#1 |
wheeler
Alex DX32 Rim = 3 inch tire?
Will my Alex DX 32 MUni rim (24 inch) take a 3 inch Gazz tire? And, probably most importantly, will it be a bear to get this type of tire on that rim.... a la earlier 'tight tire' posts?
thanks, Erin (who is thinking up a lot of questions while at home with a case of the Xmas flu.......)
__________________
"If you have no goals, you can accomplish almost anything!" Slugbath |
#2 |
Registered User
i have a gazzoloddi 24" by 3" tire on my MUni. it's takes a bit of effort to get on, but that is soon forgotten, and the 3 inch tire is amazing. i'd say that the best rim to put a 3inch tire on would be the Alex DX 32 (your rim) so go ahead.
the only problem with this idea, is that it will require you getting a wider enough frame to use it (bedford frames d'ont fit) however, Darren was telling me that he was going to be getting some wider frames that will fit a three inch tire, so i guess your in luck. Tell us what you end up doing, -Ryan
__________________
"Yeah, Gravity is bad" Leo Kottke |
#3 |
768 - It's in your DNA
Your Alex DX 32 rim has an affinity for any and all Gazzoloddi 24x3 tires and will cleave unto them. My understanding is that it's a tight but not undoable fit. I've never had to separate mine even though the constant cooing from the pair in the basement becomes annoying at times.
__________________
-Greg Harper Destroying the climate by shutting down nuclear power plants, one by one, since 1979. JC is the only main man. There can be no other. "A fool on a unicycle is redundant" - J.D. Miller |
#4 | |
Registered User
Quote:
Tell me you don't leave them in the basement - together - unattended? Bruce |
#5 |
wheeler
Ah, cooing of rim and tire, music to my ears! Yes, just what I hoped to hear......
and I have also heard that Darren will be getting frames to fit a 3 inch tire soon.... So what will I notice when I ride on a 3 inch tire as opposed to a 2.5 inch tire, let's say.... will there be a significant difference or only a subtle difference? Erin
__________________
#6 | |
Guinness Mojo
Quote:
One difference you'll notice is that riding over roots and rocks will be easier. Traction will be better. Small rocks that used to roll under your tire and cause you to UPD will not not cause you to UPD as often. It will suck up bumps better when rolling over roots and such. Landing drops will feel more stable. So many good things are better with a 3" tire. That isn't to say that there are no downsides. Turning on pavement will be more difficult. You'll have to some of your riding technique because of the difference in turning. You will find that you'll end up choosing to ride right over things on the trail instead of turning or zigzagging around them because you can and because it is not as easy to turn. Rolling resistance also increases with the 3" tire but the upsides of being able to just plow over things instead of zigzagging around them can make up for that.
__________________
john_childs (att) hotmail (dott) com Team Never Wash Your Muni My Gallery :: Unicycling Bookmark List :: World Clock |
#7 |
wheeler
Thanks for that info John.... sounds pretty good to me!
What about weight, is the 3 a lot heavier than the 2.5, and therefore is it harder to hop with the extra weight? Erin
__________________
#8 | |
Uni Gwaihir
Quote:
http://www.nokiantyres.com/bike/dhspecs/index.htm Some more weight data can be found here: http://torontounicyclists.tripod.com/tire.htm Have fun, Fred |
#9 | |
Guinness Mojo
Quote:
The biggest factors in jumping height are your skill, your standing vertical leap, how well you can make your jump "snap", and how well you can sync your jump with the compression and rebound of the tire. The weight of the tire not near the top of the list of things that significantly impact your jumping height. The nice thing about the 3" tires is that they compress and rebound nicely and the nice rebound does help when jumping with them. The 3" tires actually feel bouncy compared to the higher pressure skinnier tires. But lighter tires are nicer for jumping with, which is one reason people like the 3" Fireball tire for urban/trials. Just a few psi difference makes a very noticeable difference in how the 3" tires feel and behave. You'll want to experiment to find your ideal tire pressure for your style of riding. A while ago I posted a heuristic for determining tire pressure. Scott Bridgman put that post in his Tips and Techniques section of muniac.com. <http://www.muniac.com/tips.htm#pressure> With the 24x3 Gazz I usually run about 24 psi.
__________________
#10 |
wheeler
Thanks John, again, very helpful!
Erin
__________________
#11 |
Registered User
ya, like everyone else said, the alex DX32 rim is ok with the gazz tire. Auctally i just got a unicycle with that combination, and it works really well. As for jumping, it depends what your doing. A single jump is a bit harder, but it's not much difference, and the extra bounce is great for when you're doing a few jumps.
__________________
Your body is an insturement, not an orinament |
#12 |
Pedal Pedal Crash
Also, some 3"ers are harder than others. for example I dont think I could change my Intense 24x3 if I tried my hardest for an hour, but I can get my kujo on/off in less that 5 minutes. I havent tried a Gazz though.
__________________
There is nothing worse than a gross exaggeration. |
#13 |
Registered User
I found that the 3 inch tires are quite heavy, but they have have higher sidewalls, meaning the distance between the ground and the rim (with the unicycle on the ground, inflated) is larger, so the actual outside diameter is much closer to 26inches than 24, even though it's on a 24 inch rim, and it's a 24 inch tire. this added sidewall, allows you to run lower pressures, and get more bounce out of your sidewall. this increases your hopping height, despite the added weight.
-Ryan
__________________
| Tags |
| alex, dx32, inch, rim, tire |
