Unicyclist Community
Reply
Old 2005-02-22, 07:21 PM   #1
Erin
wheeler
Erin's Avatar
seat clamp bolt?
I need a seat clamp bolt that fits the single hole in the pre-attached clamp on a Bedford frame. Does anyone know what I would call this when asking for the bolt at a hardware store?
thanks,
Erin
__________________
"If you have no goals, you can accomplish almost anything!" Slugbath
Erin is offline   Reply With Quote
Old 2005-02-22, 07:25 PM   #2
UniBrier
Time To Ride
UniBrier's Avatar
Instead of the hardware store consider a quick release from your LBS. That's what I use on my Bedford 29er frame.
__________________
Steve
Hop Drop & Roll
“If something is too hard to do, then it's not worth doing. You just stick that guitar in the closet next to your
shortwave radio, your karate outfit and your unicycle and we'll go inside and watch TV.” – Homer
UniBrier is offline   Reply With Quote
Old 2005-02-22, 07:30 PM   #3
Erin
wheeler
Erin's Avatar
Steve, don't you find that it is hard to get the quick release secure enough? When I used them in the past the seat post always seemed just a tad loose.
__________________
Old 2005-02-22, 07:42 PM   #4
sabin_a.
skilled unicyclist
sabin_a.'s Avatar
Send a message via AIM to sabin_a.
I had this same incident with my bedford clamp.
Darren was really helpful and said you could take a dremmel tool or a file and grind off the small weld to un-attatch the clamp so you can use another (non quick release clamp) I didnt have a dremmel, so i used a file. It took a little bit of work, but i got it off and put on a 3 allan bolt clamp.
-Sabin
__________________
Homer - "Could Jesus microwave a burrito so hot that he himself could not eat it?"
Flanders - "Well, as melon scratchers go, that's a honey doodle"
SIXSIXONE
sabin_a. is offline   Reply With Quote
Old 2005-02-22, 08:02 PM   #5
john_childs
Guinness Mojo
john_childs's Avatar
Unicycle.com sells the bolt. Here's a picture of it. I'm pretty sure that it's a standard style of bolt but I'd be surprised if a hardware store will have one (they're not common).
You'll need to find a place that specializes in fasteners (a fancy name for nuts and bolts and other threaded things). Print out that picture from Unicycle.com and they'll know what you need. The thing that's special about the bolt is the little tab under the head that keeps the bolt from spinning when it's tightened up.
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2005-02-22, 09:00 PM   #6
UniBrier
Time To Ride
UniBrier's Avatar
Quote:
Its basically the same quick release that I have on my MTB and other family bikes, Coker, the Schwinn Giraffe, etc. I haven't had a any problems with the good ones. There are some types that are built cheap and they have failed.
I just go to Recycled Cycles and look through their bin of used clamps until I find one I like.
__________________
Steve
Hop Drop & Roll
Reply
Tags
bolt, clamp, seat
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.06364 seconds with 9 queries
