Unicyclist Community
Reply
Old 2019-09-28, 07:04 PM   #1
m00ms
Unicyclist
uni geezer freemount
hi all,
just wondering if anyone here has seen or used uni geezers cinder block freemount video for practice and curious to hear if it helped you out.
after many years doing roll back freemounts my freemount is ok but not the best i would like to improve and get rid of bad habits and found his video which makes sense but feels alien to do!!
hopefully i have linked the video
https://youtu.be/YDziHTXuA-w
m00ms is offline   Reply With Quote
Old 2019-09-29, 12:21 AM   #2
OneTrackMind
Unicyclist
Basically it is a one legged jump mount. It needs extreme explosive power in one leg.
I use the mount that UniMyra shows in this video. I have heard it called a one footed still stand.
https://www.youtube.com/watch?v=yqWt...ature=youtu.be
__________________
Triton 36" + 29" | KH 29" | KH 26" | KH 27.5" Muni | Nimbus eSport Race 24" | Torker LX 24" | Qu-Ax Luxus 20" | Qu-Ax Profi 20" | KH / Impact 19" hybrid
OneTrackMind is offline   Reply With Quote
Old 2019-09-29, 01:54 AM   #3
JimT
Unicyclist
JimT's Avatar
I used a block when I first started working on freemounting my 36er. I used it for a day or two with progressively smaller blocks till I could mount without a block. Once I managed to freemount once without the block I simply repeated a thousand plus times (without a block) to get relatively proficient. Once you can do at least one freemount without the block there would be no benefit in practicing with the block anymore. It is simply a stepping stone on the learning path to constantly freemounting without any aids.
JimT is offline   Reply With Quote
Old 2019-09-29, 12:25 PM   #4
DrD
Unicyclist
I tried Terry's technique and I think it helped me at the time. I didn't do it with a paper plate or anything, I might have have used a concrete block though as a platform. I think it was a useful exercise though.
In hindsight, I think that what was best for me was to just think of hopping up while keeping my back foot in the same position in space rather than not putting weight on it. In the end of the day it is the same thing but thinking of it that way seemed somehow easier for me.
I've found that thinking while mounting usually makes things worse for me but I suppose you have to consciously think about what you are doing when you are trying something new. What I tend to do now for my 29" and 32" is pretty much along the lines of UniMira's 36" mount in the video above, except that I start with the back pedal about twenty-five or twenty to, with my hand on the handle, rock forward, and lever myself up. Trying to analyse it usually results in failure, but I think my initial freemount successes (on my 24"), and hence what I do now, were helped by Terry's video and that probably lives on in my subconscious!
DrD is offline   Reply With Quote
Old 2019-09-29, 05:45 PM   #5
lowerstackmac
Unicyclist
I use Terry’s mount exclusively for my 26”. I also did not practice using the block or plates. It works very well for me, but I had difficulty getting used to not putting ‘any’ weight on my rear foot/peddle. I place my left foot at 7 o’clock and my right at the 1 o’clock positions. If you practice on even the slightest downgrade it is much easier to perform the maneuver. I would suggest you try it on a decline to get the feel for it then try it on flat ground. Good luck.
lowerstackmac is offline   Reply With Quote
Old 2019-09-29, 06:02 PM   #6
zebra
Unicyclist
hi all,
I found this video really useful for learning to freemount mt 20", but i use a wheel assisted for my 26"
zebra is offline   Reply With Quote
Old 2019-09-29, 07:33 PM   #7
finnspin
one wheeled cycling
finnspin's Avatar
hi all,
I used this method to teach people. It helped some, but not all. Worth trying it out though.
I don't think it's point is to say: don't put any weight on your first pedal by the way. But compared to a rollback mount, you use a lot less, and the method in the video can help to get used to that. As DrD said, it's about keeping the foot in the same position.
__________________
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. -Douglas Adams.
finnspin is offline   Reply With Quote
Old 2019-09-29, 08:05 PM   #8
slamdance
Unicyclist
You got that right..."one leg explode"
Yes. To me it's like a one foot kick up like Onetrackmind mentioned. How many of us can hop 1 ft high on one leg while holding a saddle?
I've been riding for almost 3 years now, and I just totally rely on rock back mount which I've evolved from being able to idle.
I "tried" the 3/9 o'clock "traditional mount" but quickly gave up on it. At the same time riding and learning to idle formed my current mount. I will only try to practice the trad mount either on grass, or so. I have at least one incident where I failed and the unicycle kicked out under me and I went straight down.
To me the "zero grav" foot on pedal "ready to kick out" is a trick that requires perfect body lift to "pin head" saddle balance point. At the same time, you cannot really stall, you have to start leaning forward and pedaling at the same time. I would be really impressed to see a rider be able to free-mount like this + stall and hop. Unimyra is doing just that on his video, but he is a "master". Again, this is more or less a "jump mount" an advanced move.
