Unicyclist Community
Go Back   Unicyclist Community > Unicycling Discussion > Unicycling Articles and Tutorials
Reply
Old 2017-04-06, 04:08 AM   #1
caseytronic
Unicyclist
caseytronic's Avatar
KH One / KH Zero Rear Bumper Mods
Quick Review / How-To: Bumper Mod for KH Zero / KH One
Why:
Many of us really like flat profile and shape of the KH Zero / KH One saddle, but due to the shape, the back of the saddle is exposed to scuffing above the rear bumper - especially on larger wheeled unis where it hits the ground at a greater angle on many UPDs. One solution is to fabricate and extra guard for the part above the rear bumper.
Several folks here on the forums have come up with some other good bumper mods to add an extra guard in the KH Zero thread: http://www.unicyclist.com/forums/sho...d.php?t=115830
I thought it might be good to start a separate thread for sharing ideas on this type of mod as it can improve a popular saddle and will be easy to find.
My Mod:
To kick it off, I came up with an inexpensive solution with easily available materials so I thought I'd share it here.
I had lawn edging in my shed - it is a tough plastic strip 5 -6 inches (15mm) high and comes in lengths of 10 to 50 feet. The top of the edging is formed into tubing. The edging is flexible and can be mounted to the bumper bolt holes. The lower flat section can then be bent and fitted between the saddle and bumper so the top tubing portion emerges above the bumper to cover the back of the saddle.
I have ridden several weeks using this mod - it works and so far I have not had any issues with it.
Since the tubing is hollow, it can also be used to tie down a bag mounted on the rear of the saddle by running cord through it.
Materials:
KH One / KH Zero Saddle
Lawn Edging / Landscape Edging - 4 to 5 Inches Deep x 10 - 50 ft - available in your shed or most hardware / home stores - must be at least 4 inches deep (10 cm)
Edging Compatible Cutting Tool (Small Hacksaw / Tin Snips / Heavy Duty Scissors / Knife)
Metric Hex Key Set
Steps:
1. Preparation / Disassembly:
- Remove Rear Bumper from KH One / KH Zero using Metric Hex Keys
- Cut a section off of the lawn edging strip - The length of the cut section should be slightly narrower than the rear bumper width (enough to protect, but not scuff your legs). If the bottom of the edging has ridges or tubing, cut them off without removing any of the flat part of the edging. The tubing at the top of the edging should remain. You need at least 4 inches (10 cm) between the bottom and the top of tubing portion.
2. Shaping The Edging To Fit The Saddle/Bumper:
- Line up the flat bottom of the edging with the bolt holes on the rear bumper. Drill / Ream bolt holes in the edging using the rear bumper as a guide.
- Cut the edging to match the shape of the rear bumper on the inside edge near the bolt holes. This will allow the bumper to bolt on tightly with the edging underneath.
- Trim the edging down between the bolt holes and the tubing so it narrows down to the bolt holes.
3. Re-assemble Saddle with Edging Between Bumper and Saddle:
- Put bolts through rear bumper then through the holes in the edging (edging should be under the bumper).
- Bend the edging to fit the profile of the bumper. It should go down into the lip of the bumper and up the back of it.
- Place the bumper with attached edging back underneath the saddle and align the bolts. Carefully thread the bolts into the saddle nuts - adding the edging makes it slightly harder to line them up. Tighten the bolts slowly and evenly, alternating between them until the bumper is tight. The bumper will not tighten the whole way back due to the edging, but it will be close.
Paranoid Disclaimer:
I make no guarantees that this mod will work for you. You might find it will void your saddle warranty, destroy your saddle, or unleash some horrible plague on mankind, who knows. Whatever the outcome, I claim no responsibility for it. I'm just sharing what worked for me.
Enjoy
caseytronic is online now   Reply With Quote
Old 2017-04-06, 04:11 AM   #2
caseytronic
Unicyclist
I apologize, as apparently my hideous toenails photo-bombed one of the pics. Hopefully you can work your way around them.
Old 2017-04-09, 01:20 AM   #3
caseytronic
Unicyclist
Bumper Mod Dimensions
Here are a couple of pics of the final bumper mod product with measured dimensions.
roughly 4"/10 cm x 4.75"/12cm
these dimensions allow the tubing to cover almost all of the flat portion above the stock bumper.
Old 2017-04-13, 03:21 AM   #4
caseytronic
Unicyclist
Better Shape for SIF Work
I put this mod on my 24, which I am currently using to practice my Seat-In-Front hops and riding.
Turns out the bumper mod using the dimensions in the last post was a bit too wide and scraped the inside of my legs when riding SIF.
Found that if I narrowed it down about 1/2 inch on each side it stopped scraping me and still protects the saddle fairly well.
When you do this the finished piece of plastic does not flare out at the ends but is a straight cut up from the bottom near the bolt holes to the tubing at the top.
Reply
Tags
bumper, mods, rear
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
[For Sale: USA] KH Zero Saddle pierrox Trading Post 1 2016-12-11 11:15 PM
[For Sale: USA] Stadium and KH Zero saddles UPD Trading Post 0 2016-10-06 04:07 AM
[For Sale: North America] KH Fusion Zero, black KH pivotal seatpost, black KH clamp, & purple pivotal seatpost bwrightback Trading Post 9 2015-08-12 10:41 PM
KH Fusion Zero Question one4all General Unicycling Discussions 9 2015-07-30 03:43 AM
[Wanted North America] KH Fusion Zero Saddle bwrightback Trading Post 15 2014-09-02 02:35 PM
Powered by vBulletin®
Copyright © 2001-2016 Gilby
You Rated this Thread:
Page generated in 0.52574 seconds with 12 queries
