Unicyclist Community
Go Back   Unicyclist Community > Unicycling Discussion > Unicycle Product Reviews
Reply
Old 2018-12-04, 08:10 PM   #1
gwymer
Unicyclist
gwymer's Avatar
Ultimate Wheel Build
So, every year at STOMP Munifest I mess around in a open field with one of the ultimate wheels someone has brought along. Then after STOMP I rush to unicycle.com because I have to have one. Then I see the price, and another year goes by. I just can't pay that much for something I am not even sure I can ride or if it will be something I use or just look at in a closet.
So, this year, I start wondering about making one. Thanks to UNIGEEZER, there are options out there. So, I grab an old 26 aluminum mountain rim and start cutting spokes. I get a pair of old cranks and cut them down and find some really strong large fender washers, and with the help of some sharpies, I even make the cheaper plywood I got look pretty good.
I thought I would share my saga, for several reasons. First, others might want to see if $30 is a way they want to try themselves with an ultimate wheel before investing in a light professionally made one. Second, and most importantly, it will help to keep me focused on learning and adapting as I continue this adventure.
Stay tuned....more to come.....
gwymer is offline   Reply With Quote
Old 2018-12-07, 06:14 AM   #2
jtrops
Unicyclist
Nice build! It’s cool to see that the pedal mounts I came up with are still useful.
__________________
"A properly ridden unicycle is like an object in orbit: constantly falling but never landing." -Diogenes
jtrops is offline   Reply With Quote
Old 2018-12-07, 11:38 PM   #3
MuniAddict
UniGeezer - Not "2" Tired
MuniAddict's Avatar
Looks great!
__________________
Happy Birthday Terry! Every year you get cooler, younger and unicyclier!
Be our muniprohpet for many years more.
-Dani Buron
Website
Videos
Facebook
MuniAddict is offline   Reply With Quote
Old 2018-12-23, 01:09 AM   #4
gwymer
Unicyclist
gwymer's Avatar
Update 1
Finally a slower day and better weather. So, I headed out to find a good fence or handrail--preferably with a smooth slightly downhill slope. Then time to tire myself out straining many muscles trying to find balance.
It was a pretty successful first day attempt. I was able to make up to 3 full revolutions while holding onto the hand rail. When teaching people to first ride the unicycle, anyone who can make full revolutions on their first day out, I am pretty satisfied.
With Christmas only days away and more rain in the forecast, not sure how much more practice I will get "this year". I will keep track of total number of days practice till I can "ride" it though. Gaps, I know, will slow the progress.
Here are 2 pics--one with me practicing just balancing on it and the other was taken while moving "forward"--I use that term loosely!
(After 20 minutes of saving and spinning and re-saving--NO CLUE why they are coming through sideways???)
Old 2018-12-24, 12:02 AM   #5
jtrops
Unicyclist
Nice Work! I should get out on mine too. How is the leg rub?
When I got a set of inline hockey knee/shin pads with plastic that wraps around the side of the leg it made my learning progress much faster.
__________________
Old 2018-12-24, 07:29 PM   #6
gwymer
Unicyclist
gwymer's Avatar
The KH leg armor works great if you spin the slick section inward. I am definitely going to have to get another tire, though. The knobby mountain one was what I had on the rim. The knobs love to try and grab the armor. It does look good though with the mountain tire. Working at a bike shop, I should have no problem getting someone's cast off-slick. That would make learning easier.
Curious what size your's is? Also, do you find more air or less air makes it easier to learn with? The online comments I have read say that learning on a larger wheel is easier. This is a 26. Looking ahead, I am worried that the biggest one I can find to buy is a 24". Up side though, an aluminum one would have to be much much lighter than the tank I built :-)
Old 2018-12-24, 09:19 PM   #7
jtrops
Unicyclist
yeah the tire is key. I have an old Avocet Cross/K that has virtually slick sides, and an inverted tread pattern. My current build is 700c, but my original was 26".
I used 3/4" plywood for my first one, and it was really heavy. My second build is nicer than the first one, and I used 1/2" Birch plywood for it. It is much lighter, and surprisingly, stiff. I was worried that it wouldn't be up to the task, but it hasn't had any problems in the years since I built it. In fact, it works so well that I don't imagine I'll ever purchase a pre-made one.
I would like to build a hub so that I can lace up a 32". My plan is to make the hub so that it resembles a hoop style kite string holder, but made out of metal, with spoke holes, and pedal threads.
You can search the forums for my ultimate wheel pedal mounts, and there should be pictures of the new wheel in there. The old pictures went away when the forum lost the"gallery."
__________________
Old 2018-12-26, 07:08 AM   #8
LargeEddie
Measure once, trim to fit
LargeEddie's Avatar
Quote:
I went through the same thing a while ago and the memory's a bit vague at this point but I think it was that a picture taken in "portrait" orientation was saved by the phone just as you see it, with a tag attached instructing the viewing software to rotate it by 90°. The problem was that while many browsers do what the tag says to with the image, others--such as Firefox, which I use--ignore it the tag.
The fix was to open the file in GIMP or some editing program like that and actually rotate the image to the correct orientation then re-save it. HTH and good luck with the ultimate wheel! One of these days maybe I'll get around to trying that.
LargeEddie is offline   Reply With Quote
Old 2018-12-29, 09:45 PM   #9
gwymer
Unicyclist
gwymer's Avatar
Question: for your 1/2" birch build, what size screws did you use in the spoke holes to keep from splitting the plywood? Also, did you use a single or double walled rim? I even had a little trouble with splitting near the hand notches with the 3/4. Yes, I even predrilled. I used 1 1/4" sheetrock screws.
