Unicyclist Community
Reply
Old 2005-12-07, 08:29 AM   #1
pete66
UNI branded
pete66's Avatar
Send a message via MSN to pete66
The history of wrap?
Anyone know anything about wraps? Are they even called wraps?
The trick I'm talking about is the one Dan Heaton does in Defect, moments before he does the "super-wrap".
So I guess there's 3 tricks that can get confused with each other here:
1) Super-wrap (back leg comes around uni twice and then uni goes behind back, switches hands and then around the other leg twice)
2) Wrap - same as super-wrap but legs only go around once each side.
3) (simple) leg over - leg goes around seat and back to crank
When was the wrap first done? Was it by Dan? I think it's in Universe1... I take it the super-wrap in defect is the first time that trick was ever done?
I've pulled off a wrap like 3 times now and it feels great the times I nail it, seems like a good one for putting into combos too! Has anybody here managed any consecutive wraps?
cheers
Pete
pete66 is offline   Reply With Quote
Old 2005-12-07, 08:31 AM   #2
munimanpete
the unicycling kiwi
munimanpete's Avatar
Pete I think your mean the "Subaraft".
munimanpete is offline   Reply With Quote
Old 2005-12-07, 08:41 AM   #3
pete66
UNI branded
pete66's Avatar
*dies laughing* Aww, 10mins up so I can't edit it into SUBARAFT. So does that make the other one a "RAFT"? And then there's the double-raft (consec rafts)... triple-raft and the (wait for it) "TRIPPLESUBARAFT"
Old 2005-12-07, 08:54 AM   #4
pete66
UNI branded
pete66's Avatar
The next level will be the "air-wrap" down a 10-set... It's a really fast move so it's entirely possible, prob not that much harder than say a crankflip down a stairset.
Old 2005-12-07, 09:18 AM   #5
uniryder
SYKOproductions
uniryder's Avatar
Send a message via AIM to uniryder Send a message via Yahoo to uniryder
Hi,
I believe I was the first person to do this trick in 1999. I had not previously seen it done at any convention or on any video and it became my first attempt to invent a trick. I thought of it after seeing people do leg around mounts. The trick seemed new to the freestyle riders at Unicon in Beijing in 2000 too, so unless anyone objects i'll stake claim to this trick...
I usually call it a wrap or wrap around, but i'm open to a different name if anybody has anything.
I'll upload a vid of a double-wrap in a second...
-Dan
uniryder is offline   Reply With Quote
Old 2005-12-07, 09:40 AM   #6
uniryder
SYKOproductions
uniryder's Avatar
I'm not sure if this trick could be pulled down sets or off drops very easily, definitly would be way more challenging than a crankflip in the air... I've thought about it, but never put any effort into trying, the mechanics of it just seem really difficult...
This is a "double-wrap"
http://www.unicyclist.com/gallery2/m...cf61fef0d8e837
Old 2005-12-07, 09:43 AM   #7
pete66
UNI branded
pete66's Avatar
Well I guess one of us needs to put some time into landing a "half-wrap" down a drop first, and ride away seat out back? Maybe if you got that solid it'd get easier? I'll check out that vid now
Old 2005-12-07, 09:49 AM   #8
pete66
UNI branded
pete66's Avatar
That's choice! Thanks for uploading it.
Old 2005-12-07, 10:45 AM   #9
fexnix
I got infinite skillz
fexnix's Avatar
Send a message via MSN to fexnix
Stop talking like the swedish chef in the muppets..!
Quote:
Originally Posted by Pete 66
I'fe-a poolled ooffff a vrep leeke-a 3 times noo und it feels greet zee times I neeel it, seems leeke-a a guud oone-a fur pootting intu cumbos tuu! Hes unybody here-a muneged uny cunsecootife-a vreps?
__________________
My 29er page
My fresh album
fexnix is offline   Reply With Quote
Old 2005-12-07, 10:55 AM   #10
pete66
UNI branded
pete66's Avatar
canoh ELLp eet
Old 2005-12-07, 11:40 PM   #11
johnfoss
North Shore ridin'
johnfoss's Avatar
Quote:
If you want to tie it in with our existing (though boring) naming conventions, in the Standard Skill List, you might call it a 2-sided leg around. Check the definition for leg around. Does that fit with your wrap concept?
I dug around in my brain and am not sure that I'd ever seen it done before you either. If nobody from Puerto Rico jumps in later and says they used to do it, you're probably free & clear. This is the problem with newer tricks that don't have names; it's hard to keep track of them! We need names for the ones that are known and not yet defined.
Congrats on your first original trick! It's very visual. I have what I call Cyclone Spins, which are a combination of frontspins and backspins, and Pedal Walk, which tends to bend your frame. And that thing where you spin the unicycle with your hand on the seat, while standing next to it...
__________________
John Foss
"jfoss" at "unicycling.com"
www.unicycling.com
"Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben
johnfoss is offline   Reply With Quote
Old 2005-12-08, 01:04 AM   #12
forrestunifreak
is in college. and on magazines.
forrestunifreak's Avatar
Send a message via AIM to forrestunifreak Send a message via MSN to forrestunifreak Send a message via Skype™ to forrestunifreak
Thats different than the "super wrap" in Defect....
__________________
[SIGPIC][/SIGPIC]
forrestunifreak is offline   Reply With Quote
Old 2005-12-08, 01:51 AM   #13
unicyclistjoe
Gapping Machine
unicyclistjoe's Avatar
Send a message via MSN to unicyclistjoe
Quote:
Yes, because he is doing two consecutive single wraps. In Defect, he does the Super Wrap (Subaraft ) which is where each leg does two wraps around the seat.
__________________
NZUni President
94cm Highest Hop
287cm Longest Hop
205cm Static Flat Gap
unicyclistjoe is offline   Reply With Quote
Old 2005-12-08, 04:29 AM   #14
forrestunifreak
Yeah I see the difference now.
I heard before someone called it a saran wrap once?
__________________
[SIGPIC][/SIGPIC]
Old 2005-12-08, 04:41 AM   #15
unicyclistjoe
Gapping Machine
They probably did, the motocross people have a similar move that they call a saran wrap...not as impressive as a unicycle wrap, of course
__________________
NZUni President
94cm Highest Hop
287cm Longest Hop
Reply
Tags
history, wrap
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
stretching 661 veggie wrap shins? saam General Unicycling Discussions 13 2005-09-02 12:39 AM
History of Unicycling? tugboat General Unicycling Discussions 4 2003-03-11 10:38 PM
Unicyling History Jason Neumann General Unicycling Discussions 1 2002-08-28 06:56 PM
history Wayne van Wijk General Unicycling Discussions 1 2001-01-29 07:30 PM
Early History ??? Marlon Solar General Unicycling Discussions 3 1998-03-02 12:40 PM
Copyright © 2001-2005 Gilby
Page generated in 0.09351 seconds with 10 queries
