Unicyclist Community
Reply
Old 2019-01-12, 01:13 AM   #1
Killian
Good enough: enemy of perfection
Killian's Avatar
ISIS hub in stamped bearing holders
Hello, it's been a while.
So I've always heard that stamped bearing holder frames which are for square taper hubs, will typically fit an ISIS hub.
Well, on this premise, I purchased one of the few remaining superwide non disk ISIS hubs from compulsion, and a Nimbus Titan frame. Now that I have everything in hand, it looks like the bearings don't seat all the way down into the holder.
Rather, the bearing sits on two points within the bearing holder.
Is this what people are talking about when they say that they work together? Seems a bit sketchy...
I'll post pics later.
Thanks.
__________________
"I used to watch Highway Patrol whittlin' with my knife..." - NY
Killian is offline   Reply With Quote
Old 2019-01-12, 01:45 AM   #2
Killian
Killian's Avatar
Never mind. Just realized that it's because the stamped bearing holders are stamped a bit narrow. One of them is wider than the other and it fits just fine.
So I'll gently massage the other ones open and roll with it.
__________________
Old 2019-01-12, 09:49 PM   #3
jaco_flans
Trials & Muni!
jaco_flans's Avatar
Send a message via MSN to jaco_flans
Either way, even if it ''fits'' as we say, it doesn't touch the bottom of the bearing holder. The stamped frames are usualy made for 40mm bearings. I've used a few and worked fine as long as you dont overtighten the bearing caps.
__________________
Jakob F.
jaco_flans is online now   Reply With Quote
Old 2019-01-12, 11:14 PM   #4
MrImpossible
Unicyclist
MrImpossible's Avatar
Quote:
The regular non-ISIS bearings don't touch the bottom of the bearing holder, either. I think the ISIS ones just sit at a different spot.
When I put an ISIS wheel in my cheapo Avenir frame it seemed to fit just as well as the original wheel.
MrImpossible is offline   Reply With Quote
Old 2019-01-14, 01:32 AM   #5
jaco_flans
Trials & Muni!
jaco_flans's Avatar
I haven't had a stamped frame in my hands for too long hahaha. I didn't know even the 40mm bearings wouldn't sit completely in it.
Either way, bearing holders, machined or not, dont overtighten them. Just gotta be more careful with stamped holders.
__________________
Jakob F.
Reply
Tags
bearing, holders, hub, isis, stamped
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
42mm ISIS Bearings in stamped housings Killian General Unicycling Discussions 5 2015-08-04 03:10 PM
[Wanted Europe] ISIS steel frame (42mm bearing holders) dmacuni Trading Post 0 2015-05-04 01:55 PM
[Trade] KH ISIS hub for 48h ISIS hub jaco_flans Trading Post 0 2012-04-04 09:58 PM
holders of bearing holders? goldenchicken II General Unicycling Discussions 16 2005-08-11 07:09 PM
Bearing holders mgrant General Unicycling Discussions 13 2004-02-11 03:53 AM
Powered by vBulletin®
Copyright © 2001-2019 Gilby
Page generated in 0.08354 seconds with 11 queries
