Unicyclist Community
Reply
Old 2002-10-21, 02:16 AM   #1
andrew_carter
Back into muni!
andrew_carter's Avatar
Bearing Housing Types?
I keep hearing about main-cap bearing housing. Are there any other types and if so, do they have any real advantages or disadvantages?
Also, are main-cap and end-cap ones part of the same style?
Thanks,
Andrew Carter
andrew_carter is offline   Reply With Quote
Old 2002-10-21, 02:42 AM   #2
Scott Stephens
Equipment Destroyer
Scott Stephens's Avatar
Send a message via AIM to Scott Stephens
Question
I often ask a question like this. There are main-cap and lollipop bearings. Main cap is what is on most unicycles. Lollipop is a much cheaper, and a lot worse quality that main-cap. I dont have any idea what lollipop looks like though, just main cap. A Savage has lollipop bearings i think.
Scott
__________________
If it weren't for electricity we'd all be watching television by candlelight."
George Gobol
I have worked too hard to be a clown. I am an athlete and wish to be respected as one.- Checkernuts
Scott Stephens is offline   Reply With Quote
Old 2002-10-21, 02:48 AM   #3
Scott Stephens
Equipment Destroyer
ok
I just looked at unicycle.com under "lollipop". The difference is that lollipop has screws on the side that are apparently not very strong. Look at your unicycle at the end of the frame. See how it cuts off and then here is a peice that is a semicircle that you had to connect when you put it together? That is kind of unclear i know, but that is main cap. Lollipop is just a couple cheap screws.
__________________
George Gobol
Old 2002-10-21, 02:50 AM   #4
andrew_carter
Back into muni!
Alright thanks for that.
Old 2002-10-21, 03:23 AM   #5
Max_Dingemans
Pedal Pedal Crash
Max_Dingemans's Avatar
Send a message via AIM to Max_Dingemans
I would say go for hte main-cap style for a trials Uni. they are a better hold on the bearings, and they tend to last longer.
__________________
There is nothing worse than a gross exaggeration.
Max_Dingemans is offline   Reply With Quote
Old 2002-10-22, 12:38 AM   #6
Gardner
Newsgroup User
Posts: n/a
Re: Bearing Housing Types?
In article <Scott.Stephens.cur9p@timelimit.unicyclist.com>,
Scott Stephens <Scott.Stephens.cur9p@timelimit.unicyclist.com> writes:
They look like this:
http://unixcomputer.net/new-photo/frame-broke/
This also illustrates the main problem with the design and
a fix that's been working for me (so far).
Gardner Buchanan <gbuchana@rogers.com>
Ottawa, ON FreeBSD: Where you want to go. Today.
Reply
Tags
bearing, housing, types
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright © 2001-2019 Gilby
Page generated in 0.07959 seconds with 10 queries
