Unicyclist Community
Reply
Old 2002-10-23, 01:28 AM   #1
Bruce Shannahoff
Newsgroup User
Posts: n/a
Adjusting Torker maic caps
Greg Harper wrote:
"The Stealth Torker I bought had overtightened maincap bearings which
I
adjusted at the shop to make sure they spun OK. They were fairly
severely overtightened so I showed them the technique to properly
adjust
them."
I was at another LBS, yesterday, and they had Torker unis. I noticed
that the 24" had some kind of bearing problem; either a bad bearing or
the main cap was over tightened. What is the proper procedure for
tightening them? While it is a very knowledgable shop about high end
racing and mountain bikes, I'm not sure they know what they're doing
with a uni.
Also, I like the "Stealth Torker" I've seen posted. Is it available in
24"?
Best regards,
Bruce Still Riding Two Wheels Shannahoff
Old 2002-10-23, 04:00 AM   #2
harper
768 - It's in your DNA
harper's Avatar
I've posted this before but I couldn't find it. Torque values are certainly not required to make this adjustment correctly.
With the main cap holder nuts on FINGER tight and the gap on each side of the holders equal, turn the wheel by hand and observe as it coasts to a stop. This is about how it should turn when the bearings are tightened correctly so remember what it looks like or about how long it takes. Now, tighten one side with a 10mm wrench evenly on each nut until it starts to bind, or coasts to a stop more quickly. This is too tight. Back it off until it just turns freely again. Now do the other side. This doesn't require an enormous amount of precision and if you do more than two iterations you're already getting too picky.
__________________
-Greg Harper
Destroying the climate by shutting down nuclear power plants, one by one, since 1979.
JC is the only main man. There can be no other.
"A fool on a unicycle is redundant" - J.D. Miller
harper is offline   Reply With Quote
Reply
Tags
adjusting, caps, maic, torker
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.05471 seconds with 9 queries
