#1 |
Registered User
kh trials bearing problem
I recently messed up the left bearing and possibly the bearing housing. Does unicycle.com offer replacement bearings for the kh trials/will a generic 40mm bearing work with my axle if i put the spacer on it to accomodate the frame? If my bearing housing is bent, is there any way i can get a replacement?
Help
__________________
BC or Grind? What should i work on! |
#2 |
Guinness Mojo
See this thread for info on where to order bearings for the Summit or KH: Summit Bearings, Where do I get them?
Unicycle.com doesn't have the KH bearings listed in their online catalog. Just because it isn't in their online catalog doesn't mean that they don't have it. Call them up and ask. Otherwise you can either order them from Boca Bearing or find a local bearing supplier that has them. Unicycle.com may have spare KH bearing housings. Call them up and ask. It's a big maybe but worth a shot. They do stock spares even if all the spares are not in the online catalog. Otherwise I'd check with a local machinist to see if they can somehow fix it.
__________________
john_childs (att) hotmail (dott) com Team Never Wash Your Muni My Gallery :: Unicycling Bookmark List :: World Clock |
#3 |
My Uzi is a Tongue
kh bearings will work with a Summit just use the sleeve around them that the Summit came with.in a pinch, i think they will work without the sleeve too
__________________
theres enough BS in life, without mobius contributing. Forget_Your_Life -------------------------------------- -------MUNI MILITIA ------- One Wheeled Death Squad twitter> @shot of jagur Last edited by jagur; 2004-08-19 at 08:18 AM. |
| Tags |
| bearing, problem, trials |
