Unicyclist Community
Reply
Old 2002-10-17, 09:53 PM   #16
nikkifrog
Officially Level 2! :)
nikkifrog's Avatar
Send a message via ICQ to nikkifrog Send a message via AIM to nikkifrog
I was thinking...
Is it worth it to get a really nice Freestyle Unicycle? I mean, if I get good enough at freestyle that I'm wanting to do big drops and stuff then I'd probably want a trials. But I don't know. If I get the Yuni for Christmas I can't get anything else (muni stuff, etc.) I was thinking...how bad would a Torker with the upgrade to Primo tire be? Then I could get the Velo saddle, put it on my Muni, and put the Miyata saddle that's on my Muni on the Torker. But would that be really stupid? Are Torkers very breakable? Can they hold up to any drops at all?
Thanks!
Nikki
__________________
"When I am afraid, I will trust in you. In God, whose word I praise, in God I trust; I will not be afraid. What can mortal man do to me?" Psalm 56:3-4
nikkifrog is offline   Reply With Quote
Old 2002-10-17, 11:02 PM   #17
Max_Dingemans
Pedal Pedal Crash
Max_Dingemans's Avatar
Send a message via AIM to Max_Dingemans
dont expect freestyle unis to last for drops, unless you find some magical indestructable cranks.
__________________
There is nothing worse than a gross exaggeration.
Max_Dingemans is offline   Reply With Quote
Old 2002-10-17, 11:07 PM   #18
nikkifrog
nikkifrog's Avatar
So should I just get the Torker and save $150? If I can't use it for rougher stuff anyway. Then I'll get a trials if I want to do a lot of hopping and dropping.
Nikki
__________________
Old 2002-10-18, 07:29 AM   #19
john_childs
Guinness Mojo
john_childs's Avatar
Quote:
Originally posted by nikkifrog
I was thinking...
Thanks!
Nikki
These kind of choices depend on where you're going to ride and how you plan on riding. Good freestyle unicycles can take a fair amount of abuse. You can do things like hop up a flight of stairs, practice long jumps, hop off a bench, etc. Just don't start jumping off picnic tables and doing big drops.
I love my freestyle unicycle for working on skills. Most freestyle skills seem easier to learn and practice on a freestyle unicycle. Freestyle skills are more difficult to do on a Monty tire. The fat Monty makes it harder to turn, the longer cranks also make freestyle skills more difficult, and the soft Monty tire will wear very quickly doing freestyle skills on pavement (you'll end up spending a fortune on new Monty tires). What the trials uni is good for is hopping and jumping. If you're going for skills development I'd go for the freestyle uni.
I don't know if you've seen the videos that Jeff Lutkus posted on the web, but he did all of his jumping around and fancy riding on a freestyle uni. He's complained about bent cranks and bent pedals so he hasn't done it all without equipment damage.
Something you might want to consider is seeing if unicycle.com has a standard Miyata wheel laying around. A Miyata wheel would have a Suzue hub but wouldn't be built by Kovachi. That might lower the cost. Then take the standard wheel to a local bike shop and have them tighten up all of the spokes. The spoke touchup will probably be about $15, but check with your local bike shop to find out for sure (shop rates for wheel work vary). After adding in the $15 for the wheel work I don't know if it would actually end up being less expensive.
The Suzue hub is the best option for a standard hub if you are planning on being a little rough on the uni. It's the strongest of the standard hubs. Stronger than the Torker hub or the Semcycle XL hub. The hub is not a part that you want to break because it means that you have to get the wheel rebuilt and that gets spendy (usually about $30 labor, $25 for the hub, plus about $15 for spokes if you need new spokes, plus the cost of a rim if you need a new rim). If you're going to break a part, bend a crank because a crank is cheaper to replace. The weakness in the Torker unicycle is the hub that comes with it.
Do you have a muni with a 24x3 or 24x2.6 tire? If you do, you can use your muni for jumping and dropping and trials type stuff and use the Yuni freestyle uni for skills development.
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2002-10-18, 04:27 PM   #20
harper
768 - It's in your DNA
harper's Avatar
Quote:
I think the exception to this is wheel walking. Last weekend I was practicing wheel walking on everything I owned (yes, David Kaplan, I used stilts on the giraffe) and found that wheel walking the SH MUni (with the 3" Gazz tire) was the easiest. That big, fat tire is hard to miss with your feet. There was something about the visibility of the huge 6.75" Shimano cranks that made them easy to see coming around to make the transition back to the pedals, also.
__________________
-Greg Harper
Destroying the climate by shutting down nuclear power plants, one by one, since 1979.
JC is the only main man. There can be no other.
"A fool on a unicycle is redundant" - J.D. Miller
harper is offline   Reply With Quote
Reply
Tags
freestyle, unicycle
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.06519 seconds with 9 queries
