Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
Newsgroup User
Posts: n/a
Re: Super-light trials unicycle - How I became a function first weight weenie.
> > The polished aluminum looks great! How will it hold up against > > oxidation and corrosion? * I'm a retired ME with a metal finishing background, and as you'll notice below, I have way too much time on my hands. For your particular application, you might try "Boeshield T-9." It's a product orginally developed by Boeing Labs (the same as the aircraft folks) under a military specification for inhibiting oxidation and corrosion on both aluminum and ferrous alloys. It's now licensed to a 3rd party chemical processor/distributor. It has the same orginal Boeing formulation and reminds you of the new, "wet-look" you get when spraying WD-40 on something. However, as it's a penetrant, the shiny, wet-look mysteriously hangs in there for months. It's a spray on/wipe off product, so to reapply it a 6-9 months later (depending on inland vs coastal use), only takes a few seconds. You can get the stuff at: http://www.boeshield.com/index.htm Also, I've heard it's available at Yamaha dealers and marine dealerships, so you might try one of those for a local source. To get a mirror luster or mirror luster extreme on aluminum to start with, you might try: http://shorterlink.com/?UZQS3Q Although the above addresses motorcycle applications, aluminum is aluminum when it comes to polishing/buffing any aluminum plate, sheet stock, extrusion, or casting alloy. It contains about every buff and compound imagineable, the local retail sources for getting supplies, as well as the guarded secrets of professional polishing shops. As DIY poop like this is virtually non-existant, it's worth its weight in gold if you're after a true mirror luster passing for the brightest chrome plate. However, to keep it that way, you have to use a sealant. Hope this helps, Greybeard |
| Tags |
| function, superlight, trials, unicycle, weenie, weight |