Anyways, I think the "key" is leg strength. If you are "only/barely" strong enough to hop with one leg to that height, then you need 100% power from that single leg and you have one attempt before fatigue. However, if you have strong legs say(squat your body weight or more), then you need less power. It will be easier to practice many attempts before reaching fatigue, which kills your accuracy/touch. So possibly, some gym time or focused quad strength building is what you need to do additionally, if you want to master this. That's what I am doing. (if I can ever work through my joint pains). Also, traditional 'extreme' Bicycle riding speed/distance/elevation will develop crazy power quads. (JimT's progressive block training, see above, looks pretty good and figured out a systematic way to get there)
I know a lot of you "experts" who may not be very strong are saying, it doesn't take muscle. That's because you have that perfect touch to get up and going. Try switching foot. Not so easy is it? Unless...ofcourse, you have already mastered that.
Anyways, my point is for any newbie who are having trouble. Get stronger, first. Or consider the "non-traditional" rock back. Keep on.
slamdance is offline   Reply With Quote
Old 2019-09-30, 06:29 PM   #9
m00ms
Unicyclist
thanks onetrackmind for the link which i have seen before but still struggle with.
my general riding is ok but my bad habits mount is going to be tricky to get past i think!
i want my mount to slow and controlled like that with little or no movement from the unicycle.
Old 2019-09-30, 08:37 PM   #10
Tinkerbeau
Unicyclist
Quote:
That's the problem for me; the explosiveness in the legs is gone - or maybe I am just too heavy and not fit enough. I find that the slightest curb - even a grass edge in the park or a small stick - is needed for me to static mount.
2-step walking mount seems much easier to hoist the body up but has its own challenge in coordinating limbs.
As a newbie, I found freemounting from a pavement curb the perfect mix of static wheel, no backward motion and control of placing the 2nd foot.
Tinkerbeau is offline   Reply With Quote
Old 2019-09-30, 08:47 PM   #11
Canoeheadted
Unicyclist
Start learning other mounts from different positions instead of using one mount exclusively.
Using just one mount keeps you in that gutter and prevents you from learning anything outside of it.
Learn smarter, not harder.
It's a longer road but you will be a better rider for it.
Canoeheadted is offline   Reply With Quote
Old 2019-10-01, 10:27 AM   #12
Setonix
Unicyclist
You say that, but my static mounts always get me on top of the unis. Only with the 36" especially when tired, the static mount becomes hard, but persistence always prevails. The thought of having to walk back is good stimulation.
Setonix is offline   Reply With Quote
Old 2019-10-01, 01:05 PM   #13
elpuebloUNIdo
Viva la revolucion!
I agree. Try different mounts in different positions. Regarding the words smarter and harder, however, practicing a bunch of mounting variations may sound to some riders like a harder approach. They may prefer to identify a single, correct method, then practice that method, thinking that is smarter approach. IMHO, we need to avoid this kind of linear thinking when it comes to learning unicycling. I can understand why someone might approach mounting the 36" this way. For practicing variations on mounting, nothing beats a 20".
elpuebloUNIdo is offline   Reply With Quote
Old 2019-10-03, 03:58 AM   #14
slamdance
Unicyclist
Yes...Harder...not Smarter!!!
If we were smart the science of nature(physics) would tell us DON"T DO IT!!!
However, we(at least me) follow the tradition of Insanity.
Einstein said...Insanity = doing the same thing over/over, but expecting a different outcome. Guess, what Mr. Einstein...f-u..and the constraints of physical forces, geometry and balance. We... can ride!!!
My point is don't be afraid to adopt the attitude, let's get dumber not smarter!!
It's more fun. Keep on.
(actually...if the physics were "accurately" modeled with a free body diagram by an actual unicycle rider...the science is on our side...but let's continue this in another string)
Old 2019-10-05, 10:36 AM   #15
m00ms
Unicyclist
ive had a couple of pratice sessions now doing 3/9 o clock mounts against curb and then using a block of wood behind the wheel.
against a curb is great and im getting there with the block,im tall and long legged so doing block mount on my 26 feels like a long way up!
i can feel i am putting lots of weight on the back pedal so hopefully with time and practice i can get that weight down.
bad habits are hard to get rid of but im going to get this!!
Reply
Tags
freemount, geezer, uni
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Monster Uni: Post Your Fat Uni Here ! Siddhartha Valmont General Unicycling Discussions 141 2017-01-26 10:00 AM
Freemount and dismount 24" uni Alucard Unicycling Articles and Tutorials 46 2014-07-15 03:20 AM
How To Uni When You Can't Uni? adreanaline General Unicycling Discussions 7 2013-11-24 05:35 PM
Ever been uni-catfished (or uni-Te’o-ed)? Kram Costello General Unicycling Discussions 17 2013-01-22 04:42 PM
Borrowing Son's Uni - looking for first uni DrDuktayp General Unicycling Discussions 16 2013-01-18 03:29 PM
Powered by vBulletin®
Copyright © 2001-2019 Gilby
Page generated in 0.12954 seconds with 11 queries
