Unicyclist Community
Reply
Old 2004-04-19, 08:25 PM   #1
gpickett00
Registered User
gpickett00's Avatar
Onza 20 vs. KH20
Hello, I have 400 dollars and I'm trying to decide between a Kris Holm 20" and an Onza 20". I am leaning toward the Onza because it is supposed to be in stock in late April, while the Kris Holm is out of stock until late May. Please tell me the pros and cons of each of them so I can decide whether to wait for the KH20 or buy the Onza SOON.
gpickett00 is offline   Reply With Quote
Old 2004-04-20, 01:30 AM   #2
gpickett00
Registered User
gpickett00's Avatar
top
Old 2004-04-20, 02:02 AM   #3
darchibald
Street Unicyclist
darchibald's Avatar
I'm asking the same questions. From what I've heard (all second-hand info), the Kh is better overall, but it seems to be for no apparent reason. There is a problem with its nubs, either last years or this years. It can rip up your ankles pretty good, but when ordering you can ask for them to be fixed. The Onza is cheaper and weighs less, (6.2 kg vs. 6.65 kg). But I still keep hearing that the KH is better.
Remember this is all second hand info, cuz I'm still in the same place as you. Out of curiousity where are you looking at these?
Hope this helps
David
Ps. it says your level 3.7. Where does that come from.
darchibald is offline   Reply With Quote
Old 2004-04-20, 02:18 AM   #4
gpickett00
Registered User
gpickett00's Avatar
I look on www.unicycle.com . I get 3.7 from i can do 6 out of the 9 level 4 skills. 6 divided by 9 = .6666667
Old 2004-04-20, 02:19 AM   #5
one wheeled stallion
Guerilla Unicyclist
one wheeled stallion's Avatar
Search the archives guys, there have been tonnes of threads about Onza vs KH!
I like the cranks better on the Onza, tho I have had a bit of play in the hub. The KH just feels rock solid. Pretty even, tho I think there are more b*ke cranks to fit the KH. Could be wrong.
Apparently Onza, KH and UDC are joining together to build the hub/crank set to rule all hub/crank sets, I guess this will be on the new models? I've read it's for release around October, but again I could be making that up. More hearsay is that it's stronger than Profiles. May be worth waiting a little longer. Or getting a Nimbus so you can upgrade the hub and cranks later, as the only real difference after the hub/cranks is the frame as the seats are the same.
__________________
OWS
"...I explain briefly to him that such conduct leaves him vulnerable to accusations of being an idiot. We part as enemies" - Mikefule
one wheeled stallion is offline   Reply With Quote
Old 2004-04-20, 05:39 AM   #6
elmer
uniimpaired
elmer's Avatar
onza vs kh
Let me suggest another option if you're in a hurry! I'm preparing to replace the 24" rim on my Torker DX with a 19" Alex and a trials tire. The splined cranks are substantially built and the frame and seat post are excellent, the frame being only marginally larger than necessary for a 20" trials set-up. The cranks do have the same nub problem, however as the KH/Summit. This configuration is going to run me a total of about $250.00 after shipping. The Torker was purchased from e-bay. The rim, spokes and tire from unicycle.com, and I'll do the wheel-build myself. I'll post pictures when it's done.(hopefully within two weeks)
elmer is offline   Reply With Quote
Reply
Tags
kh20, onza
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.08547 seconds with 9 queries
