Unicyclist Community
Reply
Old 2006-03-23, 10:40 AM   #1
willdabassist
Will
willdabassist's Avatar
Exclamation World-Wide pedal reverse-thread theory cospiracy!!!
I made a bit of a discovery recently, well i think it is...Has anyone els discoverd it??
Anywhom, what i have grown to believe is the reason that pedals have a reverse thread on one of them is so that the resistance caused by the bearing in the pedal does not un-screw the pedal off the crank arm...right??
So here's an experiment that sort of proves this wrong:
Take a pedal wrench and put it on the pedal as if to take it off.
Now, hold the wrench tight against the pedal and wheel your uni forward, keeping the peda wrench and pedal paralell with the ground.
This is to reproduce the forces of riding.
Now, if you continue doing this, the pedal will fall off.
Try this with all your unicycles and bikes if you want. I have.
Is this not strange?
Am i making sense?
It sort of goes against how i thought it should work.
It has left me quite destressed actually!
If someone could explain to me if im wrong or how im wrong, that would be great.
Or just tell me the results of your test.
Cheers
Will
willdabassist is offline   Reply With Quote
Old 2006-03-23, 11:06 AM   #2
Loosemoose
Coco... thanks guys.
Loosemoose's Avatar
Send a message via MSN to Loosemoose
Try riding your uni backwards for a while (turn the wheel around in the frame, or just spin the saddle 180)... Pedals fall off. I've tried it, it works.
Loose.
__________________
Vice President - Southampton University Circus Society
"Come on you target for far away laughter,
come on you stranger, you legend, you martyr, and shine..." - Pink Floyd
Loosemoose is offline   Reply With Quote
Old 2006-03-23, 11:26 AM   #3
monotone2k
Newsgroup User
Posts: n/a
Re: World-Wide pedal reverse-thread theory cospiracy!!!
If you are holding the pedal and wrench still whilst rotating the wheel
forwards, this is just the same as holding the wheel still and rotating
the the wrench and pedal backwards... which, as you explained, is
exactly how they should come off.
All you've done is find another way of removing the pedals rather than
keeping the wheel still, not proven that the threads are the wrong way
Kind've weird to think about, you have to remember that the effective
directions change depending on what part you keep still.
mono
Old 2006-03-23, 11:26 AM   #4
joemarshall
dumb blonde
You're wrong. Loads of people come up with this idea at some point. See <http://sheldonbrown.com/gloss_p.html#pedal> for an explanation of why.
If you'd ever ridden a unicycle backwards for a long distance, or put the seat on the wrong way round(*), you'd know that the pedals fall off surprisingly quickly.
Joe
(*) obviously I'm not stupid enough to have done this, it was 'a friend of a friend' who did this and then went for a ride with no tools and no way of tightening up the pedals leaving him walking home a couple of miles. Honest.
joemarshall is offline   Reply With Quote
Old 2006-03-23, 11:46 AM   #5
lucky_8
lucky8 unicyclist
Quote:
that must suck
lucky_8 is offline   Reply With Quote
Old 2006-03-23, 03:07 PM   #6
Loosemoose
Loosemoose's Avatar
When I first arrived at Southampton & went to the Circus Society I did my usual checkover of the clubs unicycles, and saw to my horror that they had been riding it reversed for a considerable period of time. Asking the President at the time, apparently they stripped the threads from 2 crank arms, and thought this was due to learners being tough on equipment... I quickly put it right again, although I have 2 new crank arms to fit still.
Loose.
__________________
Old 2006-03-23, 03:42 PM   #7
Eddbmxdude
THE original 12" Trials vid
Eddbmxdude's Avatar
What you could have done is, put the pedals back on finger-tight and then turn the saddle round so that they tighten the rest of the way whilst you rode.
Ride on!
Edd
__________________
www.voodoounicycles.com- The UKs only Extreme Unicycle Display Team
I guess it's just a good thing you didn't include the footage of us snorting cocaine from the thighs of prostitutes eh Edd. - Boogie
Eddbmxdude is offline   Reply With Quote
Old 2006-03-23, 04:17 PM   #8
joemarshall
dumb blonde
Quote:
Didn't work. These particular pedals need to be quite tight like slightly tighter than finger tight to be not wobbly in the threads of a crank. It felt like I'd be too likely to strip the threads riding on them. It's odd, some pedals are fine with being finger tight, some pedals you need a spanner, it doesn't seem obvious why.
