Unicyclist Community
Reply
Old 2003-02-16, 02:23 AM   #1
John Hooten
Newsgroup User
Posts: n/a
KH24 creaking - Fixed!
Well, I stopped by my local Napa auto parts store and picked up a tube of
Anti-seize. There was a remarkably large selection, considering I had never
even heard of anti-seize before yesterday. I chose the 1 oz, tube for $3.59
over the 10oz. can for $6.something. If properly cared for the 1 0z. tube
just might be a lifetime supply. Once home I removed the cranks, applied
anti-seize and reassembled the unicycle. I then took a ride, climbing the
same hills where the creaking appeared yesterday. The creaking is gone.
I wanted to change one thing at a time and thought that the creak was
definetly coming from the crank and so worked on that first. But, I checked
the spokes when I got home and they definetly need tighting. I will work on
that tomorrow. I probably should have checked and tightened the spokes
before. It is, after all, a production wheel, not a professionally made
one.
Thanks for all your help.
John Hooten
john_childs wrote:
> My DM has a similar splined hub and crank design as the KH. I found it
> was important to grease up the spline and grease up the threads on the
> pinch bolt on the crank. The KH also has a bolt at the end of the axle,
> make sure the threads on that bolt are also greased or anti-seized.
> Then tighten everything down. Grease or anti-seize on all of the
> threads will allow you to get things much tighter and will hopefully get
> rid of the squeaking.
> john_childs
> john_childs (at) hotmail (dot) com
> john_childs's Profile: http://www.unicyclist.com/profile/449
> View this thread: http://www.unicyclist.com/thread/23506
Reply
Tags
creaking, fixed, kh24
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright © 2001-2019 Gilby
Page generated in 0.07909 seconds with 10 queries
