Unicyclist Community
Go Back   Unicyclist Community > Non-unicycling Discussion > Just Conversation & Introduce Yourself
Reply
Old 2014-01-09, 06:26 PM   #1
wilsonov7
Rookie
hello from the south
http://www.youtube.com/playlist?list...uNaDTuPmJVqNcB
Hey Everybody, I'm Jon from Albany, GA. I've chronicled a good bit of my unicycle learning adventure on my YouTube channel. Most of the videos are under 10 seconds I started back around 12/09/2013 and I'm at the 30 day point right now and I'm finally getting it...a little. This is hard but so fun when you get up and balanced and moving!
wilsonov7 is offline   Reply With Quote
Old 2014-01-09, 09:47 PM   #2
wilsonov7
Rookie
tires
also, has anyone put a 2.1" Primo Wall on a Torker CX 20" yet? Just wanna see if it fits.
Old 2014-01-09, 09:56 PM   #3
Uni Lateral
Cyclophobic
Uni Lateral's Avatar
Looking good Jon...I think I was at a similar level at day 30...maybe with a bit more huffing and puffing as I tried to push myself further.
I loved the little self-congratulatory cheer...I still do those all the time as I achieve new things on the unicycle. Keep up the good work
UL
Uni Lateral is offline   Reply With Quote
Old 2014-01-10, 02:18 PM   #4
wilsonov7
Rookie
UL
I have to keep myself motivated as I'm both the team and cheerleader
Old 2014-01-10, 09:43 PM   #5
coyote29er
Unicyclist
coyote29er's Avatar
Ah yes, I'm reminiscing on my "cling to the chain link fence for dear life days." Way to go Jon! And more dancing... Really, explore the space! (a more-cowbell reference.
coyote29er is offline   Reply With Quote
Old 2014-01-10, 09:49 PM   #6
wilsonov7
Rookie
Quote:
More dancing, seriously? Well, I'll make it job no. 1!
Old 2014-01-10, 09:49 PM   #7
wilsonov7
Rookie
Any advice on the free mount? I have no clue what I'm doing. At all.
Old 2014-01-11, 12:23 AM   #8
LargeEddie
Measure once, trim to fit
LargeEddie's Avatar
You're doing great for one month. Keep it up!
Quote:
I haven't tried it but I'd bet it'll fit. 20" unis mostly seem to have lots of tire clearance and 2.1" isn't especially large anyway. How big is the original tire and how much room is there above and beside it?
It'll come. Still early days. I didn't get it for the longest time. Curb mounting was a good way to work up to it and to practice the low-speed balance skills I needed to ride away from any kind of mount, and also a good way to re-mount out in the real world until I had free mounting down.
The thing I noticed in your video is that you don't have the seat firmly planted in your crotchal zone. That's a big part of it. You can use your hips to drive the unicycle forward and resist the foot on the back pedal. It's a dynamic thing. It clicked quickly once I got it but I needed a long time (ie, months) to get it.
LargeEddie is offline   Reply With Quote
Old 2014-01-11, 05:53 PM   #9
wilsonov7
Rookie
I am going to try to curb mount. thanks for the tip! I believe that the current tire is a 1 point 75 inch wide Kenda.
Old 2014-01-11, 07:13 PM   #10
LargeEddie
LargeEddie's Avatar
OK, so if you've got a quarter inch or so between the sidewalls and the frame legs, it should be alright. That's a pretty skinny tire if it's 1.75". (That's what came on my starter uni too.) More width gives you a margin to run lower pressure without the rim bottoming, which helps a lot for an adult rider over bumps and cracks and things found on normal pavement.
Old 2014-01-11, 08:46 PM   #11
wilsonov7
Rookie
first successful free mount...day 32
After about 3000(well, 13) tries today, I finally made a free mount. I'm finding it easier to mount it with the crank angled farther towards the ground and kind of rolling backwards just a bit. I tried the horizontal crank/jump with the other leg method over and over again. After this quick video, I did about 3 more successful free mounts followed by roughly 25 to 30 revolutions of easy riding, at which pointed, I ran out of breath and started getting cramps in my right quad. I thought launching off assisted by a wall was impossible up to about day 25, so maybe this is just a matter of perseverance, right?
Old 2014-01-12, 11:27 PM   #12
LargeEddie
LargeEddie's Avatar
Congratulations! That's a great achievement. I'm still trying different styles of mounts with different crank angles and different amounts of rolling either way. And when you get bored with that, try it with your feet reversed.
And yes, the burning quads phase comes next. Some of that is toning your legs so they last longer, more of it is getting your weight onto the seat instead of standing on the pedals as you ride. A whole lot is also getting smoother so you aren't having to make as many corrections with the pedals. But it all comes with time and practice, so keep up the good work.
Old 2014-01-13, 02:47 PM   #13
wilsonov7
Rookie
Thanks! I'm becoming obsessed with mastering the free mount. If I don't make it within the first 10 attempts, though, I gotta grab a wall or something. It has to stay fun!
Old 2014-01-21, 07:45 PM   #14
wilsonov7
Rookie
I just made a leap of faith and got a 24" Nimbus Muni. I just put it together. This tire is BIG!
Old 2014-01-29, 01:27 PM   #15
wilsonov7
Rookie
I'm now making about 8 out of 10 free mounts. When I do bail, it is usually right after getting up, so that is progress(I suppose!).
Reply
Tags
south
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Hello from the Great White North muni365 Just Conversation & Introduce Yourself 5 2013-07-13 09:26 AM
Hello to those from the BBC News Website! mowcius Just Conversation & Introduce Yourself 5 2012-05-31 04:56 PM
Hello from NJ. Jake95 Just Conversation & Introduce Yourself 2 2012-05-29 02:46 PM
Powered by vBulletin®
Copyright © 2001-2016 Gilby
Page generated in 0.32390 seconds with 11 queries