Joe
Old 2006-03-23, 06:08 PM   #9
johnfoss
North Shore ridin'
johnfoss's Avatar
Probably just variations in machining; some sets of threads match up better (or worse) than others.
I don't know why I'm posting to this thread. For Will: If you haven't read the linked article from Sheldon Brown, please consider millions of people riding bicycles for over 100 years. The question is not whether the threading is backwards, it's whether your theory is backwards. The key word is precession.
__________________
John Foss
"jfoss" at "unicycling.com"
www.unicycling.com
"Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben
johnfoss is offline   Reply With Quote
Old 2006-03-24, 04:17 AM   #10
willdabassist
Will
Thanks joemarshall for the link. That is really interesting.
Before i posted this thread, i asked at two local bike shops.
The first one said "I dont know how it works on your crazy bike" refering to my uni, and then walked off. The tech at the other shop said that it was so that the pedal didnt get stuck on too tight!
I wasn't doubting hundreds of years of cycle technology, as i too have gad my pedals comming loose from riding backwards!
Old 2006-03-24, 06:46 AM   #11
Klaas Bil
Newsgroup User
Posts: n/a
Will, your 'conspiracy theory' has been set straight, so I won't add
to that.
But I'll say, I appreciate how you put your question. This issue comes
up every so many months in this group, and is often phrased like "The
world has done it all wrong all the time".
Old 2006-03-24, 01:18 PM   #12
manu2015
street rider
manu2015's Avatar
Hi,
A few months ago, i wanted to unscrew my pedals and didn't remember the good direction.
I tried to think to the stresses involved in pedaling as i knew there were something particular with pedals threads. I noticed the thing of the pedals getting loose when going backwards for a while. So i had the same thought as you, ... and at first tightened my pedal.
I realized quickly that i was doing a mistake but didn't understand why.
Thank you for your question, i read the page of sheldon brown and i have my so needed explanation.
Manuel
manu2015 is offline   Reply With Quote
Old 2006-03-24, 07:43 PM   #13
johnfoss
North Shore ridin'
johnfoss's Avatar
Quote:
Let us praise the lowly bike mechanic. They do under-appreciated work for very low pay. Many are not experts outside of their narrow area...
__________________
John Foss
www.unicycling.com
Old 2006-03-24, 07:44 PM   #14
johnfoss
North Shore ridin'
johnfoss's Avatar
Quote:
Here's a crude way to remember. Which way to your pedals go on? Righty-righty, lefty-lefty. Sound familiar?
__________________
John Foss
www.unicycling.com
Old 2009-12-11, 08:42 PM   #15
saskatchewanian
ERIC P
saskatchewanian's Avatar
Send a message via MSN to saskatchewanian Send a message via Skype™ to saskatchewanian
Doing some tire testing I accidentally put the wheel on backwards. only got in about 5 minutes of riding when the pedals started to feel loose. Turned the seat around (too lazy to turn the wheel around) and the pedals tightened themselves again.
The conspiracy of unintuitive physics is real!
I was surprised how fast they loosened. I think if I was planning (and able) to do a lot of backwards riding I would use some blue loctite on the threads.
__________________
saskatchewanian is offline   Reply With Quote
Reply
Tags
cospiracy, pedal, reversethread, theory, worldwide
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
spaced out avalible world wide!!!! Jeff Groves General Unicycling Discussions 4 2004-10-29 10:44 PM
World Wide Uni Club. THe WORLDS GREATEST!! Logan_A. Just Conversation & Introduce Yourself 28 2004-04-16 11:43 PM
World's cheapest UW -or- pedal thread thread schroder General Unicycling Discussions 6 2003-10-20 05:25 PM
reverse pedal grabbing m_extreme_uni General Unicycling Discussions 6 2002-10-29 03:36 AM
Different methods of promoting unicycling world wide Ken Fuchs General Unicycling Discussions 3 1994-11-15 04:18 AM
Copyright © 2001-2005 Gilby
Page generated in 0.09261 seconds with 10 queries
