Unicyclist Community
Reply
Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 2008-08-13, 09:36 PM   #1
danger_uni
Kris Holm
137's on KH24 for Freeride/Technical downhill
Hey,
After a summer of riding a 36'er with 110's, I decided to replace the 150's on my KH24 with 137's and see how it felt on technical downhill on the Vancouver North Shore. I've used shorter cranks before for XC riding but never on harder stuff.
Only one ride so far, but I really like it and am going to stick with it for now. Descents feel much smoother and it is easier to spin out off the bottom of transitions. Also cornering is smoother and it is nice not to worry so much about hitting pedals on the ground.
Big caveat: Using this setup for technical riding really benefits from effective use of a brake, especially with a Spooner on it. I felt like I was depending on the brake for most of my braking power through transitions and quick stops. It's nice to do that anyway with 150's but with the 137's it actually felt easier to brake while pedalling through bumps.
Also, it is easier to get used to this if you are already used to pushing shorter cranks on a 36'er.
Just thought I'd pass that along. Anyone else tried this setup?
Kris
danger_uni is offline   Reply With Quote
Old 2008-08-13, 09:48 PM   #2
2simpl
2simpl
Send a message via MSN to 2simpl
I was riding my qu-ax custum muni on the begining with 170mm cranks, change to 145mm cranks and now i ride with 137mm kh cranks and I lovin it <3
Like that you say, its easier, faster and smother to ride downhill
2simpl is offline   Reply With Quote
Old 2008-08-13, 09:54 PM   #3
MuniAddict
UniGeezer - Not "2" Tired
MuniAddict's Avatar
Quote:
Originally Posted by danger_uni
Hey,
Kris
I can see the speed advantage of 137's over longer cranks, and less up/down leg movement for DH, but I love climbing as much as DH, so I'll stick with my 150's for now. If doing mostly DH, why not go even shorter, like 125mm?
__________________
Happy Birthday Terry! Every year you get cooler, younger and unicyclier!
Be our muniprohpet for many years more.
-Dani Buron
Website
Videos
Facebook
MuniAddict is offline   Reply With Quote
Old 2008-08-13, 10:17 PM   #4
2simpl
2simpl
with 125mm will be much harder to brake becuse it will be so much spead....I think so, maybe i will try
Old 2008-08-13, 11:19 PM   #5
agentQ
Sam Haber
agentQ's Avatar
Send a message via AIM to agentQ Send a message via MSN to agentQ
I have been wanting to throw some short cranks onto my muni for a while. I am without hub at the moment... no pun intended.
I do not have a lot of muni experience tho I have been giving much thought to working on some fast paced freeride type stuff. http://www.vimeo.com/810530 this was my first attempt at Muni with tricks, tho I ended up thinking, even tho I am much more comfortable on a 19" that the speed advantage of a 24" for that kind of riding would be a great addition (with much practice of course). However with Muni longer cranks hit rocks and would aslo jolt the rider around more. So short cranks would help smooth things out a little as long as the rider has no fear and good brake control.
Glad you posted this Kris, It will help inspire me to build up my muni again with shorter cranks and a brake.
-Sam
__________________
Uneed Films
Whats up with Street and Flat?
the Unicycle Lab
agentQ is offline   Reply With Quote
Old 2008-08-13, 11:36 PM   #6
phlegm
Unicyclist
phlegm's Avatar
I decided to replace the 150's on my KH24 with 137's...
Awesome! Not that my rides are intense as Northshore riding but I've been running this setup for about a month now on local Santa Cruz MUni rides, and I definitely prefer it to the 150s.
The only bad thing is that UDC (US) is out of 137s at the moment, and I still want another pair for my KH29. It won't help if everyone wants to be like Kris.
phlegm is offline   Reply With Quote
Old 2008-08-13, 11:46 PM   #7
MuniAddict
MuniAddict's Avatar
I think what it comes down to is what works best for you. One size definitely does *not* fit all. Some even prefer 170mm for the added torque and for climbing especially long, increasingly steep terrain. Others, like Kris H., preferred, and recommended the 150's for the longest time.
I started with 165's back in '05-the same size used by at least 4 (and likely many more) of the best MUni riders in the LA/SB area-but since changing to 150's, I would not go back to the longer cranks. I find the 150's to be the perfect size [for me] for doing steep climbing, rolling technical terrain, natural trials... and they allow for plenty of speed, adequate torque and less need for braking, and they're also great for drops of any size. But I suppose if you're primary focus is downhill, than 137mm might be the way to go, or even shorter. Well, that about sums it up for me.
__________________
-Dani Buron
Website
Videos
Facebook
Old 2008-08-13, 11:54 PM   #8
phlegm
Unicyclist
phlegm's Avatar
Quote:
137s feel better to me for climbing than 150s! Try it, and see if you like it.
125s feel a little short to me when doing a lot of dropping onto uneven trails, and then I'd definitely have to put a brake on my KH24.
Old 2008-08-14, 12:01 AM   #9
MuniAddict
MuniAddict's Avatar
I have tried 137's...on a KH 29er lol! It was before I bought a 36er and that's all I had to keep up with the big wheels, but I was able to keep up fine. I just pedaled way faster! IT was all on flat, beach path.
But, for me it's about control as well, and the 150mm give me all the things I mentioned, and less need for a brake on steep DH.
There was at least one thread a while back about whether logic & physics should be thrown out the window, with some people stating that shorter cranks are just as, or even EASIER to climb the same steep terrain as longer cranks. There is no question that the shorter the cranks, the *less* leverage you have and the more pedal force it will take to climb.
