Unicyclist Community
Reply
Old 2005-10-08, 11:35 PM   #1
musketman
Registered User
musketman's Avatar
3.7/ KH conversion
Stupid questions about to come... beware! Can the new 3.7 tyre fit into a kh frame? I'm guessing not, but it seems like the frame width is enough to fit 4" in there, or is it the clearance part of this that doesn't make it? Or both? Could you get a 29" KH frame and put the 26 by 3.7 tyre on it? Or a 24" frame and put a 24" by 3.7 tyre in it? Has anyone tried?
musketman is offline   Reply With Quote
Old 2005-10-08, 11:46 PM   #2
trials_uni
Trials and Muni Rider!
trials_uni's Avatar
if you speak of the 3.7 listed earlier it will fit the KH 29er frame privided that the width of the frame is compatible and only the 24rim will fit the 26 beccomes a 29er due to the massivity(is that a word?) of the tyre...hope that helps
-Phil
__________________
TRIALS 4 LIFE !
Check Out The Newbie Guide
And the Spline Maintenance Guide!<UPDATED!!!With Video
Quote:
Originally Posted by BillyTheMountain
Hey thanks! The unicycle community needs more people like you, willing to out Bike Suprematists and stand up for the rights of unicyclists!
I'm puttiing you in for an Award at NAUCC!
trials_uni is offline   Reply With Quote
Old 2005-10-08, 11:53 PM   #3
KcTheAcy
Ohh Baby
KcTheAcy's Avatar
I dont think the 24x3.7 has come out yet.
KcTheAcy is offline   Reply With Quote
Old 2005-10-09, 12:24 AM   #4
Loosemoose
Coco... thanks guys.
Loosemoose's Avatar
Send a message via MSN to Loosemoose
Its possible, I don't have a new kh frame to actually measure though. Also bear in mind that the 3.7" tyre relates to tread width and the actual distance between the sidewalls on each side may be as much as 4". Its worth trying, but I wouldn't bet much on it without checking first... Since the only 3.7" tyre is for a 26" wheel you'd need to use a 29" KH frame.
Loose.
__________________
Vice President - Southampton University Circus Society
"Come on you target for far away laughter,
come on you stranger, you legend, you martyr, and shine..." - Pink Floyd
Loosemoose is offline   Reply With Quote
Old 2005-10-09, 01:29 AM   #5
SurlyDave
Surly MC
Quote:
Loose.
The overall width of the tire is 3.7" (94mm) on the Large Marge rim at 30psi. The tire is widest at the sidewall...not at the edge of the tread. Flattened out, the tread measures 4" (102mm) across.
Dave
SurlyDave is offline   Reply With Quote
Old 2005-10-09, 10:40 AM   #6
Loosemoose
Loosemoose's Avatar
Quote:
Ah sorry, my mistake. I assumed the 3.7" measure was tread width while inflated, and the sidewalls were wider than that. Thanks for clearing that up Dave.
Loose.
__________________
Old 2005-10-09, 06:03 PM   #7
musketman
Registered User
musketman's Avatar
I could try it, but im not spending the money to find out! It seems like it would work tho. I have an 05 kh frame and im pretty sure it is at least 4" across. If the KH 29 frame is the same across i don't see why it wouldn't work.
Reply
Tags
37 or, conversion
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
KH/pro file hub conversion musketman General Unicycling Discussions 5 2005-09-15 10:59 PM
Conversion commandoH General Unicycling Discussions 15 2003-12-02 03:03 AM
pic conversion GILD Just Conversation & Introduce Yourself 11 2003-08-07 09:01 PM
Air Seat Conversion? XWonka General Unicycling Discussions 4 2003-08-04 11:04 PM
Copyright © 2001-2005 Gilby
Page generated in 0.07874 seconds with 10 queries
