Unicyclist Community
Reply
Old 2004-11-17, 03:28 AM   #1
David Stone
Newsgroup User
Posts: n/a
Super Trick Cycle levels
I have just bought my 2nd STC, and this one is set a little higher in the
seat (the other one is mainly for the kids in my uni club). Suddenly I can
do a new trick: While riding normal, I take off one leg, cross it over the
frame, and put it back onto the pedal so that the frame is now to my side.
It's hard to ride like that, but I can get some distance or just go in a
circle.
I'm also working on pedaling forwards while riding with the frame and
handlebars behind me. For this one, you have to lean far back and steer
backwards (it helps to be able to ride backwards the normal way).
If you don't own a STC, it's hard to understand what I'm talking about
(it's hard enough if you do have one). The thing is pretty screwy.
I've been toying with the idea of creating some levels for the STC. Has
anyone bothered to do this already (saving me some time)? If not, I'll
proceed.
Some sugg's:
Note: Backwards denotes the way you're facing
Note: In reverse denotes the way the STC is traveling relative to the
front of the frame.
Level 1.
Ride forwards 10 revs, STC facing the normal way.
Turn to the right 90 degrees within 2 revs (about 3m)
ditto for the left
Level 2.
Ride forwards 10 revs with the front section in the air, one or both hands
on the pedals or frame.
Turn 180 degrees to the right within 3 revs, both wheels on ground
ditto for the left
Level 3.
Ride in reverse 10 revs.
Riding forwards in a wheelie, spin handlebars around once, then continue
riding.
Level 4.
Ride forwards without hands, 10 revs (this usu means knocking the frame
with your knees).
Riding forwards, switch to riding in reverse.
Riding in reverse, switch to riding forwards.
Level 5.
Wheelie idle (idle while the front wheel is off the ground) while holding
the handlebars in one or both hands.
Pivot (swing) the front wheel 90 degrees while switching from forward- to
reverse-riding.
Ride forwards 10 revs with the frame (and handlebars) behind you.
Level 6.
Pivot (swing) the front wheel 180 degrees while switching from forward- to
reverse-riding.
Ride in reverse 10 revs with the frame (and handlebars) behind you.
Cross one leg over the frame while riding forwards and put the leg back
onto the pedal; then continue riding for at least 5 more revs.
Level 7.
Reverse wheelie
There are more skills I haven't thought up, and there are plenty I've
forgotten about, so please feel free to contribute suggestions. I'd be
about level 5 on this scale (I'm level 7 on a uni).
David Stone
Old 2004-11-17, 03:51 AM   #2
Bob22b
MCL Tearer :d
Bob22b's Avatar
Do you have a link to what one of these things is? I've never heard of it.
Bob22b is offline   Reply With Quote
Old 2004-11-17, 06:40 AM   #3
UniMachine
Machined Uni
Send a message via AIM to UniMachine
Yeah, What is a Super Trick Cycle?
UniMachine is offline   Reply With Quote
Old 2004-11-17, 11:08 AM   #4
s7ev0
woooaaaah!
s7ev0's Avatar
Mr Search he say...
one of these
__________________
"If god wanted us to believe in him - he'd exist"
Linda Smith
Avatar courtesy of Loosemoose.
s7ev0 is offline   Reply With Quote
Old 2004-11-17, 11:31 AM   #5
ur
Unicycling Revolution
ur's Avatar
Is it just a unicycle with an extra attachment of another wheel?
ur is offline   Reply With Quote
Old 2004-11-17, 05:08 PM   #6
jsm
Freestyler
jsm's Avatar
Given its setup, it shouldn't be to difficult to do many different kinds of wheel walk on it. You should also be able to ride one-footed.
jsm is offline   Reply With Quote
Old 2004-11-17, 05:40 PM   #7
lleberg
Can you ride that.. thing?
lleberg's Avatar
It is defenetly possible to go on the backwheel, and rotate the rest of the bike one whole revolution around the back wheel, you have to lean the bike a bit, but it is possible with a god head, quick feet and loads of tries.
Another thingyou could do is sit on the front facing backwards, and ride it as a penny farthing...
Also wheelwalk on the front wheel wile sitting on the seat.
Another stylish thing to do is wheelbraking the front wheel at high speed, and rise to the front wheel.
This is called a "stoppie" on motorcycles
__________________
I <3 my unicycle!
lleberg is offline   Reply With Quote
Old 2004-11-17, 06:15 PM   #8
UniMachine
Machined Uni
Wow, thats pretty cool. it looks like it would be easy to make one. Do you have any videos of you riding, I'd love to see one in action.
Old 2004-11-17, 06:33 PM   #9
David Stone
Newsgroup User
Posts: n/a
Re: Super Trick Cycle levels
"UniMachine" <UniMachine@noemail.message.poster.at.unicyclist.com> writes:
I'll try to make some this weekend.
David
Old 2004-11-17, 06:38 PM   #10
David Stone
Newsgroup User
Posts: n/a
"jsm" <jsm@noemail.message.poster.at.unicyclist.com> writes:
Wheel-walking is extremely easy on a STC. One-footing is easy, too, and
not very impressive. I wouldn't include them on the levels list bc they
are too easy. Basically if you can ride, you can do those 'skills.'
David
Old 2004-11-17, 06:55 PM   #11
lleberg
lleberg's Avatar
Re: Re: Super Trick Cycle levels
David
Why don't you combine them?
Edit: ehum, i mean:
Why don't you combine wheelie and wheelwalk, and wheelie and onefoot riding.
__________________
I <3 my unicycle!
Old 2004-11-17, 09:13 PM   #12
jsm
Freestyler
jsm's Avatar
I was thinking more on the line of harder wheel walks, such as hand, backwards, and standup up. Possibly only on the front or back wheel.
Old 2004-11-17, 09:55 PM   #13
lleberg
lleberg's Avatar
a standing wheelwalk on the front wheel, holding the backwheel in your hands.
__________________
I <3 my unicycle!
Old 2005-01-30, 11:26 PM   #14
adamstone
Registered User
i have built a 'stc', i hadnt seen a picture of one til after i built it, so it buzzes me to see other ones nearly the same .
i m probly bout level 7 i gues, i been riding a uni most days for bout a year now, and riding the funny bike since dec 2003,
one footed , wheelies n stuff. i call the penny farthing trick the velocipede, coz its frunt wheel drive, and then transfer to the seat and ride with front wheel trailin behind me.
thinkin of havin two seats or two unis attached , n e one seen that before?
adamstone is offline   Reply With Quote
Old 2005-01-31, 04:47 AM   #15
yoopers
Unicyclist
yoopers's Avatar
Send a message via Yahoo to yoopers
Problem with that is that the front wheel, at least on ours, doesn't have front brakes. I suppose that could be remedied easily enough. It definitely would add some depth to tricks on the STC.
Good idea for a trick if brakes were added.
Bruce
__________________
`_______
/l ,[____],
l---L ľ0lllllll0-
()_) ()_)----)_)
Munipsycho on the art of raising children: "My job is not to keep them from falling. It's to teach them to always get back up."
Always give lots of credit and take very little. Seems to make everyone happier. Conversely, take as much responsibility for mistakes as one can assume! - Dr. Bobo
unicycledude93: Steve Dekeokeok
unicycledude93: Yoopers
Byrnetown: haha, those are old guys
yoopers is offline   Reply With Quote
Reply
Tags
cycle, levels, super, trick
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright © 2001-2016 Gilby
Page generated in 0.09397 seconds with 11 queries
