Unicyclist Community
Reply
Old 2003-04-30, 03:31 AM   #1
keaner
unicycler
keaner's Avatar
KH24 tiawan+ profile wheelset
I'm just heading out to the shop to install a profile wheelset on a kh24 ,looks like it's going on the grinder,gotta clean off some of that extra metal around the bearing holders ,it'll go.
I can't see any other way to make it fit ?
Can you??
keaner is offline   Reply With Quote
Old 2003-04-30, 04:11 AM   #2
tomblackwood
Tailgate at your own risk...
tomblackwood's Avatar
Re: KH24 tiawan+ profile wheelset
Can you??
I'm not sure, but you should probably read through the whole thread at the following link before you do anything drastic.
T
http://www.unicyclist.com/forums/sho...an+AND+Profile
tomblackwood is offline   Reply With Quote
Old 2003-04-30, 05:16 AM   #3
john_childs
Guinness Mojo
john_childs's Avatar
Can you??
Dont grind anything on the frame!!!
There is no need to grind anything to be able to fit a Profile hub in the frame.
If you have a Taiwanese KH24 frame then you'll need to shim up the bearing holders to fit the Profile bearings. Read the link that Tom Blackwood provided for more details. Also, contact unicycle.com to find out if they have any custom shims for the bearing holders. If they don't have shims you can use a soda can to make a shim.
Unless you are talking about grinding the flying saucer shaped spacer that Profile supplies. That spacer can get in the way and grinding it down would improve clearance. I actually don't use the flying saucer spacer and instead use extra aluminum Profile washers instead.
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2003-04-30, 09:58 AM   #4
U-Turn
Small fish, small pond
U-Turn's Avatar
Just out of curiosity, has anybody put a Profile hub setup in a Pashley frame and bearing holders?
__________________
Weep in the dojo... laugh on the battlefield.
-- Dave Stockton
U-Turn is offline   Reply With Quote
Old 2003-04-30, 01:50 PM   #5
muddycycle
Nonchalance
I just got some KH 140 mm cranks, they came with a nice pair of shims.
__________________
"What can possiby mystify a madman?"
Hegira: Greg Bear
muddycycle is offline   Reply With Quote
Old 2003-04-30, 04:19 PM   #6
jason
Just some guy
jason's Avatar
Send a message via AIM to jason Send a message via Yahoo to jason
kaeaner,
I'd like to hear how the project goes and maybe you can show us all an image or two when you're finished?
As I understand it, the bearing holders on the KH24(tw) are slightly larger than the Profile bearings and thus the bearing holders require shimminng and not grinding.
Cheers,
Jason
jason is offline   Reply With Quote
Old 2003-05-01, 03:08 AM   #7
keaner
unicycler
keaner's Avatar
kh24 tiawan +profile wheelset/grind it
I've triied to shim up the bearings ,not going to work ,from what I can see I just have to shave the bearing holders down a 1/4" on the out side edge that hold that redundant steel dustcap thingy ,whos idea was that? ,haha and the profile hub will drop right in ,
that shim idea is not possible ,I know Kris the man said it himself but I doubt it's possible.Until I see one done, It's not gonna work
A minor grind should do the trick .
I'll post a pic when it's done .
Reply
Tags
kh24, profile, tiawan, wheelset
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright © 2001-2019 Gilby
Page generated in 0.05926 seconds with 10 queries
