Unicyclist Community
Reply
Old 2009-04-15, 08:40 AM   #1
pfalvi
Unicyclist
Kris Holm Seatpost twisting in Coker Frame.
Hi there. I have a Coker Big One, and a Kris Holm rail type seatpost to attach my T7 handle. When I mount, the seatpost will twist to the right, and I can't ride far before stopping with a wall to re adjust. I have it tightened as much as I physically can, but it will still turn. Any suggestions?
pfalvi is offline   Reply With Quote
Old 2009-04-15, 09:42 AM   #2
johnfoss
North Shore ridin'
johnfoss's Avatar
Don't hold the T7 handle when mounting, just hold the front of the seat. This will greatly reduce the torque that's being applied during mounting. If that's the only time your seat twists, it might be enough. Otherwise you may want to look into a 2-bolt seat clamp.
__________________
John Foss
www.unicycling.com
"Who is going to argue with a mom who can ride a unicycle?" -- Forums member "HiMo"
johnfoss is offline   Reply With Quote
Old 2009-04-15, 10:27 AM   #3
paul royle
RTL Team 23 Lost Wheelers
paul royle's Avatar
It may not be the seatpost twisting in the frame.
On the original KH rail posts the clamp (silver bit that holds the T7) was a press fit into the top of the post, and sometimes this joint became loose, particulary if used with a T7. Later KH rail posts are pinned at the joint between clamp and post to prevent this.
You can easily check if it's the post turning in the frame or the clamp moving in the top of the post by noting the postition of the writing on the post relative to the frame before you start riding, and after the seat twists.
If it's the clamp moving in the post it's simple to fix, either buy a later post with the pin fitted, or if you have the tools drill a hole through the post and clamp and put a thin bolt through.
Paul
paul royle is offline   Reply With Quote
Old 2009-04-15, 06:22 PM   #4
pfalvi
Unicyclist
Kh
The weird thing is that I do have a 2 Bolt. And the pin. And still, I can easily twist it with my hands. It didn't happen before I got the Kris Holm.
Old 2009-04-15, 07:18 PM   #5
johnfoss
North Shore ridin'
johnfoss's Avatar
It's possible your new seat post is not the correct size for the seat tube. I don't know the measurements offhand, but if it's off by 1mm it may not look wrong, but it may be a problem to keep it tight. If the slot in the seat tube is closing nearly all the way, or if your clamp is closing all the way (no gap where the bolts go through) it means something isn't fitting right.
__________________
John Foss
www.unicycling.com
Old 2009-04-15, 08:12 PM   #6
scott ttocs
Unicyclist
scott ttocs's Avatar
Is the post twisting in the frame, or is the insert twisting in the post?
scott ttocs is offline   Reply With Quote
Reply
Tags
coker, frame, holm, kris, seatpost, twisting
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
[For Sale: North America] New Magura HS33 brake sets in Kris Holm Blue. Four sets available, $90 per wheel!!! brycer1968 Trading Post 14 2009-04-20 05:00 AM
Does the 08 Kris Holm Seatpost Work with a Thomson? Unreal-Wheel General Unicycling Discussions 10 2008-10-20 05:25 AM
Kris Holm Seatpost issue... Theo General Unicycling Discussions 36 2007-10-28 11:20 AM
Kris Holm Coker frame nikkifrog General Unicycling Discussions 31 2003-05-07 05:53 PM
FW: Kris Holm Coker frame John Drummond General Unicycling Discussions 1 2003-04-12 01:31 AM
Powered by vBulletin®
Copyright © 2001-2019 Gilby
Page generated in 0.06040 seconds with 11 queries
