Unicyclist Community
Reply
Old 2007-01-29, 04:12 AM   #1
tjrook
Level 2 Rider!
tjrook's Avatar
Send a message via MSN to tjrook
Unhappy Mounting...
I dont know if I'm just freaking out, and I dont know how common this problem is, but I'm having a problem with freemounting. I've only started unicycling about a week ago, so it's probably common to have a problem with it, but it's really weird because I was progressing very fast, and now it's been a few days where I've been trying to freemount, and am not able to do it.
I can ride for as long as I want, and dont need any support at all, I just need to be able to get on the unicycle without help! I've done it once or twice, but it felt more like luck than anything else.
If anybody here has some advice for me on what to do, it would be greatly appreciated. If all I need to do is keep practicing, then go ahead and yell at me, and I'll keep practicing!
__________________
My unicycle: Torker Unistar LX 20"
Listening to: (usually something "soothing")
Quote: "Keep smiling, it makes people wonder what you're up to."
tjrook is offline   Reply With Quote
Old 2007-01-29, 04:15 AM   #2
The Buddy
Registered User OF CANDY!!!
The Buddy's Avatar
Send a message via AIM to The Buddy Send a message via Yahoo to The Buddy
I know how that feels! I can freemount 60% of the time and one thing that really helped me was putting a board (or a curb) right behind the wheel. That really helps to get the motions down. Good luck and keep practicing!
The Buddy is offline   Reply With Quote
Old 2007-01-29, 04:22 AM   #3
uni_jim
i shot a clown and stole his bike.
uni_jim's Avatar
if you have a smallisher wheel put your first foot almost all the way down and step down so that your uni comes under you, then stick ure other foot on the other pedal an go.
With a 24"+ you can put your pedal halfway (in the horizontal position) and without putting weight on it, push off of the ground w/ your other foot with your weight on the saddle. Then you can put Foot #2 on pedal#2 and ride off into the sunset
__________________
evolve trials
Quote:
Originally Posted by pedrotejada
flatlanders are street riders with fear of height and ladders...
uni_jim is offline   Reply With Quote
Old 2007-01-29, 06:05 AM   #4
uniredneck
Wrenching Specialist
uniredneck's Avatar
Send a message via AIM to uniredneck
Hey, I had the same problem for awhile. I learned to freemount on a 24" LX and the way that uni_jim described worked best for me and after about a month I get up about 80% of the time. Just keep up the practicing. Remember to lean forward if using this technique, your legs will follow with uni will follow.
uniredneck is offline   Reply With Quote
Old 2007-01-29, 12:48 PM   #5
CKCrowe
Unicycle is my life 1-5 hours a day
CKCrowe's Avatar
Send a message via AIM to CKCrowe
idk how thts like, my sis and I both learned to freemount before riding, she started at 8 and I got my uni at 11, but started at 14 lol.
CKCrowe is offline   Reply With Quote
Old 2007-01-29, 05:18 PM   #6
thejdw
elcycinu
thejdw's Avatar
Pratise make shure you push the pedal back a fair way ot it won't work
I can get it 97% of the time
__________________
I didn't spell it wrong, you just read it wrong!
thejdw is offline   Reply With Quote
Old 2007-01-29, 07:07 PM   #7
Keldridge
Wobbles but mostly upright
Keldridge's Avatar
I am just getting freemounting down. I am probably 50/50 now. These are the things that helped me.
First, find some video of someone doing it. That helped a ton. I used the one off the skills page at www.unicyclist.org...
I started pretty slow too. I found for me, that using a little bit of frustration as extra ooomph to get me up helped the first few times. Seems I was trying to be too timid. I started to jump further, and fight close ones harder, and then it started to come around a bit more.
Also, something that really helped my son get it. I mount with my left foot on the pedal, and my right foot down. When I would jump, my wheel would turn left, and I would fall left. I found I had to move my right foot in just a bit, and actually think about jumping about 20 degrees to the right. I would pick out a tree or something off to the right of where I wanted to go and jump towards it. It really helped me come up and be more centered.
Finally, just believe that you will mount. At some point, I just decided to do it, and I started doing it way more often...
Hopefully, some of this helped... I love the freedom of mounting without help...