Old 2018-12-29, 10:01 PM   #10
gwymer
Unicyclist
gwymer's Avatar
Day 2
Ok, We rode Muni this morning (7.5 miles) on a wet pretty technical trail, but since I still had good weather (finally) I had to get in some more practice on the Ultimate this afternoon. -about 45 minutes (then I was pretty worn and regressing)
Few things:
-Learned that if you can't keep it exactly straight, lean the top of the wheel towards the opposite side of the foot that is coming over the top of the revolution. Then you are coming up on the side it hits and so because it is lower on your leg, it doesn't grab you. (hope that makes sense?)
-Was able to do most of my practicing holding on with only one hand today.
-1st day my best was 3 revolutions in a row. Day 2, I set out to make it all the way down the rail (see pic) without stopping. Didn't make that--about 2/3rds of the way. Still much improved.
Overall, having taught many people to ride unicycle, I see now in myself about the same progress I hope for in those I teach. That is VERY EXCITING!!
I really think this is doable, and like unicycling, in 1-2 weeks (if I can get enough practicing in.)
Old 2018-12-30, 02:10 AM   #11
jtrops
Unicyclist
I used 1" sheet rock screws. I did drill pilot holes first. That wheel was built with a double wall (box section) rim. I don't remember off hand, but I think I used every third hole. The rim I used didn't have any offset for the spoke holes. I don't think I could have used a 1/2" sheet of wood if they had been offset. As it is I put the disc in the rim, and marked the holes, and the valve position. Then I removed the disc, and drilled the pilot holes down at each mark, but in the middle, so that the disc would be centered in the final build. I also cut out the space for the valve before I reassembled it, and screwed it together.
The first wheel I built was with a single wall rim. I had to use two rim strips on that one for fear of having a screw go into my tube.
__________________
Old 2019-01-06, 11:42 PM   #12
gwymer
Unicyclist
gwymer's Avatar
Day 3
Ok, You have to understand, I am one of those who learned to ride unicycle when I was 10, then 6 months later I took it apart to customize it, and didn't put it back together for 30 years. It was, however, like riding a bike, and in less than 30 minutes I was riding again like I was 10. Sooooo, I have taught lots of other people and improved my skills, but I haven't had to "learn to ride a new thing" in over 40 years now (if you are doing the math, yes, I turned 50 this year) I was very curious if my brain would adapt quickly, slowly, or not at all???
All that to say, any improvement each day would make me happy. I have been PLEASANTLY surprised. Each day (though only 3) has shown marked improvement. Today I made it the full length of the rail (see pic from last post) without stopping, only holding on with one hand, and did it 5 times. (not necessarily consecutively)
My newest reflection and pondering is: Does practicing daily without missing days, or practicing with gaps help or hurt the process???
-part of me thinks daily muscle memory would be better
-another part of me thinks, like working out, gaps give muscles time to heal and remember.
Thoughts????
Old 2019-01-07, 02:53 PM   #13
elpuebloUNIdo
Viva la revolucion!
I can't speak for UW riding in particular, but in general, my experience is that learning a new skill requires as-close-to-daily-as-possible practice (and a lot of it). Once a skill is learned well, I find sometimes when I return to the unicycle after a week hiatus, I have better finesse at it. One footed riding is an example of a skill I only learned moderately well, and as a result, I slip back on the learning curve. I'm guessing that with the UW, some muscles get tired, so I suppose a break can be helpful.
elpuebloUNIdo is offline   Reply With Quote
Old 2019-01-12, 12:34 AM   #14
gwymer
Unicyclist
gwymer's Avatar
Day 4
Well, today was 2 extremes. I started out feeling like I had regressed--shorter distances and lots of mistakes. After a few tries though, I started focusing on trying to get off the rail. After 30 minutes, my best ride was 5 revolutions without touching the rail.
Referring back in my mind to teaching others to ride unicycle--I am at the pivotal point of getting it. I have the concept but not the control and consistency. That is still VERY exciting. This looks like it is doable and in a reasonable amount of time.
I did have my first Superman UPD though, while setting my 5 revolution record. Not exactly the way I wanted to end it. Next time, I think I am ready to get out my gloves. Little bit of road rash on my palms today.
Old 2019-01-16, 04:56 AM   #15
gwymer
Unicyclist
gwymer's Avatar
Tire Change
Been really cold, BUT a friend hooked me up with a new tire that he had for a mountain bike trainer setup. Excited to see if it moves the learning curve along faster.
Will let you know
Before and after pic below--Yes, flipped sides--One side black and white, other side colored--that way I know which is right and left.
Reply
Tags
build, ultimate, wheel
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
[Wanted North America] Ultimate wheel. OR Unicycle with 28-29" Wheel, dont need high end FreeFlyFreak Trading Post 0 2010-12-06 12:41 AM
Not sure I got wheel build right ezas General Unicycling Discussions 30 2010-08-11 07:59 AM
The Viz Rim and my Ultimate Build uniaddict Unicycle Product Reviews 52 2009-02-20 09:30 AM
How NOT to build a wheel mike.hinson General Unicycling Discussions 5 2004-03-06 11:30 PM
how to build a wheel ? tandys General Unicycling Discussions 2 2001-05-07 10:58 AM
Powered by vBulletin®
Copyright © 2001-2019 Gilby
Page generated in 0.11327 seconds with 12 queries
