Unicyclist Community
Reply
Old 2005-01-02, 05:09 AM   #1
hole-in-my-shoe
getting bigger
Need help removing crank
I need to remove a cheap crank from a square-tapered hub. The thread on the crank is stripped beyond salvation. I have no idea how
to proceed. Can I save my hub?
I'm considering just taking the nut off and riding around until the crank works itself loose. Somebody stop me.
Crank removal tips please.
Thank you.
hole-in-my-shoe is offline   Reply With Quote
Old 2005-01-02, 05:15 AM   #2
brockfisher05
THE YAM FATHER
brockfisher05's Avatar
well just use a cranks puller and how the hell did you strip it
__________________
email me! brockfisher05@gmail.com
brockfisher05 is offline   Reply With Quote
Old 2005-01-02, 05:30 AM   #3
john_childs
Guinness Mojo
john_childs's Avatar
You can try using a bearing puller to remove the crank. But that would require that you buy a bearing puller if you don't already have one.
The cheap and easy way would be to take the nut off and ride around till it comes loose. Just be careful it it's a steel crank. Steel cranks can damage the hub taper much more easily than an aluminum crank.
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Reply
Tags
crank, removing
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.08292 seconds with 9 queries