Keldridge
Keldridge is offline   Reply With Quote
Old 2007-01-30, 01:11 AM   #8
tjrook
Level 2 Rider!
tjrook's Avatar
Thanks for all of the help so far! I'm sure it will all be very helpful. It's really cold outside right now, so I only get about 10 minutes of practice in before I start feeling like an ice cube, but I think that I've discovered something. I am able to get up onto the unicycle, and am able to balance myself pretty well too, I just have a problem getting that initial push on the pedals so I can get going. My feet either slip off, or they just dont want to move. It's really weird. Is this where I need to learn to lean forward or something?
This really sucks because I cant experiment at all. I think I would have probably have my problem solved already if I had the time to actually unicycle...
__________________
Old 2007-01-30, 02:19 AM   #9
Keldridge
Keldridge's Avatar
Sounds like you need to lean forward a bit and get the weight on the seat instead of the pedals...
Keep at it...
Old 2007-01-30, 03:21 AM   #10
Tomahawk
T.O.M.A.H.A.W.K.
Practice. I've been riding for half a year and can now freemount 100% of the time effortlessley
Tomahawk is offline   Reply With Quote
Old 2007-02-01, 11:42 PM   #11
Joe2005
Unicyclist
Just jump on it while doing a 720 unispin it's easier...trust me
__________________
Nobody knows what happened to that boy after that.-Nutcracker
I know. He was kidnapped by aliens, learnt their ways, stole the biggest ship he could, travelled back in time by mistake and crashed the plane on the Earth surface. He was the one who killed the dinosaurs. -Ivan
Joe2005 is offline   Reply With Quote
Old 2007-02-02, 02:12 AM   #12
fuolornis
Unicyclist
I started out the way other posters have described, but now the pedal my foot starts out on is way at the top, nearly exactly on top, and I move forwards as I mount so there's nearly no wheel motion while I get on.
fuolornis is offline   Reply With Quote
Old 2007-02-02, 07:07 AM   #13
wobbling bear
GranPa goes-a-wobblin'
wobbling bear's Avatar
AFTER 4 years of practice I still have bouts of freemounting failures.
I suspect that in my case it is psychological: there are places and moments I feel I will miss .... and I miss!
(the real problem is I hurt myself twice quite badly while freemounting ... so I still have anguish that pops up).
So I need to relax and go with proper thrust and "I don't care" state of mind. I developped lots of small tricks for different unis that help me freemount.
They are a combination of foot position, weight transfers, seat height (and sometimes tire grabs on big wheels, I used to do running mounts but now no more since I broke a toe doing that ).
I envy those who do that effortlessly!
__________________
One Wheel : bear necessity
(Abuello RodoMancat)
wobbling bear is offline   Reply With Quote
Old 2007-02-02, 07:19 AM   #14
WizzKidd!!
Hello Pavement!
Quote:
I totally feel your pain since I'm in the exact same position as you right now. I find that I mount much better when I'm fresh, but later I get maybe 5% of my mounts, on a good day.
I also feel like I can't get going. I tried rocking my feet back and forth to get some motion, then go forward. It helps sometimes. But sometimes I get stuck in a backwards motion and it all goes bad from there. I think we both just need more practice.
WizzKidd!! is offline   Reply With Quote
Old 2007-02-02, 10:42 AM   #15
phthoruth
one footage
phthoruth's Avatar
Try lowering your seat. It makes the free mounting easier. Riding is marginally harder.
Leg pads help save your shins and raise your confidence.
phthoruth is offline   Reply With Quote
Reply
Tags
mounting
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mounting my 6 ft. uni. Amy Weissman General Unicycling Discussions 8 2007-03-29 02:15 AM
Mounting! ackgot General Unicycling Discussions 16 2006-08-28 03:47 PM
Mounting... molab General Unicycling Discussions 13 2006-01-16 12:34 PM
mounting help please? habbywall General Unicycling Discussions 3 2005-06-30 01:50 PM
Mounting Eublapharis13 General Unicycling Discussions 25 2003-06-14 06:11 PM
Powered by vBulletin®
Copyright © 2001-2019 Gilby
Page generated in 0.08439 seconds with 11 queries
