my left shoulder way out in front and in most cases my left shoulder is level with or further to the right than my seat. Is this a big problem?
__________________
maker of the happy birthday threads _________ Just put the new uni together in the driveway stopped to move the car and ran over the uni. Felt like putting my head under the tire. - JustOneWheel |
#8 |
Registered User
when i ride across a sloped surface i tend to move my right shoulder forward a lot more just to stay up right. i got a new tire for my uni and it pretty much stopped when i did that.
cheers, keep it wheel. |
#9 |
South Bay Uni-Sykos
Well I just finished adding extra washers onder the right under side where the seat bolts on. I noticed BEFORE I did this that the seat was high on the left side when the bolts were even. I think I just compressed that side down more during riding. So I will see if this has any effect and fixes the problem. Thanks everybody!
__________________
#10 |
From the Over 50 Group
I have come to my own conclusion that leading with one shoulder or the other is a means for controlling front-to-back balance.
I get into an awkward position such as a left or right slanting road surface, I slow down and the next thing that happens is one shoulder starts leading the way. One shoulder goes forward and so of course the other goes back. Then instead of using my arms to control side-to-side balance my arms are controlling front-to-back balance. Slanted surfaces and steeply curved road crown (especially while riding my 29er) still give me a lot of trouble. It is better than it used to be but still feels really awkward. I don't think it is your equipment unless something is really mis-aligned. The problem is with the rider. My 2 cents.
__________________
A man can fail many times but he isn't a failure until he begins to blame someone else. - Waite Phillips The art of medicine consists of keeping the patient amused while nature heals the disease. - Voltaire |
#11 | |
South Bay Uni-Sykos
Quote:
__________________
Impotence: Nature's Way Of Saying "No Hard Feelings". Uni is just a cycle I'm going through. Last edited by terrybigwheel; 2006-05-27 at 02:51 AM. |
#12 | |
Amanda gives me sunburn
Quote:
I've found this to be right. When I upped the pressure on my Coker tire, this happened, and I eventually just got used to it and it went away. |
#13 | |
South Bay Uni-Sykos
Quote:
__________________
#14 |
North Shore ridin'
Yesterday I rode Daytripper63's brand new KH 29er (with splined axle). I felt like it rode a little funny, wanting to pull to one side or the other, like riding on carpet. Very noticeable when riding on slanted bits of trail. It was very noticeable at first, but after a mile or so of riding it I felt less uncomfortable. I think the tire pressure was okay, though I didn't change it. I don't know if it's the tire shape. My tendency is to trust Kris on the choice of tire on any of his unicycles.
But I only rode a mile or so, not enough to form a proper opinion or nail down the problem (if any). For Terry, I'd recommend starting with the advice of whoever said to ride a different unicycle. Isolate whether it's the unicycle or you. The problem is *not* necessarily just in your mind or riding technique. It could also be orthopedic. But that's one of those things to be stuck with, only after eliminating everything else. Backpack: Are you sure the straps are equally adjusted? I usually have to adjust my Camelbak straps a little on every ride, as they tend to loosen. Are you holding the seat most of the time? If so, which hand is on the seat? If that shoulder is leading I don't think it's a problem. But if it constantly bugs you it is. If you don't normally hold the seat, try it. Hold the seat for long periods. It might take a while to get used to the idea, but it makes you more stable to the cycle, as well as increasing your leverage. It may help you straighten out. I highly doubt the side-to-side angle of your seat has anything to do with this. A crooked seat is more likely to just make you sore on one side more than the other. But let us know if it works!
__________________
John Foss "jfoss" at "unicycling.com" www.unicycling.com "Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben |
#15 |
jumps stuff
why does it matter??
and this happens to me after I do spins, but only then and all I have to do to fix it is hop-180 out of it or spin 180 out of it
__________________
><> Unicycle For Christ <>< MY VIDEOS World Record 94cm Highest Hop (rolling) 308cm Longest Hop (10 feet) 210cm Static Flat Gap |
| Tags |
| leading, left, riding, shoulder |
Similar Threads
| Listing/leaning to the Left when riding "CURED" | Daytripper63 | General Unicycling Discussions | 7 | 2006-03-08 04:50 AM |
| Rail riding -- "East Cliff" in Santa Cruz, CA | corbin | General Unicycling Discussions | 12 | 2005-06-15 09:30 PM |
| Why is the left pedal left-hand threaded? | Michael Grant | General Unicycling Discussions | 21 | 2002-08-11 05:41 AM |
| shoulder riding | jj348 | General Unicycling Discussions | 1 | 2001-09-02 10:37 PM |
| tips on leading workshops anyone??? | ticklemevaughn | General Unicycling Discussions | 0 | 2001-08-14 04:38 AM |
