#1 | |
805elgguJ
Broken uni piece.
On my onza trials 20" unicycle, down by the crank, there is a little saucer thing between the crank and frame....it can now spin freely instead of staying in place. Is this bad? Kelly.
Heres a pic.
__________________
Quote:
www.myspace.com/kelly_hickman |
#2 |
***** Member
No, don't worry, it's not a problem. It is merely a spacer.
__________________
SWAT Gallery SWAT webpage Arrow Racing Sixsixone "Obie is definately a trend setter, I got in to unicycling because of him, and came here because of him" - KJ-52 "try not to annoy the great Obie, for he is better than us." - Murde Mental Disclaimer: The above message was not intended to offend anyone. If you are offended I can take no responsibility for my actions because I don't feel like it. Also you are reading an internet newsgroup where not everyone will share your same views and beliefs, be able to take criticism and post/read threads at your own risk. |
#3 |
Ohh Baby
You should tighten the crank's allen bolt.
#4 | |
805elgguJ
Yeah i just tightened the crank alen bolt thing. Is my crank pretty much screwed now that i have been riding with it loose?
__________________
#5 |
Registered User
Yeah, its not broken it stays in place because the crank wedges it on so just tighten your cranks and it should stop spinning
EDIT well nevermind because you just posted as i was typing
#6 |
Registered User
it shouldn't be screwed up, i mean, theres still so much surface contact even if it's not totally tight, it shouldn't move on the splines unless it's WAY off
make sure you tighten it a bunch, but make sure the main cap holders are stillin the right place you might want to take the frame off, tighten the cranks, then put the frame back on o yeah, don't (if you're ever reassembling totally) put one crank on, tighten it a lot, then put the other one on, you could pull the axle through the hub instead, tighten both cranks to a medium spot, then fully tighten each
__________________
UBC rocks!!! |
| Tags |
| broken, piece, uni |
