Unicyclist Community
Reply
Old 2011-03-27, 01:43 AM   #1
madams
Unicyclist
free mounting on my 29er
Did my first free mounting on my 29er tonight....boy was that painful. I have to get shin guards ugh. I wear a helmet, wrist guards, knee pads, and elbow pads but never needed shin guards until tonight. I landed about 3 out of maybe 100. But it is a start. I watched so many youtube videos on freemounting. I tried quite a few but came to the conclusion (for me) to grab the tire while rolling forward. Freemounting is definitely a necessity if you want to ride long distances on a rail trail....
Mike A.
madams is offline   Reply With Quote
Old 2011-03-27, 01:54 AM   #2
Steve
Supreme Commander
I haven't tried grabbing the wheel. When I mount mine I do just a bit of a rolling mount where I start with the pedals about the 4 and 10 clock positions with the lower one AWAY from my foot (i.e. if I am mounting with the right foot down the right pedal is the one in the 4 o'clock position) roll forward a little. Plant my lower foot on the lower pedal, stopping the wheel but my momentum brings me up and over. While I am going over I try to plant my foot on the top pedal and if I hit it it is enough to get the pedals out of the 6 and 12 position so I can start riding away. Usually if I don't make it it is because I miss the top pedal and end up going over the top with the unicycle ending up behind me. Whatever works for you is good but that is how I do it.
Steve is offline   Reply With Quote
Old 2011-03-27, 02:08 AM   #3
jtrops
Unicyclist
How long are your cranks? That would change the advice I have of what kind of mount to recommend.
With my 29er I was able to do a rollback mount with 125's even as a very new rider. On my Coker I use a static mount or a rolling mount with 140's. If the wheel is moving a bit as I get on it's much easier to get the momentum to become stable.
It is true that if you are setting out for a long ride it's nice to be able to freemount. You never seem to have a tree, or fence right when you need it.
__________________
"A properly ridden unicycle is like an object in orbit: constantly falling but never landing." -Diogenes
jtrops is offline   Reply With Quote
Old 2011-03-27, 04:45 AM   #4
NotSoYoungOne
One wheelin' the Wasatch Front
NotSoYoungOne's Avatar
I use a modified static mount. My down pedal is at about 7:00-7:30 and up pedal at 1:00-1:30. I always adjust the up pedal so it is in line with the crank arm to give my foot the best chance for a nice initial position. Just like a static mount I put little to no weight on the down pedal, but instead of keeping the wheel from moving I allow the wheel to roll forward quite a bit as I step to the up pedal. When my foot hits the up pedal the cranks have moved to nearly 9:00 and 3:00 or sometimes even a little further and my upper torso is ahead of the seat tube so I get a good strong start.
I also use the rolling mount, and the tire-grab mount, but neither very often.
Hope this helps.
__________________
If you always do what you always did you'll always get what you always got.
NotSoYoungOne is offline   Reply With Quote
Old 2011-03-27, 10:41 AM   #5
jojoxie
Unicyclist
jojoxie's Avatar
Quote:
Mike A.
Hi madams, One week ago I was where you are with mounting my 29er. I wear the KH shin protection which give me confidence to attack the rolling mount. I practiced on grass which also helped confidence....soft landings .
For me confidence and positive visualisation are everything. Good luck, Joseph.
__________________
Facebook
Website
jojoxie is offline   Reply With Quote
Reply
Tags
29er, free, mounting
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Returning back to riding my unicycle ....question on crank length ? Tim Coin General Unicycling Discussions 11 2012-12-25 02:56 PM
Wet Whirl on my 29er Unicycle & Dancin' Billy Shug Unicycling Videos 13 2011-04-11 01:14 PM
riding down hill on my 29er madams General Unicycling Discussions 8 2011-03-26 08:17 PM
Mounting the 29er (with a guy question) Phuni General Unicycling Discussions 15 2004-09-01 09:18 PM
Free mounting UniManiac General Unicycling Discussions 14 2004-04-15 04:22 PM
Powered by vBulletin®
Copyright © 2001-2016 Gilby
Page generated in 0.07846 seconds with 11 queries