If anyone disagrees, than I don't know what to say lol! There are still people who believe Elvis P is alive & well, and that the earth is indeed, flat! Oh, and just for the record, I know you didn't say that in your quote above, but it just kinda me of the old thread.
__________________
-Dani Buron
Website
Videos
Facebook
Old 2008-08-14, 12:10 AM   #10
danger_uni
Kris Holm
I think it has a lot to do with the difference in feeling between when you first jump on to a uni with short cranks, and when you actually get used to it. After a lot of riding on a 36'er with 110's, climbing steep hills on a 24" with 137's felt just as easy if not easier than how 150's used to feel.
But for technical riding it really does depend a lot on your riding style. If your style is oriented towards rolling through technical sections, shorter cranks are great. If you want to slowly hop and work your way down, you won't run up against any limitations in spinning anyway, so longer crank would be more appropriate.
Plus as I mentioned it is a lot easier to use shorter cranks with brake because the limiting factor for technical riding with short cranks is not climbing, it is quickly stopping or preventing too much acceleration.
Kris
Old 2008-08-14, 12:20 AM   #11
MuniAddict
MuniAddict's Avatar
Kris
I see the key word there is "feel"? So, would you say that 137mm feels/is easier for steep climbs than, say, 150mm, does that also hold true for even longer, 170mm cranks? If so, can we assume that the shorter the cranks, the easier it is to climb?
Taking it to the extreme, would not even shorter cranks in the 100mm, or even 89mm make climbing even easier? In other words, where is the "cutoff point" in shorter cranks going from being easy/easier to climb with, to being difficult or entirely impractical for steep climbing? I'm being facetious, but I'm just trying to understand the reasoning that shorter cranks "feel" or indeed are, for some it seems, easier for climbing.
Maybe I'm mistaking "easier" for more efficient? I mean that even though you may be expending more force to get up a hill using a shorter crank, maybe it's just "easier" in the sense that your legs are making smaller circles and you are concentrating your energy-albeit a greater amount-in a more efficient manner?
__________________
-Dani Buron
Website
Videos
Facebook
Old 2008-08-14, 12:35 AM   #12
phlegm
Unicyclist
phlegm's Avatar
1. I think shorter cranks feel more controlled when spinning fast, and I think most people that spin fast would agree. I agree with Kris' point about riding style. My style is definitely more rolling and flowing oriented than stopping a lot to hop over/through obstacles.
2. The physics of a unicycle and unicyclist is quite complex. There are a lot more factors than just leverage to consider.
3. I never said 137s are better for everyone. You can argue all you want using ideas from physics, but trying them out is the real test. I've tried 137s, and I really like them. Who really cares about the underlying reasons that 137s feel better?
Old 2008-08-14, 12:42 AM   #13
MuniAddict
MuniAddict's Avatar
HAha I was only referring to *climbing* with shorter and shorter cranks, and that some people were declaring that the shorter they [cranks] are, they are somehow *easier* to climb with. Maybe more efficient yes, but more pedal force is required than with longer cranks. That's just a simple fact. Less leverage=more force required.
You referred to *SPINNING FAST*, meaning DOWNHILL. Lol, I know that the shorter cranks are great for DH, as KH first posted about in this thread. I love spinning fast too..especially with a camera in my hand shooting POV! It was only the uphill aspect that I was talkng about, and that if your primary focus is "spinning fast" downhill, then hells yeah! Shorter cranks rule!
But for me, I like climbing and everything else, so a good, muilt-purpose 150mm is just right for me.
__________________
-Dani Buron
Website
Videos
Facebook
Old 2008-08-14, 12:49 AM   #14
phlegm
Unicyclist
phlegm's Avatar
Climbing does feel easier to me with 137s than 150s, and I'm definitely one who enjoys climbing. I could propose a number reasons for why 137s feel easier to me, but frankly I don't care.
Old 2008-08-14, 12:54 AM   #15
Rubix
01010101 01001110 01001001
Rubix's Avatar
Send a message via Yahoo to Rubix
The shorter the cranks, the less torque you can get on them. I've been riding my 29er with 102mm cranks, going from 125mm. I've had trouble getting started due to the length of the cranks. Its not about what length is "easier", its about adapting to what you have. Granted I haven't ridden in a few weeks, it is still a bit difficult to static mount with 102mm cranks (correction: mounting is no prob, its getting her rolling is the problem). There would be no way I could climb a steep hill with 102s, I'd detour that hill, and look into getting back to the 125mm cranks I was used to and could climb.
__________________
Riding a unicycle is about as close to Zen as I can get. Nothing else matters during a ride except to enjoy what's around me.
Rubix is offline   Reply With Quote
Reply
Tags
137, downhill, freeride or technical, kh24
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
26" Freeride/Downhill Einrad ZU VERKAUFEN foxx Deutsches Einradforum 7 2009-02-01 10:29 PM
using 137's for street unikid132 General Unicycling Discussions 6 2008-04-15 01:00 AM
technical tricks. zippy General Unicycling Discussions 1 2006-06-08 04:27 PM
KH24 Freeride, How Happy RU? Memphis Mud General Unicycling Discussions 11 2005-05-28 12:29 PM
Need technical DVD/PVR help! bugman Just Conversation & Introduce Yourself 5 2005-02-03 10:28 AM
Powered by vBulletin®
Copyright © 2001-2019 Gilby
You Rated this Thread:
Page generated in 0.14714 seconds with 11 queries
