Unicyclist Community
Reply
Old 2004-09-22, 04:34 AM   #1
dogbowl
Member, Sun28 Appreciation Society
dogbowl's Avatar
Loose Main-Cap Bearing Housing nuts: Good?
Here's a strange discovery...
Everytime I am riding well and actually freemounting with some regularity, whenever my unicycle responds to my every whim and command, I discover that the Main-Cap Bearing Housing Assembly on the left side of the axel is loose. Not by much, but enough to give my axel a bit of "give and take."
I tighten the two screws, and then my unicycle does not ride as well. The wheel turns fine, but any time the two screws (or nuts) on the left are not jangling ever so slightly, I start riding like crap.
They always get loose by themselves--I am wondering if there is a structural flaw in my frame, or perhaps it is my riding.
My real question is, does it matter? When the two screws on the left side give my axel a bit of give, my riding is a hell of a lot better and I have a lot more control over the machine. I tighten them, and it sucks.
Is this normal? Can slightly loose nuts on one side of the axel for the Main-Cap Bearing Housing Assembly be harmful to Monster-X (that is the name I have given my 26inch Nimbus MUni)or is it normal for unicycles to have a bit of give in the axel area?
__________________
EX-Unicyclist...because I did not wear elbow pads.
All I want out of life is to be able to ride the unicycle while smoking a cigar at the same time. Is that too much to ask for?
www.dogbowl.com / www.eyeballplanet.com
dogbowl is offline   Reply With Quote
Old 2004-09-22, 05:00 AM   #2
john_childs
Guinness Mojo
john_childs's Avatar
The main cap bearing nuts should stay tight. You should have nylock nuts on the Nimbus. Maybe you need to replace the nylock nuts with fresh ones. Nylock nuts have the nylon inserts that are supposed to lock the nut to keep it from working loose. If the nylock insert gets worn it won't hold and the nut will work itself loose.
Another option is to use a little Loctite threadlocker on the nuts. You can get Loctite threadlocker at most auto parts stores and some hardware stores. The medium strength stuff will be strong enough to keep the main cap bearing nuts tight.
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2004-09-22, 05:05 AM   #3
chirokid
The Russian Bear!!!
Send a message via AIM to chirokid
Quote:
Originally posted by john_childs
Loctite on the nuts.
I agree with John, put a drop of Loctite on the threads and tighten those cap nuts one last time.
I suspect that in time, you will actually ride much better with the nuts tight. I know your unicycle will last longer with the nuts tight.
NOTE: One little drop of loctite is all you need, per bolt. --chirokid--
__________________
"Other than that, the best maintenance is to keep riding it as this helps to keep the eccentric nut on the saddle in optimal condition." quote by Mikefule
chirokid is offline   Reply With Quote
Reply
Tags
bearing, good, housing, loose, maincap, nuts
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright © 2001-2019 Gilby
Page generated in 0.25574 seconds with 10 queries
