Unicyclist Community
Reply
Old 2003-02-15, 01:48 AM   #1
John Hooten
Newsgroup User
Posts: n/a
KH24 creaking
I had my KH24 out on it's 5th ride today, halfway through the left crank
started to creak. I stopped to make sure that everything was tight - it
was - but the creaking continued. It is not unlike the creak from a
profile crank. Has anyone else had this problem? Is it a problem? Is
this something endemic to splined cranks? Is there anything I should do
to check the crank and axle?
John Hooten
Old 2003-02-15, 01:56 AM   #2
Sofa
you - pee - dee
Sofa's Avatar
i bet it's not the cranks, i bet it's the spokes. chances are, the spokes are loose.
it would sound like the crank, because you'd get the creak with each power stroke
i don't know if this is recommended, but what i do in this situation, is turn every spoke 1/4 turn tighter. (still creaking, try an 1/8 turn, and so on) it solves it, but may do something bad to the tension (although I've never noticed anything bad)
Check for very loose spokes first, of course.
__________________
Happy Life Day
Sofa is offline   Reply With Quote
Old 2003-02-15, 02:18 AM   #3
Jason
Newsgroup User
Posts: n/a
Re: KH24 creaking
> started to creak.
Greetings John,
Frank A. addressed this issue in his review of of the KH24. He used some
'anti-seize' on the cranks to resolve the issue. I posted earlier to
find out what brand was used because I have KH24 on the way and I want
it to hum like a well oiled machine.
I would ike to hear your opinion of the KH24 if you some time.
Cheers,
Jason
Old 2003-02-15, 02:23 AM   #4
Jason
Newsgroup User
Posts: n/a
Re: KH24 creaking
Sorry, I rushed my typing...
> I would like to hear your opinion of the KH24 if you have some time.
Jason
Old 2003-02-15, 04:17 PM   #5
Erin
wheeler
Erin's Avatar
Good for you to be getting a KH24 Jason. You will have fun with your new MUni for sure!
Erin
__________________
"If you have no goals, you can accomplish almost anything!" Slugbath
Erin is offline   Reply With Quote
Old 2003-02-15, 05:03 PM   #6
john_childs
Guinness Mojo
john_childs's Avatar
My DM has a similar splined hub and crank design as the KH. I found it was important to grease up the spline and grease up the threads on the pinch bolt on the crank. The KH also has a bolt at the end of the axle, make sure the threads on that bolt are also greased or anti-seized. Then tighten everything down. Grease or anti-seize on all of the threads will allow you to get things much tighter and will hopefully get rid of the squeaking.
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Reply
Tags
creaking, kh24
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright © 2001-2019 Gilby
You Rated this Thread:
Page generated in 0.05380 seconds with 10 queries
