#1 |
Newsgroup User
Posts: n/a
I wonder if any of you can give me some advice. I have a United trials unicycle
with a Monty wheel and am constantly having problems as the bearing has moved in on the axel causing the wheel to rub against the frame. The guys at my club think that I need a new frame, possibly a Sem. I don't really want to have to spend too much money, but need to do something as I want to do lots of trials and just can't keep the wheel centred. I also don't want to make the unicycle too much heavier. I have heard people say that Sem frames tend to buckle with a lot of hopping. Any advice would be appreciated. Thanks, Jeff |
#2 |
Newsgroup User
Posts: n/a
Re: Advice on Trials Frame?
One bearing has probably moved out, not in, as the bearings can't move in past
the shoulder on the Suzue hub. The bearing walks because the frame is too wide. As in when you put the frame on, you have to squeeze the fork legs together a bit to get the bearings to drop in the slots. Then as you ride it, the fork legs relax as they pull one bearing out on the axle. The fix is to take the frame off and squeeze it together enough to permanently bend the legs together a bit. So that they are either neutral or slightly too narrow for the axle. Then pound the bearings back on, up the the shoulders, and put the uni back together. Chris Groves wrote: [color=blue]>[/color] [color=blue]> I wonder if any of you can give me some advice. I have a United trials[/color] [color=blue]> unicycle with a Monty wheel and am constantly having problems as the bearing[/color] [color=blue]> has moved in on the axel causing the wheel to rub against the frame. The guys[/color] [color=blue]> at my club think that I need a new frame, possibly a Sem. I don't really want[/color] [color=blue]> to have to spend too much money, but need to do something as I want to do lots[/color] [color=blue]> of trials and just can't keep the wheel centred. I also don't want to make the[/color] [color=blue]> unicycle too much heavier. I have heard people say that Sem frames tend to[/color] [color=blue]> buckle with a lot of hopping. Any advice would be appreciated.[/color] [color=blue]>[/color] [color=blue]> Thanks, Jeff[/color] |
#3 |
Newsgroup User
Posts: n/a
Loctite high strength sleeve retainer 640 will keep the bearings from slipping
on the axle. The sleeve retainer is designed to hold press fit parts. My Coker and my Pashley muni had problems with the bearings slipping outwards towards the crank. I pulled the bearings off, applied some Loctite sleeve retainer, put the bearings back on and no more problems. The bearings stay put now like they should. Even with the Loctite it is still possible to remove them when it is time to replace a bearing so even though it says high strength it is still not difficult to break the bond using a bearing puller. The hard part is finding the sleeve retainer. Some auto parts stores have it and some industrial supply stores have it. The Loctite thread locker is easy to find, but the sleeve retainer takes a little more searching. john_childs [color=blue]>From: "Groves" <groves@pobox.com>[/color] [color=blue]>[/color] [color=blue]>I wonder if any of you can give me some advice. I have a United trials unicycle[/color] [color=blue]>with a Monty wheel and am constantly having problems as the bearing has moved[/color] [color=blue]>in on the axel causing the wheel to rub against the frame. The guys at my club[/color] [color=blue]>think that I need a new frame, possibly a Sem. I don't really want to have to[/color] [color=blue]>spend too much money, but need to do something as I want to do lots of trials[/color] [color=blue]>and just can't keep the wheel centred. I also don't want to make the unicycle[/color] [color=blue]>too much heavier. I have heard people say that Sem frames tend to buckle with a[/color] [color=blue]>lot of hopping. Any advice would be appreciated.[/color] [color=blue]>[/color] [color=blue]>Thanks, Jeff[/color] _________________________________________________________________ Get your FREE download of MSN Explorer at http://explorer.msn.com |
| Tags |
| advice, frame, trials |
