Unicyclist Community
Reply
Old 2002-06-27, 01:42 AM   #1
teachndad
ONE for the...Off Road
teachndad's Avatar
Location: West San Fernando Valley, Southern California
lenght of hose on magura brakes?
Hi,
I need to know the appropriate length for the magura brake hose
from the brakes to the brake lever assembly.
I looked at Kris Holm's Unicycle at his website and it shows
virtually no slack.
The KH model Muni at unicycle.com shows some slack. Which
would be optimum.
thanks,
__________________
Rod
scottw818.wixsite.com/vintage-rod-and-reel
teachndad is offline   Reply With Quote
Old 2002-06-27, 01:45 AM   #2
Sofa
you - pee - dee
Sofa's Avatar
if you are planning to take the seatpost off to put in a car or something, you'll need slack, only enough to seperate the two peices.
If you are keeping the uni attached all the time, no slack is needed. The hose needs to curve kind of naturally, though.
Sofa is offline   Reply With Quote
Old 2002-06-27, 02:11 AM   #3
john_childs
Guinness Mojo
john_childs's Avatar
Kris is using the steel braided Magura brake line. The pic on unicycle.com shows the stock plastic brake line. The braided brake line is much more flexible than the plastic line and that is probably why Kris has less slack.
One problem with a brake line is the line getting snagged when you try to catch the muni after a UPD. Having less slack makes it less likely that you will snag the line and break it off.
Less slack is better, but there is a limit to how little slack you can have with the unflexible plastic line.
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2002-06-27, 10:23 AM   #4
Sofa
you - pee - dee
Sofa's Avatar
There is no need for the braided line, however, if you make the hose long enough to take the seat off, then spin the seatpost around several times before tightening.
In this picture, I left the hose the length it was on my bike, so I could switch between the two. It's all grabbed tight and taped to the frame. It still workes, but the line was warped after that (fine for uni, fine-but very ugly for bike)
Reply
Tags
brakes, hose, lenght, magura
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright © 2001-2019 Gilby
Page generated in 0.05124 seconds with 11 queries
