#1 |
Registered User
Unicycle for my little sister?
My little sister wants to get a unicycle and learn how to ride, so I beat her up. I can't have any of this imitation stuff...
Just kidding. I am trying to figure out what size she should get. She is 12 years old and 61" tall. Should she use an 18" or a 20"? Which will be easier for her to learn? I have only used a 20" so I can't speak from experience. The unicycles I am looking at are the 20" Sun http://www.unicycle.com/shopping/shopexd.asp?id=36 and the Torker Unistar CX. http://www.unicycle.com/shopping/shopexd.asp?id=42 For 18" There is only a Sun. http://www.unicycle.com/shopping/shopexd.asp?id=35 Or I could give her my old 20" Savage. |
#2 |
***** Member
Measure her inseam then get her a uni with a minimum inseam requirement less than hers, but not much less. Get the one that is the closest to her without being too short.
__________________
SWAT Gallery SWAT webpage Arrow Racing Sixsixone "Obie is definately a trend setter, I got in to unicycling because of him, and came here because of him" - KJ-52 "try not to annoy the great Obie, for he is better than us." - Murde Mental Disclaimer: The above message was not intended to offend anyone. If you are offended I can take no responsibility for my actions because I don't feel like it. Also you are reading an internet newsgroup where not everyone will share your same views and beliefs, be able to take criticism and post/read threads at your own risk. |
#3 |
Registered User
my sister is 11 and 61" also. With my summit down to the lowest it will go she can ride comfortably. I would get her a 20", then when she gets older she can still use it. I would go for the Torker. Suns have cheapo steel rims. The torker on the other hand has an alloy rim.
Alex |
#4 |
On Vacation - till i find a job
I would say that a 20 inch will be fine. It might be a tad big, but I don't think so. All of the uni's you have listed are decent, but the Torker LX is a much better option. It will last much longer and has a much better saddle in addition to a better rim and frame. It's a tad more expensive, but well worth the extra cost.
Good luck on whatever you get. Daniel
__________________
OPPORTUNITYISNOWHERE |
#5 |
Pedal Pedal Crash
I wouldnt recommend an 18", it's the tire and rim selections are very, very limited.
__________________
There is nothing worse than a gross exaggeration. |
#6 |
Time To Ride
20 inch is good. My daughter, Andrea, is now 12 and exactly 5'. She has always been petite and started several years ago on a 20" . She currently is on a Sem Longneck frame, fits her like a Wyganowski.
If you're on a budget go with the Sun, she will not like the kiddie seat on the Torker CX. Again I agree with Daniel, if you can afford it, go with the Torker LX; you will get both a flat crown and a far superior seat.
__________________
Steve Hop Drop & Roll “If something is too hard to do, then it's not worth doing. You just stick that guitar in the closet next to your shortwave radio, your karate outfit and your unicycle and we'll go inside and watch TV.” – Homer |
#7 |
Newsgroup User
Posts: n/a
Re: Unicycle for my little sister?
On Fri, 16 Jan 2004 21:47:12 -0600, Rayden
<Rayden@NoEmail.Message.Poster.at.Unicyclist.com> wrote: >She is 12 years old and 61" tall. Should she use an 18" or a 20"? 20" all the way. It's much more a standard size. I've seen kids of 5 learn on a 20". (For them a 16" might have been better though.) >Which >will be easier for her to learn? 18" might be a tad easier, I'm not sure. But the difference (if any) would not justify buying an 18". |
#8 | |
Co-Founder of the PacoGild Movement
Quote:
__________________
Blah Blah Blah BACON Blah Blah Blah --Harper a-la Catboy Still a work in progress . . . 768 |
#9 |
Registered User
Absolutely 20 inch
Both my children (6 and 8) learn on a 20 inch. Seatpost is first too long, but it can cut little away. |
#10 |
Awesome(but not at uniing)
my little bro is also interested in learning. He's about 5'9" (remember, little is relative, im 6'2")
i've got my summit seat all the way down, and its still too short from seeing the videos, he's already decided he wants to do MUni he wont learn on one, but do you think he should learn on a 20" or a 24"?
__________________
I've even passed a Jeep Cherokee stuck in the snow to who's driver I asked, 'May I suggest putting it into one wheel drive?' --Sofa |
#11 |
mad.nut
simple answer
24
its easier to ride, and much quicker, although a 20 is easier to idle on, which is important
__________________
if practise makes perfect, and nobody's perfect, why practise? |
#12 |
Hardcore Trials Rider
Whats with using Inchs?
Id get her a 20" and insist on her learning freestyle ![]() Trev
__________________
www.unicycleboy.unicyclist.com MMMM the Bishop http://www.unicyclist.com/gallery/?g..._itemId=174201 |
#13 | |
currently riding bikes
Quote:
I dont see anything wrong with teaching someone to ride on a muni, but a 3" Gazz probably wouldnt be great due to the way it handles on hard surfaces. Other Muni tires dont have that problem though. If your not against It I would have a sybling learn on my uni just to see if they like it or not, especially when your so close in height.
__________________
No one said it was gonna be easy and I'm not afraid to try, with the odds stacked up against me I will have to fight, One Life One Wheel got to do it right. H2O -------MUNI MILITIA ------- One Wheeled Death Squad |
#14 |
Newsgroup User
Posts: n/a
On Sat, 17 Jan 2004 13:04:09 -0600, Bonduranto
<Bonduranto@NoEmail.Message.Poster.at.Unicyclist.com> wrote: >do you think he should learn on a 20" or a 24"? If both are available, then I'd say 20". People learn to ride 30% quicker on a 20" as compared to a 24". |
#15 | |
Unicycle Advocate
Quote:
Give her your old Savage Rayden, but chuck a nice seat on it or she won't enjoy Unicycling as much, and might be put off. |
| Tags |
| sister, unicycle |
