Unicyclist Community
Reply
Old 2002-07-29, 07:43 PM   #1
Janne Himanka
Newsgroup User
Posts: n/a
Impressions of a beginning backwoods unicyclist
I thought I'd post some of my impressions of riding my new UDC Max
Traction 26x3. Living in northern Finland, I have easy access to
woods, little gravel roads, single track and so on. I picked a place
that I knew would have nice little roads in a pine forest (perhaps similar
to US fire roads, can anyone define these?), packed my gear and drove
there. The road was mainly sand, with lots of stones and roots. Three
nice lakes were nearby.
I wrote earlier that I had trouble freemounting with the new bigger
wheel, and Mikefule posted some suggestions. I tried his technique and
it was certainly an improvement. I could freemount successfully at
least half of the time using his method, a lot better than my previous
experiments with a rollback mount. Thanks Mike! I still couldn't mount
going uphill, and every now and then I would misplace my other
foot. But I think this is normal and will get better over time. I
noticed that I could fairly consistently start riding with a poor foot
placement and adjust it while riding.
Couple of days before I had done the air conversion to the Miyata
saddle, using a 12-1/2 x 2-1/4 inner tube. The conversion went
smoothly, except that I inadvertently squashed two clips when putting
the seat post back in place. This didn't seem to cause problems,
however, and I didn't bother taking it apart again. We'll see how it
holds up. The air seat is so much more comfortable. It also adds a
feeling of suspension, together with the 3" Gazz, so that it is a pure
pleasure to bounce over roots and stones.
I had a blast riding the sand road. I didn't have many UPD's, and I
always landed on my feet. My turning is still erratic. If I can
plan it ahead, and the surface isn't too difficult, I can usually
negotiate even pretty tight corners. But if I have to turn suddenly,
or the surface has bumps or inclines, I tend to lose it. I'll
definitely have to work on my turning in different conditions.
I noticed that either my aerobic fitness is miserable or I somehow
wear myself out being too tense. In any case, after riding half a
kilometer I was huffing and puffing like a locomotive. I suppose that
will improve with practice. After an hour of riding I was sweating
like a p... err, like an animal with lots of sweat glands. So I
decided to take a swim in the nice clear little lake nearby. After
that, some nice English pipe tobacco in a nice Italian pipe. It
doesn't much better than that.
Janne
Most of the girls, as they walked along, seemed % shem@erasethis.iki.fi
to be absorbed in silent prayer; but he supposed, %
on second thoughts, it was only gum they were %
thus incessantly ruminating. Gum, not God.
Old 2002-07-31, 08:41 PM   #2
sendhair
Human Fly bzzzzzzzzzzzzzzzzzzzzzzz
sendhair's Avatar
Location: Right here in Kyoto... well, just a second ago...
Quote:
originally posted by Janne Himanka: After an hour of riding I was sweating like a p... err, like an animal with lots of sweat glands.
HaHa! Very "PC" of you there, Janne! Besides, p(igs) don't have sweat glands, so that old cliche is actually an oxymoron. In the same category as drinking like a f... and eating like a b...
BTW... if you're concerned about your aerobic fitness, maybe you should cut out the smokin'... just a suggestion!
I know, I know... it's a pipe... you don't inhale... right?
Quote:
originally posted by Janne Himanka: ...nice little roads in a pine forest (perhaps similar
... fire roads, ... or lumber roads... or both?
sendhair is offline   Reply With Quote
Old 2002-08-01, 07:53 AM   #3
Janne Himanka
Newsgroup User
Posts: n/a
Re: Impressions of a beginning backwoods unicyclist
sendhair <sendhair.8oalm@timelimit.unicyclist.com> writes:
>> -originally posted by Janne Himanka:- *After an hour of riding I was
>> sweating like a p... err, like an animal with lots of sweat glands.*
I know (actually they do have sweat glands only on the end of their
snout). I think John Childs has schooled this newsgroup pretty well,
nobody dares write inappropriate things about swine physiology any
more.
I don't. In any case, I think that the relaxation and good vibes from
smoking the pipe offsets the small negative effects, seeing that I
smoke about 3 times a week. I wouldn't want to smoke a straight pipe
while riding a unicycle, though. A face plant could ruin a whole day.
Back to the hamster wheel called work,
Janne
Never trust a man with a blue trench coat + shem@erasethis.iki.fi
never drive a car when you're dead. +
Old 2002-08-01, 03:45 PM   #4
GILD
Waffle-Tosser, Time-bider and JCTK
GILD's Avatar
Location: the bustling metropolis of Nelspruitia, south africa
the level of tiredness u described could well have something to do with the amount of weight u expect your legs to carry
the more weight - the quicker u will feel really tired
on uneven terrain it is more difficult to maintain more weight on the seat and to use the legs 'only' for pedalling
as u mentioned, u will get better at it
your excursion sounds like fun
GILD is offline   Reply With Quote
Reply
Tags
backwoods, beginning, impressions, unicyclist
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.06958 seconds with 9 queries
